-len pre skusenych uzivatelov!
-test v image AAF OK.
mode employs
to install this version to do that, you Munice a usb virgin at least 2 gb or already formatted, but the data will be erased for a hard drive it could focus completely erased the same for an external hard Dique , and have an image "openplie" flash
minimum of 2.6.31, but recommended a 3.2.2, kernel 2.6.18-7.4 is not supported
ipkg install / tmp / * bariet. ipk
once installed, download and unzip the pictures and images that kept "rootfs.bin" and renamed eg "plie.nfi", watch the renamed file extension should always have nfi if it does not work and the transfer by ftp in the directory "MB_Images", the extraction can take 15 minutes do not worry if its fair at worst it's because of the ram, in case you need to install a swap and after it work
ie you can also use the ftp client for dcc installed images, not tried all the options that have nothing to do with our demo, make a backup type nfi it does not, by cons you can make backups bz2
