IncubusCamd
Stáhni Emu plugin.
IncubusCamd
IncubusCamd 0.92 for HD-Box9200 PVR
Tu prilozeny subor obsahuje potrebne subory pre instalaciu (kopirovanim cez Sambu,alebo ftp) incubuscamd 0.92 do hdboxu.
Pred instalaciou je nutne stopnut aktualne pouzivany emulator (Menu a modre )
Nainstalovat subory do predikovanych adresarov.
Atributy:
start.sh - 755
incubusCamd.sh4 - 755
tak isto je potrebne vytvorit vo /var/adresar /run/ - atribut 777
Restartovat prijimac tlacidlom Power na dialkovom !!
Spusta sa klasicky - Menu a cervene tlacitko na DO
Pre spolahlivu pracu na streamoch so simulcryptom (viac kodovacich systemov na jednom programe) , je nutne urcit prioritu CAID v subore incubusCamd.prio . Pozor na dodrziavanie medzier v config. suboroch !
testovane so serverom CCcam 2.1.2
Pristup na web rozhranie je cez port 668- teda : http://xxx.xxx.xx.x:668 (namiesto xxx.xxx.xx.x zadat skutocnu IP HDboxu)
Exkluzivne pre CZ/SK majitelov HD-box 9200 PVR . :)
ShaMan
Screen z www rozhraní Incubus
Příspěvek od ShaMan »
ShaMan
Incubus 0.94
incubusCamd, cam daemon.
Available for processor types: sh4 (tested only on Cuberevo family receivers)
Use the sh4_e2 version on cuberevo with enigma 1 or enigma 2 on board, the other version (*.sh4) on cuberevo with dgstation firmwares
Use the sigma version on azbox hd firmwares
Use the ppc version on dreambox with enigma 1 (or receivers like); for triple dragon and dgstation firmwares on ppc check
the config to know how to set the cam for those boxes
Use the mips version on dreambox with enigma 2 (or receivers like)
Card client for protocols: cccam, gbox, newcamd 5.20, newcamd 5.25, radegast old, radegast new, aroureos, camd 33, camd 35
Emulators for: Seca 1, Seca 2, Viaccess 1, Viaccess 2, Viaccess 2.3, Viaccess 2.4, Conax, Cryptoworks, Tps Crypt 1, Tps Crypt 2, Tps Crypt 3, Biss, Constant CW
.conf and .prio files can be inserted in the incubusCamd binary file directory, or in /var/bin directory, or in /etc, or in /var/keys
SoftCam.Key must be inserted in the /var/keys directory
.prio and SoftCam.Key file directories can be declared also in the .conf file
History:
04/11/2009, V0.94
- fixed bugs on EMM handling for various codifies
- fixed some memory bugs
- many other internal code improvements
- no more beta code used in teta version
Re: IncubusCamd
USB instalacka - plugin - Incubuscamd 0.95
adresar plugin pre instalaciu incubuscamd 0.95 . Vsetky potrebne subory su prilozene. Pozor - len pre fw verzie 1.07.74
Postup instalacie tu :arrow: http://www.forum.satdigitalne.cz/viewto ... 169&t=4139
Doporucujem pred zavedenim do prijimaca zvolit najskor Format user Data (zelene tlacitko) .
Pred instalaciou nezabudnite vypnut UNI citacku !
a trochu aj maly pokec:
web rozhranie je implicitne povolene . port 668
pristup:
http://xxx.xxx.xx.x:668 (namiesto xxx.xxx.xx.x si zadajte ipadresu HDboxu)
incubus zatial nevie emulovat nagra2 - ostatne public kodovacie systemy zvladne- preto je tam aj SoftCam.Key
vzdialene servery sa pridavaju do incubusCamd.conf - je vo /var/keys/
ja zdielam skylink a cslink z mojho ipboxu v protokole newcamd (v lokalke- takze vam to nepojde :) ) , takze tie dve linie si upravte - pre newcamd protokol.
dam sem priklad a vysvetlim aj co kde zapisat:
card_server_url=newcamd://standart5:standart5@192.168.1.8:10000:0D03:000000/0102030405060708091011121314/0
card_server_url=newcamd://meno:heslo@ip_adresa_serveru:port:CAID:PID/deskey/emm zapisy nepovolit (keby som chcel povolit-napisal by som EMM)
Mam dve citacky na servery, dve karty, preto aj dva riadky card_server_url=newcamd
Priklad pre vzdialeny CCcam server tam je tiez.
V subore incubusCamd.prio je ako preferovany provider 0D03, 0D0F, 0D20 (UPC) . Skylink modru som dal ako I: 0D70 - teda ignorovat to CAID.
Odskusane - funkcne.
Ked bude cas upravim aj spolu s newcs, aby vedel vlastnu kartu precitat.
Zpět na „Emu pluginy HD-BOX FS-9200-9300 PVR“
