USB CITACKA
USB CITACKA
Zdravím
Mam velky problem
Pokusam sa uz treti den rozbehnut USB CITACKU kariet a stale nic
Mam doma vu+ solo se2 a SMARTMOUSE/ Easymouse 2 USB PREMIUM
absolutne sa ju nedari nacitat skusal som aj doscam z autokonfig a aj akykolvek oscam cez mipsel arm cortex a stale nic
hlavna pricina je v tomto
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Flush readed byte Nr 2 value 00 time_us 1865
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Flush readed byte Nr 3 value 8f time_us 858
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Flush readed byte Nr 4 value 84 time_us 1095
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Flush readed byte Nr 5 value f3 time_us 1633
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Flush readed byte Nr 6 value 01 time_us 998
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Buffers readed 6 bytes total time_us 99897
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Buffers readed 0 bytes total time_us 75168
2017/01/31 18:58:43 19CDC261 r (reader) skylink [mouse] Reader initialized (device=/dev/ttyUSB0, detect=cd, mhz=600, cardmhz=600)
2017/01/31 18:58:44 19CDC261 r (reader) skylink [mouse] card detected
2017/01/31 18:58:44 19CDC261 r (reader) skylink [mouse] Buffers readed 0 bytes total time_us 75165
2017/01/31 18:58:45 19CDC261 r (reader) skylink [mouse] ATR: FF 2E 00 8F 84 F3
2017/01/31 18:58:45 19CDC261 r (reader) skylink [mouse] ERROR: Could not read reader->convention
2017/01/31 18:58:45 19CDC261 r (reader) skylink [mouse] Error activating card.
2017/01/31 18:58:45 19CDC261 r (reader) skylink [mouse] Buffers readed 0 bytes total time_us 75162
2017/01/31 18:58:47 19CDC261 r (reader) skylink [mouse] ATR: FF 2E 00 0F 00 F3
2017/01/31 18:58:47 19CDC261 r (reader) skylink [mouse] ERROR: Could not read reader->convention
2017/01/31 18:58:47 19CDC261 r (reader) skylink [mouse] Error activating card.
Dík za rady
Mam velky problem
Dík za rady
Re: USB CITACKA
Karta je? [reader] vypadá jak?
že by
protocol = mouse
Jak máš nastavené piny na tě čtečce.
že by
protocol = mouse
Re: USB CITACKA
[reader]
label = skylink
protocol = mouse menil som rozne nepomohlo
device = /dev/ttyUSB0
caid = 0D96 daval som aj IRDETO a ktomu aj RSA key nepomohlo
detect = cd daval som aj none nepomohlo
mhz = 600 menil som nepomohlo
cardmhz = 600 menil som nepomohlo
group = 2
Doplnene som nejako zabudol
pin je na 5 V dalsi pin smartmouse a pin je na 6 mhz a menil som rozne Nepomohlo
label = skylink
group = 2
efendy55
Re: USB CITACKA
[reader]
label = Skylink
protocol = mouse
detect = cd
mhz = 800
group = 1
emmcache = 0,1,3,2
ak ti to pomôže tak ja to mám takto , ale na maline ...
label = Skylink
protocol = mouse
detect = cd
mhz = 800
group = 1
emmcache = 0,1,3,2
Všetko4K,Linux E2
Re: USB CITACKA
nepomohlo
2017/01/31 21:02:44 014D9FA5 r (reader) skylink [mouse] Buffers readed 0 bytes total time_us 75156
2017/01/31 21:02:46 014D9FA5 r (reader) skylink [mouse] ATR: FD 26 08 0F 04 F3
2017/01/31 21:02:46 014D9FA5 r (reader) skylink [mouse] ERROR: Could not read reader->convention
2017/01/31 21:02:46 014D9FA5 r (reader) skylink [mouse] Error activating card.
2017/01/31 21:02:46 014D9FA5 r (reader) skylink [mouse] Buffers readed 0 bytes total time_us 75160
2017/01/31 21:02:47 014D9FA5 r (reader) skylink [mouse] ATR: FD 2E 00 0F 84 73
2017/01/31 21:02:47 014D9FA5 r (reader) skylink [mouse] ERROR: Could not read reader->convention
2017/01/31 21:02:47 014D9FA5 r (reader) skylink [mouse] Error activating card.
2017/01/31 21:02:48 014D9FA5 r (reader) skylink [mouse] Buffers readed 0 bytes total time_us 75164
2017/01/31 21:02:49 014D9FA5 r (reader) skylink [mouse] ATR: FF 2E 00 0F 04 F3
2017/01/31 21:02:49 014D9FA5 r (reader) skylink [mouse] ERROR: Could not read reader->convention
2017/01/31 21:02:49 014D9FA5 r (reader) skylink [mouse] Error activating card.
2017/01/31 21:02:49 014D9FA5 r (reader) skylink [mouse] THIS WAS A FAILED START ATTEMPT No 1 out of max alloted of 1
2017/01/31 21:02:49 014D9FA5 r (reader) skylink [mouse] card initializing error
Re: USB CITACKA
Zkus přepnout na phoenix .
Re: USB CITACKA
Při přepínání je potřeba restart celého vuučka. Začni tím dej nejnižší 357 a zkus. Už jsem se setkal že byl prostě vadný crystal a nešel ani za boha.
Re: USB CITACKA
Idem na toThomik1 píše:Při přepínání je potřeba restart celého vuučka. Začni tím dej nejnižší 357 a zkus. Už jsem se setkal že byl prostě vadný crystal a nešel ani za boha.
ale to som už skušal X krát
ešte raz to prebehnem
kurňa na prvý šup a koľké hodiny som s tým strávil
Re: USB CITACKA
Len je sranda že keď jej pridám MHZ tak už nejde a ani smartmouse nejde
asi s nou nieco bude na prd
Re: USB CITACKA
Stane se , ono by se to nemělo přepínat za chodu. Krystal odejde do věčných lovišt.
efendy55
Re: USB CITACKA
Thomik1 vidím že máš v popise DM520-usbdvttuner . aký tam používaš s akým chipom a image ???
Všetko4K,Linux E2
Re: USB CITACKA
Funguje mi HD DVB-T USB tuner EVOLVEO Mars , jenže mám ho asi 4 roky a má starší čip. Marsim má ten samý s novým a nefunguje mu. Na atv , pli v pohodě hraje. Takže si to přeber.
efendy55
Re: USB CITACKA
vdaka , takže máš asi s chipom 9015 , ja mám s 9135 .
tiež som ho skúšal v decembri v openatv , vidieť ho videl , ale nič nešlo . skúšal som tam aj iné typy , ale tiež boli OFF . ale už je v predaji aj COMBO ...
Všetko4K,Linux E2
Re: USB CITACKA
Nahrávám tam ovladač pro 9135 nic víc, ale jak píšu starý chip i když číslem stejný.
