web interface plugin
Stáhni Plugin.
monkus Slovakia
Příspěvek od monkus »
Extract all files from httpd.tar.gz . When You extract it You will have directory httpd, copy it by FTP to AzBox HD receiver in /EMU directory, so You will have /EMU/httpd . Give CHMOD permission 755 on this files : run.sh, mini_httpd and htpasswd.
Now enter in azscripts folder , and give CHMOD permission 755 to all files inside of /EMU/httpd/azscripts.
To start Web Interface , connect to You AzBox HD by telnet or ssh, enter inside of /EMU/httpd , and start Web Interface with command ./run.sh .
Now in Web browser, IE or Firefox type :
http://IP adress of Your AzBox ( e.g : http://192.168.1.12 )
Keep in mind that this is just beginning and Web IF will be developed continuosly
Thanks to joseba and DTI.ba
joberuc Slovakia
Re: web interface plugin
Příspěvek od joberuc »
Nova vylepsena verzia.
Podrobny navod:
rozbalit vsetky subory zo zipu pomocou ftp do adresara /EMU/httpd. Potom nastavit prava 755 na subory run.sh, mini_httpd and htpasswd.
Tiez treba nastavit prava 755 na vsetky subory v adresari /EMU/httpd/azscripts.
Start weboveho rozhrania pomocou telnettu alebo ssh, v adresari /EMU/httpd treba spustit skript ./run.sh
Editovat IP adresu v telnet.conf pre pouzitie weboveho telnet interfacu v adresari telnet.
Do weboveho prehliadaca treba zadat adresu Vasho AzBoxu.
Dakujeme My AzBox Teamu.
Naposledy upravil(a) dempsey dne 30 srp 2009, 23:29, celkem upraveno 1 x.
Důvod: screen
monkus Slovakia
nova verzia 1.4
Web Interface PHP by Kiovo v0.3
s pluginmi od monkusa :115:
What works:
full control via the web interface AZBOX Monkus Tools
Telnet through the Web interface screenshots of live TV
AZBOX info (CPU, Linux, Meme, Forestry, modules, partitions)
What does not work:
the number "0" (in the web interface problem with td210_ip_remote)
Live Streaming (TV AZBOX web interface yet)
Download Movies (Web server yet)
What should fuciona in future versions:
live TV via the web interface
Installation:
Unzip the folder "/ EMU" of AZBOX HD.
Attributes 755 in the file "httpd".
Using Tools HD Monkus in AZBOX adjust the settings.
Change in the folder: / EMU / httpd / include:
The file "ip.conf" Enter the IP address of deco
to use telnet via the web interface to change the folder / EMU / httpd / include:
- File "telnet.conf" Enter the IP address of deco
- By default, the active register by root with no password set the password so that useis or remove the pad to common password azbox
Web Interface Login:
Option 1 - via telnet:
path: cd / EMU / httpd
Start:. / Httpd
Option 2 - from the plugins directly to the command in the AZBOX
Option 3 - automatically when you start AZBOX
The automatic startup of the Web Interface could be activated or deactivated from toolbar web interface but first you have to install the Auto-Run.
Now we will install the Auto-Start, so that at boot automatically restart the webadmin AZ.
In your httpd really a file called: S80httpd
Send it to the folder: / DISK2/etc/start.d /
We went in: / DISK2/etc/start.d /
755 attributes to the file: S80httpd
We have installed the webadmin, you can reboot the AZ.
Latest version of PHP 0.3 changes:
- Live TV become final use
- Movie browser with Live View, where you installed VLC (please try)
- Remote control home page
- AZBOX Sysinfo
- Tools to test Monkus revised
- Almost Normal mode is stored
- Some small fixes
- Iperf in sysinfo (customer is necessary, but at the same time)
* Latest version of PHP 0.5
Changelog:
- A few bugs fixed.
- Movie Browser should now be revised to run bug-free.
- Movie Browser is now used for all the embedded media player VLC http://www.videolan.org/.
- Firmware ad on the home page including links to direct download the new firmware.
- Live TV completely (I hope that we will also prepare time soon).
- Toolbox for the configs from OpenXCAS expanded.
nemoznost vytvorit screen moze byt sposobena aj blokovanim aktivne pouzivaneho c-line v boxe.
<?php
$output = shell_exec ('/MMP/usr/bin/td210_ip_remote 127.0.0.1 S azscripts/_aux.scr sleep 1');
echo '<div align="center">';
echo '<div class="command">Send ' . $output . '</div>';
shell_exec ('/MMP/usr/bin/admin_control /EMU/httpd/screenshot/screenshot.png');
$screenshot = '<br><br><a href="../screenshot/screenshot.png" class=\"highslide\" onclick="return hs.expand(this)" target="_blank"><img src="../screenshot/screenshot.png" class="picture" border="1" alt="Screenshot"></img></a>';
echo $screenshot;
Web Interface v0.78 PHP Multilingual
Changelog:
- Version mit mehrsprachiger Unterstützung (Verzeichnis /lang).
- diese Version wurde komplett nach /MMP verlegt.
- Monkus Tools auf die Verzeichnisse /MMP/httpd und /PLUGINS umgebaut.
- alle configs liegen jetzt im Verzeichnis /configs und können bei einem Update behalten werden.
- Anzeigebug gefixt.
- weitere Buttons im Telnet Fenster hinzugefügt.
- Sprachen deutsch,englisch,holländisch,russisch
- Firmwareliste mit Download von HDBox.info.
- WI-Plugin mit dabei (nur für aktuelle Firmware 0.9.3501 oder spätere)
tear12
Příspěvek od tear12 »
Web Interface PHP 0.80
Zpět na „Pluginy“
