Ahojte po pokuse o opravu azboxu v bootinku mi vypisalo na konci toto:
* YAMON ROM Monitor
* Revision 02.06-SIGMADESIGNS-01-2.8.0.1
Memory: code: 0x11000000-0x11040000, 0x11200000-0x11204000
reserved data: 0x11240000-0x12440000, PCI memory: 0x12440000-0x12840000
Environment variable 'start' exists. After 1 seconds
it will be interpreted as a YAMON command and executed.
Press Ctrl-C (or do BREAK) to bypass this.
ROMFS found at 0xac080000, Volume name = MIPS_LINUX_XRPC
ac080040 : Name = ., Type = dir, Size = 00000000, Next = 00000040
ac080060 : Name = .., Type = hard link, Size = 00000000, Next = 00000060
ac080090 : Name = xrpc_xload_vmlinux_ES4_prod.bin, Type = file, Size = 0064bf44, Next = 00000000
Checking zboot signature.. it's not zboot file.
Error : Internal, code = ffffffff
Neviem sa cez to preniest cely proces prebehol ok az na tento vystup vedel by mi niekto pomoct?
Chybova hlaska pri oprave AZBOX elite
Rady a návody
Re: Chybova hlaska pri oprave AZBOX elite
Problem je v subore backup_kernel treba tam dat backup_kernel_344, ktory sa pouziva, ak bola v boxe nainstalovana Enigma 2, subor je sucastou opravneho balika http://uloz.to/xdj8FMAr/recovery-azbox-zip
Zpět na „AZ HD rady a návody E2“
