OCTAGON / HDBOX Enigma2 PKT Ferrari F1 Image
Enigma2 OpenSource SH4 Duckbox Project GIT-337 PKT mod SVN-147 Ferrari F1 Image
Image for instalation on pendrive.
For HD boxes: Octagon SF1018, AT7000, FS-9200 and other ressellers ...
Screeny:
Changes sh4 Duckbox Team:
- merge tdt changes up to rev 2028, thx tdt for updates.
- commented out poll operation on PVR_COMMIT, it delayed first timeshift picture for up to 10 seconds
- updated filepush.cpp from opendreambox git to significanltly improve timeshift start behaviour
- update stboards patch
- servicedvd patch for HD Skins - Thanks to nit
- new workaround for deadlock problem which does not disturb fwd/rew - thanks to tdt
- Fixed race-conditions using Mutex in Audio
- fix avs standby proc output
- fix audio problem
- libeplayer2: Re-enabled 'PLAYBACK_TERM'; indented many #ifdef's for better reading
- fix dvb subtitel
- fix dvd menue (is not perfect)
- fix dvdplayer button position
- fix button color in dvdplayer
Changes PKT:
- new default skin PKT F1 HD
- new MOUNT Manager 0.7.4
- corrected Polish translation
- fix for GS after change channel list
- update picons
- update channel list
- added new menu for PKT Infocenter
- WebcamViewer - cameras update
- update Finnish Enigma Timo Jarvenpaa
- fix for GS when haven't HDD
- added Czech locales
- update MediaCener - added SHOUTcast radio
- list favourite radio stations -> /var/config/SHOUTcast.fav
- added Webinterface Version: 1.6rc2
- fix for navigate (stability, smooth move) channel list, code optimalization
- fix for display Polish days name on Standby mode
- activation mode moderate Standby in BP
- fix for mount CIFS and NFS
- activation NTFS filesystem
- activation automount for devices connected to USB - mountpoint -> /media
- added Romanian translation E2 (superonic, costel_mbc, neutrin, otheitis, cipy_1982, neutrin, runcanion)
- update drivers for card reader - should work all the cards in the system N3
- oscam by BP soon
Zipped files pack have:
- E2_Instalator_v-0.7_EN -> tool for installation image - English
- E2_Instalator_v-0.7_PL -> tool for installation image - Polish
- HDBOX_PKT_Ferrari_F1_Image.tar.gz -> main PKT image file
- howto_EN.pdf -> howto install EN
- howto_PL.pdf -> howto install PL
- loaders -> three different loaders - Multi Boot, USB Boot and USB Boot with installed HDD
- PKT.txt -> changelog PKT
- TDT.txt -> changelog TDT
POZOR! Nesprávnou inštaláciou neoficiálneho sw môžete poškodiť Váš prijímač
http://fotky.satpodpora.sk/HDBOX_PKT_Fe ... _Image.zip
Best regards,
Polish Kathi Team
Screeny:
- fix audio problem
- fix dvb subtitel
Changes PKT:
- update picons
- oscam by BP soon
Best regards,
Polish Kathi Team
mmirousek
Re: OCTAGON / HDBOX Enigma2 PKT Ferrari F1 Image
chápu to tak, že postupy pro AAF a HDF zde neplatí ?
Ja som sa do toho ešte nepustil - takže neviem
Subor ma priponu *.tar.gz , takze plati rovnaky postup ,ako na ostatne.
Prilozena je USB verzia , nic sa nemeni.
A je tam slovenčina
Newcs v interných čítačkách funguje / natiahol som 1,65 / ale cez prehliadač sa do neho nedostanem cez http://ipboxu:8081
Tiež má problém naformátovať môj USB HDD - AAF s tým nemal žiadny problém.
enconfig kôli našej diakritike EPG treba prekopírovať
obrazový výstup je veľmi slušný aj na SD
DVB titulky nejdú ako v AAF tak ani tu ale po aktivácii txt titulkov sa tvária ako DVB
Zatiaľ sa mi javí ako vydarená - uvidíme
Erzo
Tiez som stiahol NewCS 1.65, potom treba nieco nastavit alebo hned ma fungovat?
TV LCD LG 37LH5000, DM800 HD OEM, Octagon FS 1018 - HDD 160GB, Toroidal T55 (39,0°E + 28,2°E + 23,5°E + 19.2°E + 13,0°E + 9,0°E + 4,8°E + 0.8°W), Wireless USB - D-Link DWL-G122, Router - Linksys WRT160N, Router - Asus WL-500gP V2 - Oleg + Oscam
Stiahni k tomu newcs aj config
potrebuješ aj niečo čo spracuje DCW z karty - napr mgcamd / ja som dal kôli jednoduchosti 1,33 - k tomu tiež config
Nakoniec to musíš všetko spustiť v blue paneli
Modré tlačítko - emu manager - vyber mgcamd a zeleným naštartuj. Newcs internú čítačku naštartuješ s číslom 2
Potom reštartni celý box
mmirousek
jj, taky problém s USB diskem, už jsi na to přišel ?dempsey píše:Newcs v interných čítačkách funguje / natiahol som 1,65 / ale cez prehliadač sa do neho nedostanem cez http://ipboxu:8081
DVB titulky nejdú ako v AAF tak ani tu ale po aktivácii txt titulkov sa tvária ako DVB![]()
Diakritika je i s přehraným encoding.conf špatná ale jen jeden znak
myslím "š" nebo "ř", už nevím , mám to teď vyplé
jo a pořád se nemůžu domluvit s nahráváním a současným sledováním
jiného kanálu. Funguje to někomu ?
To som ešte nerozchodil - nemám tu separátny signál a cez loop to zrejme nejde.
S tým HDD to bolo nakoniec jednoduché. Nenaformátoval som ho síce v boxe ale mal somho sformátovaný na ext3 a stačilo ho len mountnúť ako
Modré tl.- Disk - Manager ( HDD......) a šípkou do prava zmeniť sda1 na sdb1 a mountnúť.
na spravne zobrazovanie diakritiky si musite zvolit cesky jazyk na menu .
bery2
Fungují čtečky na Skylink nebo Cslink v této verzi .Díky
Ano, ale veď sa o tom bavíme o pár príspevkov vyššie...
kao1
Nedarý sa mi rozchodit Skylink, nemáte niekto chuť napísať presný postup...dík
bery2
V každém případě musíš mít spojený HDBOX s internetem abys si stáhl Pluginy.Menu/Pluginy/zelené tlačítko/emu/ok/najdi soubory mgcamd_133 /ok/ a config_mgcamd /ok/ dále soubory newcs_1.65 /ok/ a config_newcs /ok/.Vše tlačítkem ok postupně nainstaluješ.Až tyto 4 soubory nainstaluješ vyjeď zpět do úvodní obrazovky a zmáčkni modré tlačítko /EMU/ok/Správce EMU/ok/ šipkou do prava a najdi mgcamd_133 a dej zelené tlačítko na aktivaci .Počkej až se ti v řádku objeví Aktivní CAM:mgcamd_133.Dále zmáčkni tl 2 a začne ti odpočet aktivace newcs.Až to proběhne napíše ti to Newcs internal active ,restartuj HDbox a musí ti to jít.
