OpenAZBox PLi MOD Images
Odkaz na stažení Firmware (Enigma2) a Diskuze k dané Images E2.
gorick
Dal poděkování: 3 poděkování
OpenAZBox PLi MOD Me Release 1
Příspěvek od gorick »
Kernel: Linux azboxme 3.5.5 (multiboot s OpenRSi 3.0 a AZtrino 2 RC3)
Enigma 2: 15. november 2012
What is new:
- Fixed khdmi issues on all models
- Fixed i2c issues on all models
- Fixed "tune" problems on Ultra and Premium+
- Fixed blindscan in Premium+, Ultra, Me and MiniMe
- SPDIF Enabled
- Added AC3/DTS downmix Yes/No switch in A/V Settings (all models)
- Fix and additions in AZPlay:
Add scalling, audio lang. sel
Add subtitle lang. sel, set volume/mute after switching
Increase font size to max 90
change way to show parameters in setup menu - now all is sorted
STOP command now completly close player and jump to filelist
Fix BUG - show prev. subtitle if you use more then one video
Add : mts extension, ac3 extension, change value from setup menu in real time
Fix BUG - Green screan , when you doenst setup tuners
Fix problem with changing parameters (fix in rmfp_player)
Add - show infobar when play ts , mts, ac3 files - without time info/index
Download: :arrow: Tu stiahni-usb :arrow: Tu stiahni-webif
gorick
OpenAZBox PLi MOD Me Release 2
This is special New Year edition for all AZBox users from OpenAZBox (RTi team) team.
Kernel 3.3.1 - 31.12.2012
Fixed:
1. S-ATA problems for AZBox Me fixed
2. e-SATA problems fixed (Thx to the_ripper)
3. Problems with EXT4 FS under Kernel 3.5.5 (Thx to the_ripper)
4. Several driver issues on 865xdvb.ko fixed
5. With new kernel initramfs webinterface flash is fixed (Thx to the_ripper)
6. Fixed remembering of settings for video interlace/deinterlace when entering and exiting from AZPlay
7. fix memory em8xxx mrua leak when eixiting azplayer (Thx to the_ripper)
Edit: oprava AZplay
For ALL Who have problem with AZPlay pls copy attached file :'libcurl.so.4' in folder /usr/lib/
http://www.mediafire.com/?dak4xiaf0a3zyei
gorick
OpenAZBox PLi MOD Me Release 3
Kernel of 9. January 2013
Drivers of 6. January 2013
Enigma 2 of 9. January 2013
What is new:
- Added support for USB DVB Tuners - vTuner support (Satellite, Terrestrial, Cable)
- Back to old Video out API
- Fixed de-interlace remember option when exit from AZPlay
- Fixed scaling
- Fixed flashing trough Web Interface (added to new initramfs)
- Fixed problem with AZPlay playback (libcurl.so.4 was missing)
Download driver support for your USB DVB Tuners directly from Menu -> Plugins -> Press Green button for Download
Download: :arrow: Tu stahni
gorick
Re: OpenAZBox PLi MOD Images
OpenAZBox PLi MOD Me Release 4
Kernel 3.3.1 of 17. January 2013
Drivers of 17. January 2013
Enigma 2 of 17. January 2013
What is new:
- Added ALSA support inside of 865xdvb.ko (all ALSA dependent plugins are working now e.g AirPlay, OpenAirPlay etc.)
- Added support for ftdi_sio ( Menu -> Plugins -> Press Green button for download -> Drivers ) or by telnet ( opkg install kernel-module-ftdi-sio )
- Fixed RAW/PCM settings
- And all fixes from previous online update.
:arrow: Tu stiahni
gorick
OpenAZBox PLi MOD Me Release 5
Drivers of 24. January 2013
Enigma 2 of 24. January 2013
What's new:
- Fixed DVB USB vTuner interface (Scanning and watching should work OK now for all non-Sundte devices too)
- Few more fixes on main driver
- Added UPnP support in AZPlay
:arrow: Tu stiahni
gorick
OpenAZBox PLi MOD Me Release 6
Drivers of 1. March 2013
Enigma 2 of 4. March 2013
What's new:
- Reworked IR code for better performance with RCU
- Fixed issue with STB when in standby and when streaming is started, so no more kernel panic or crash
- Added patch for SATA bug (mbus turned off now, as user reported with that is working more stable)
- Enhanced SatScan (Blindscan) plugin for better pefrormance
:arrow: Tu stiahni
gorick
OpenAZBox PLi MOD Me Release 7
Drivers of 15. March 2013
Enigma 2 of 15. March 2013
Kernel 3.3.1 of 15. March 2013
What's new:
- New rebuilt Kernel + Initramfs (You must flash image0.jffs2 + kernel!!!)
- Fixed Fast Forward FFWD in Enigma 2 Media Player
- Fixed Strange behaviour of RCU (added better protection for non mapped keys, let's see if user will again have some non valid message from MICOM)
- Fixed Tune Failed on DVB-T USB Sticks (We Need test for Sundtek)
:arrow: Tu stiahni
NOTE:
Please keep in mind that YOU MUST FLASH NEW KERNEL WITH NEW IMAGE! This image must be fully flashed, and is not possible to make online update from Release 6, only full and clean flash of Release 7!
Zpět na „AzBox Me Odkaz na Firmware (Enigma2)“
