MaZ / správca súborov
Maz pozri. 1,0
Správca AzboxHD od Morse
- Zobrazenie fw, pluginov a addonov ktoré sú k dispozícii na serveri AzboxHD.es
- Telnet
- FTP
- Capture OSD (menu) z AzboxHD
- Úprava zoznamu kanálov. (V tejto chvíli môžeme len upraviť súbor all_channel.dat). Môžete stiahnuť a potom nahrať zoznamu prijímač, multi-kanálové mazání, mazanie satelitov kompletnú editáciu dát kanály, správa zoznamu obľúbených položiek, hľadanie kanálov, rôzne usporiadanie tohto zoznamu, atď. Kompatibilný s ver. 8 zoznamy kanálov a uvidíte. 9 z firmy 2880.
Díky Morse
preklad trochu pokrivený zo španielčiny
Diskusia k tejto utilite viewtopic.php?f=76&t=3706
- Telnet
- FTP
Díky Morse
Re: MaZ ver. 2.0 / správca súborov
MaZ see. 2.0
Manager for AzboxHD by Morser
- Added a button to telnet to the clipboard to copy the contents of text framed in the console window.
- Added the modification of satellites and transponders
- Ability to massive changes in satellites like putting selected satellites USALS motor mode or enable / disable the LNB feed.
- Ability to search our coordinates giving the name of our city or village.
- In the lists of favorites, if we try to add a channel that already, do not re-add.
- Added the copy to favorite channels or favorite lists complete and attach them to other lists (in the destination list must be the channel or did not stick).
- Added power also capture images from TV (no video, only static images)
- Added the creation and modification of reservations for recording
- Added a list of recorded programs with the ability to delete or download to your PC.
- Added multilanguage support (included with the Spanish, Portuguese, English, French, German, Italian and Serbo-Croatian)
Re: MaZ / správca súborov
Tady je MaZ s ceskym a slovenskym prekladem
AZ BOX HD Premium, HDD 2,5" 120GB,19,2+23,5
- Primo
Doprelozil jsem informace o skriptech do cestiny. Staci prepsat soubor scripts.ini novym prilozenym.
tu vam prikladam poslovenceny a rozsireny script,staci prepisat originalny subor,nie je prelozene vsetko komplet,ak niekto viete po spanielsky,tak skuste doprekladat ten zbytok. Ja som prelozil aspon to,co som vedel
AzBox HD Elite, DM 800HD, DM7000, DM500S, Skylink, CSlink, UPC
- Primo
Dokoncil jsem preklad rozsireneho souboru scripts.ini pro spravce souboru MAZ do cestiny. Puvodni soubor prepiste novym.
MaZ / správca súborov 2.1
- Opravená chyba v zozname rezervácií upraviť alebo zmazať záznam zdvojnásobil a odstrániť ďalšie posledný
- Opravená malá chyba v preklade z informácií, ktoré reset po nahraní zoznamu kanálov.
- predĺžený čas na vyhotovenie snímok na televízore HD (test).
- Teraz si môžete zvoliť zoznam kanálov HD alebo kódované
- pridaný Katalánsky jazyk a kórejsky
- Opravené rôzne chyby v modifikácii satelity
- pridaný výber možností pri výbere UB LNB iba, ako je to v AZBOX
- Boli odstránené zostali iba druhy LNB User Def, Universal, Unica a 10000/10445. Ak vyberiete Užívateľ def. nám umožňuje dať frekvenciu.
google prekladač zo španielčiny
MaZ v. 2.2
Manager for AzboxHD by morser
- Added button to go to Azbox only the recording reservation list
- Fixed bug - when choosing XP style did not look right on the button bar on reservation lists of recordings
- There was more time in the TV pictures of catches for catches in HD channels
- Fixed Bug - If we had duplicate channels resulted in an error when trying to delete.
- If ordered virtually the channel list by clicking on the column you want to order, we can again leave it in the actual order on any column by clicking the right mouse button.
- Added Russian language.
- Added some scripts (with permission from Platinum).
MaZ 2.3
Pre tých ktorí už MaZ v PC majú je jednoduchšia inštalácia s pripojeným internetom po spustení už nainštalovanej utility. Netreba totiž riešiť lokalizáciu do cz alebo sk jazyka
- schmegea
Opravena kompletní záloha na HDD
EMU nahrazeno PLUGINS
záloha programů změněna na celou složku DISK2 z důvodu zálohy i ostatních tunerů DVB-C či DVB-T
souborem nahradit původní soubor v adresáři MAZ
- Primo
Do skriptu pro program MaZ jsem pridal polozku pro testovani sitove karty a parametru site, viz prispevek vispera. Prilozeny soubor rozbalte a nakopirujte do instalacniho adresare MaZ.
- schmegea
Taky jsem něco přidal do scriptů,
Kompletní záloha a záloha EMU pro využití boxu bez HDD (nemám vyzkoušeno), je tam příkaz s kopií na HDD což může hodit chybu u boxu bez HDD, ale záloha je vytvořena v adresáři tmp + kopie na HDD.
Před nahráním nového FW a provedením format aplication area si je třeba vždy soubory se zálohou u boxů bez HDD zazálohovat do PC a po instalaci FW vrátit.
Aktivace swap od monkuse a zobrazení času na displeji boxu
test sítě od prima samozřejmě ponecháno
Moje čeština do MaZ 2.3.0.0
Panasonic TX-P42S10E-ES v.1.216,Coolstream Trinity HD2 V.2.13 RC1 ,AZBox HD RTi_Core_1.6.0,GIGABLUE HD800 Solo OpenMIPS_zde2-3.0
MaZ 3.0
frcko73
Slabsi preklad MAZ 3.0.0 do SK.
Prepisat a nahradit povodny eng.lng.Blbe Pripomienky si nechajte.Komu sa nepaci,nech netaha.
