Výpis z Microsoft Security Essentials:
Položky:
file:\\AZBOXHD\Configuration\cache\ldconfig\ldconfig.exe
file:\\AZBOXHD\Configuration\etc\avahi\avahi.exe
file:\\AZBOXHD\Configuration\etc\avahi\etc\etc.exe
file:\\AZBOXHD\Configuration\etc\avahi\services\services.exe
file:\\AZBOXHD\Configuration\etc\cron\cron.exe
file:\\AZBOXHD\Configuration\etc\cron\crontabs\crontabs.exe
file:\\AZBOXHD\Configuration\etc\cron\scripts\scripts.exe
file:\\AZBOXHD\Configuration\etc\dbus-1\dbus-1.exe
file:\\AZBOXHD\Configuration\etc\dbus-1\system.d\system.d`.exe
file:\\AZBOXHD\Configuration\etc\default\default.exe
file:\\AZBOXHD\Configuration\etc\dropbear\dropbear.exe
file:\\AZBOXHD\Configuration\etc\enigma2\enigma2.exe
file:\\AZBOXHD\Configuration\etc\etc.exe
file:\\AZBOXHD\Configuration\etc\init.d\init.d`.exe
file:\\AZBOXHD\Configuration\etc\ipkg\ipkg.exe
file:\\AZBOXHD\Configuration\etc\ipkg\opkg.exe
file:\\AZBOXHD\Configuration\etc\joe\charmaps\charmaps.exe
file:\\AZBOXHD\Configuration\etc\joe\joe.exe
file:\\AZBOXHD\Configuration\etc\joe\syntax\syntax.exe
file:\\AZBOXHD\Configuration\etc\modutils\modutils.exe
file:\\AZBOXHD\Configuration\etc\MultiQuickButton\MultiQuickButton.exe
file:\\AZBOXHD\Configuration\etc\network\if-down.d\if-down.d`.exe
file:\\AZBOXHD\Configuration\etc\network\if-post-down.d\if-post-down.d`.exe
file:\\AZBOXHD\Configuration\etc\network\if-pre-up.d\if-pre-up.d`.exe
file:\\AZBOXHD\Configuration\etc\network\if-up.d\if-up.d`.exe
file:\\AZBOXHD\Configuration\etc\network\network.exe
file:\\AZBOXHD\Configuration\etc\opkg\ipkg.exe
file:\\AZBOXHD\Configuration\etc\opkg\opkg.exe
file:\\AZBOXHD\Configuration\etc\ppp\ip-down.d\ip-down.d`.exe
file:\\AZBOXHD\Configuration\etc\ppp\ip-up.d\ip-up.d`.exe
file:\\AZBOXHD\Configuration\etc\ppp\ppp.exe
file:\\AZBOXHD\Configuration\etc\rc.d\init.d\init.d`.exe
file:\\AZBOXHD\Configuration\etc\rc0.d\rc0.d`.exe
file:\\AZBOXHD\Configuration\etc\rc1.d\rc1.d`.exe
file:\\AZBOXHD\Configuration\etc\rc2.d\rc2.d`.exe
file:\\AZBOXHD\Configuration\etc\rc3.d\rc3.d`.exe
file:\\AZBOXHD\Configuration\etc\rc4.d\rc4.d`.exe
file:\\AZBOXHD\Configuration\etc\rc5.d\rc5.d`.exe
file:\\AZBOXHD\Configuration\etc\rc6.d\rc6.d`.exe
file:\\AZBOXHD\Configuration\etc\rcS.d\rcS.d`.exe
file:\\AZBOXHD\Configuration\etc\samba\private\private.exe
file:\\AZBOXHD\Configuration\etc\samba\samba.exe
file:\\AZBOXHD\Configuration\etc\skel\skel.exe
file:\\AZBOXHD\Configuration\etc\terminfo\a\a.exe
file:\\AZBOXHD\Configuration\etc\terminfo\d\d.exe
file:\\AZBOXHD\Configuration\etc\terminfo\l\l.exe
file:\\AZBOXHD\Configuration\etc\terminfo\r\r.exe
file:\\AZBOXHD\Configuration\etc\terminfo\s\s.exe
file:\\AZBOXHD\Configuration\etc\terminfo\x\x.exe
file:\\AZBOXHD\Configuration\etc\tuxbox\config\config.exe
file:\\AZBOXHD\Configuration\etc\tuxtxt\tuxtxt.exe
file:\\AZBOXHD\Configuration\etc\udev\rules.d\rules.d`.exe
file:\\AZBOXHD\Configuration\etc\udev\scripts\scripts.exe
file:\\AZBOXHD\Configuration\etc\udev\udev.exe
file:\\AZBOXHD\Configuration\etc\udhcpc.d\udhcpc.d`.exe
file:\\AZBOXHD\Configuration\etc\Wireless\RT2870STA\RT2870STA.exe
file:\\AZBOXHD\Configuration\etc\wpa_supplicant\wpa_supplicant.exe
file:\\AZBOXHD\Configuration\lib\dbus\dbus.exe
file:\\AZBOXHD\Configuration\lock\lock.exe
file:\\AZBOXHD\Configuration\log\log.exe
file:\\AZBOXHD\Configuration\run\autofs\autofs.exe
file:\\AZBOXHD\Configuration\run\avahi-daemon\avahi-daemon.exe
file:\\AZBOXHD\Configuration\run\dbus\dbus.exe
file:\\AZBOXHD\Configuration\run\run.exe
file:\\AZBOXHD\Configuration\scce\scce.exe
file:\\AZBOXHD\Configuration\tmp\tmp.exe
file:\\AZBOXHD\Configuration\tuxbox\config\config.exe
 a jak tomu zabránit aby se to nestalo znova.
