Nxtrend - Android Streaming and Remote Control App for Xtrend-series
Android Streaming and Remote Control App for Xtrend-series, including
Favourites,
Channel lists,
Timer-Management,
EPG,
Movies/Recordings,
Virtual Remote Control,
Power Commands (Standby, Shut Down…..),
Multiple Decoder-Profiles,
Twin-tuner support,
Streaming (TV and Movies) *,
Auto-detection (LAN or Remote),
Compatible with E2 and E1(**)
and other features
With Nxtrend you can control your decoder using its Virtual Remote Control, you can set a timer while travelling on a train, you can read Channel-EPG without being in front of the TV, you can watch TV-programmes and your recorded movies in streaming and much more…..
* Streaming requires a well functioning WIFI-system in your LAN. Android-device must be rather powerful but most devices sold in recent times are powerful enough ( > CPU 800 MHz should be sufficient)
** E1-support: Favourites, Channel lists, EPG, Power Commands, Streaming (TV), Virtual Remote Control
!! Free to download from Google play (former Android Market) !!
Nxtrend - Android Streaming and RC
Pluginy a utility pro přijímač Clarke-Tech , Xtrend
vikino
vikino
Re: Nxtrend - Android Streaming and RC
Nxtrend Android App (Ver. 1.4 - March 25, 2012)
Nxtrend v. 1.4 has just been published on Google Play (former Android Market).
Nxtrend is also available at SlideME (alternative App-Market).
Here is the link: h*tp://slideme.org/application/nxtrend
Ps: Remember there is now a FAQ-section available here in the forum covering most common questions along with useful information.
change-log (25/03/2012 - Nxtrend 1.4):
-Reviewed first-time configuration. Should fix sporadic cases when detection of et/ct-receiver was not successful
-Fixed streaming of movies/recordings when authentication of OpenWebIf is enabled.
change-log (23/03/2012 - Nxtrend 1.3):
-fixed scaling-issue in movielist (effected only certain resolutions)
-added support for sending Messages (you can now send messages to your decoder)
change-log (12/03/2012 - Nxtrend 1.2):
-Removed filter in IP-Address field which did not permit inputting the dot(period)-character on some devices and their keyboards and/or third-party keyboards
-Code-review of first-time configuration (not recognizing some ct/et-decoders). Hopefully fixed.
Installation-tips:
1) make sure you are using latest version of Nxtrend which you can download from Google Play (Android Market) or from SlideME (alternative app-store).
2) make sure you are connected to your LAN (using WIFI and not 3G).
3) for fist-time installation, Nxtrend will prompt you to add an Xtrend/CT-decoder and the settings-screen will open.
4) if you are using original WebIf and you have SSL (Https) enabled, then disable it (Nxtrend does not support SSL yet).
5) make sure ip-address, port-number (and password if it is enabled) are correct. DynDNS is not required to run Nxtrend unless you want to use Nxtrend remotely.
Google traslator:
Inštalácia-tipy:
1) uistite sa, že používate najnovšiu verziu Nxtrend ktorý si môžete stiahnuť z Google Android Market LIVE) alebo z Slide (alternatívne app-store).
2) skontrolujte, či ste pripojení k sieti LAN (pomocou WIFI a nie 3G).
3) pre päste-time inštaláciu, Nxtrend vás vyzve na pridanie Xtrend / CT-dekodér a nastavenie obrazovky sa otvorí.
4) Ak používate originálne WebIf a vy budete musieť SSL (https) povolená, potom vypnúť ods Nxtrend nepodporuje SSL zatiaľ).
5) uistite sa, že ip-adresa, port, číslo (a heslo, ak je povolené) sú správne. DynDNS nie je nutné spustiť Nxtrend, ak chcete použiť Nxtrend vzdialene.
Installation-tips:
Google traslator:
Inštalácia-tipy:
vikino
App Nxtrend bola z Google play stiahnuta - odstranena.
Pre nase Clarky a Xtrendy sa da uspesne pouzivat prepracovana app pre VU+:
VU+ player: https://play.google.com/store/apps/deta ... ayer&hl=sk
Stiahnete zdarma priamo vo svojom android mobilnom telefone v Google play.
Zpět na „Clarke-Tech , Xtrend Pluginy a utility“
