Dbox2 1.3
20.10.2011
What is new:
- Remote control
- EPG and channel change I've now put together: At the "Press" of the channel name / channel logo now appears the EPG, the "pressures" on the TV icon on the right side of the screen is switched
- Shift-programmable timer from EPG info out
- Distinction between optical absorption and Shift-timer
IMPORTANT:
According yjogol is in SVN Rev 1686 Coolstream a common mistake, so reading the timer on nhttpd does not work, which consequently also affects my app. This bug should be fixed with SVN Rev 1703 again.
Neutrino Remote Control 1.3
Pluginy a utility pro přijímače Coolstream ZEE, NEO a Twin.
- dempsey
Re: Neutrino Remote Control na Google play
Pre majiteľov androidov je dostupný aj pre Neutrino HD
- dempsey
Cool.Tv
Ten istý maňoš urobil podobnú aplikáciu
https://play.google.com/store/apps/deta ... oltv&hl=sk
Zpět na „Coolstream ZEE, NEO a Twin - Pluginy a utility“
