fw 0.9.3180
tato
fw 0.9.3180
Objavil sa nový fw: http://www.islaremota.com/forum/downloa ... ile&id=666
zatiaľ bez skúseností, sťahujem
tato
tato
Re: 0.9.3180
Zdá sa, že pripojenie cez FTP klientov je v novom fw citlivé v hesle na malé a veľké písmená. RCC sa mi nepodarilo rozbehnúť, TCM, MAZ prípadne FileZilla Client po zmene hesla na malé písmená sa rozbehlo.
monkus
Re: 0.9.3180
OpenSAT is proud to present
AZBox HD Firmware - rev. 0.9.3180
(2009.08.23)
RELEASE NOTES
# FIXED
- CI can not support HD channel
- CI can not send the reply of ENQ
- Subtitles are transparent when menu is set to transparent
- Unicable is not working
- If playing recorded contents on movie player, recorded contents have no sound
- Can not add new SAT/TP on SAT/TP Editor
- Can not play with After recording
- If the channel has the subtitle language, which was selected on setting, subtitle
should be showed, automatically
# ADDED
- DVB-T/C NIT Search
- DTS decoding
- The menu of "Fixe Interlace on/off" on channel manager
For supporting the encoder, which may not respect the spec on this matter.
"When progressive_frame = 1 the picture is progressive, the two fields represent the
exact same time, and you should not see any comb effect when displaying the frame.
Moreover, when progressive_frame = 0, top_field_first is used to indicate which field
has to be displayed first."
- Satellite Nile Sat 101/102/Altantic Bird4 (7.0W) is missing in the satellite list
- Telefonica transponder on Amazonas(61.0W) is missing
- Always start in TV mode
- "Automatic Reboot Option" to Timer menu
# IMPROVED
- If you choose a movie from hard disk and in the same folder where the movie is stored
there is an .srt or something else the box loads subtile automatically ordered
by .smi/.srt/.txt.
Best Regards,
The OpenSAT/AZBox Team
(2009.08.23)
RELEASE NOTES
# FIXED
# ADDED
- DTS decoding
# IMPROVED
by .smi/.srt/.txt.
Best Regards,
monkus
monkus
tato
monkus
Re: 0.9.3180
mne si pamata nastavenie jazyka. Inac, uz pretaca nahrany zaznam z hdd smerom spat. Urobil som format area a novy fw nahral z usb.
tato
Re: 0.9.3180
Pamätá si nastavenie jazyka aj na jednotlivých kanáloch po vypnutí a opätovnom zapnutí azboxu ? Nie jazyk OSD.
Re: 0.9.3180
kurna, to trasenie obrazu v rezime pan and scan ostalo z 3177. Ale aspon opravili to radio.
Mas pravdu, nepamata si jazyk kanalu.
monkus
Re: 0.9.3180
toto su bugs z 3177, co som postol
bugs:
- switch program / channel via EPG will freeze azbox hd
- image viewer still has problems with image size and optimalization
- loading boot logo only after restart (for 1 sec), not after wake up
- some problems with TP 11797 (f.e. Discovery SD) - audio, video (see attached video)
- movie player (iso image with dvd menu not supported, language setting is forgotten)
- not using audio language settings in tv mode
- shaking picture in pan&scan mode
ostali nefixnute.
nove problemy som narychlo nespozoroval.
bugs:
ostali nefixnute.
monkus
Re: 0.9.3180
a este bugtracker. doporucujem precitat, nech zbytocne nepostujete problem s philips lcd a pod. :-)
http://www.myazbox.de/Wiki/index.php?title=Bugtracker
Naposledy upravil(a) monkus dne 25 srp 2009, 09:01, celkem upraveno 1 x.
merlin123
Re: 0.9.3180
skušal niekto "tovarenske nastavenie" pri zadavani hesla nejde prepnut čisla a pismena.
stale su tam čisla,ako zadam tovarko
