fw 2.09.61
Odkaz na stažení firmware a diskuze k aktuálnímu firmware.
fw 2.09.61
HD BOX.FS9105HD v2.09.61
Ver 2.09.61 (r6236)
[ Major ]
1. DLNA, Server Upgrade function and CI+ will be reflected on next official release.
2. Possible to release earlier if CI+ CAM initializing issue solved.
[ WebZeal ]
1. Remote key Fast Backward & Fast Forward - changed to previous & next page moving key
2. Page moving to previous and next by Remote
3. Croatian(qwertz), Turkish(qwerty, q type) special characters input : fixed ( root file update necessary)
4. please use new version of WebZeal(v2.04).
[ Common ]
1. Hot Bird TP : updated
2. All : Arabic menu language : revised
3. Plugin menu : Firmware download menu : removed
[ 9000 (v1.09.xx) ]
1. NTFS file system : improved
2. FS 9000 Hang up issue : fixed
[ 8000 & 7000 (v2.09.xx) ]
1. 3G Modem : added
2. 3G modem disconnected not disappeared : solved
3. 3G modem new brand : added (Auto list)
[ Buyer issues ] : solved
1. Special character (U,A,O,etc) not display on front panel
2. Kathrein Unicable not working on all TP
3. specified channels continuous Short Freezing
4. GoldMaster : Hang up after deleting all list in Service List Manager
5. Wi-Fi password character input error fixed
6. All : French OSD menu language improved
[ FreeTV+ ] : solved
1. Hang up when more than 8 kinds of addon installed (upto 28)
2. Hang up when service moving after You Tube running
3. Parental rock issue
4. Live is not serviced when other file playback after pause
5. Only Audio comes with Divx file which was working properly
6. Wrong Audio language comes out
7. First Free TV+ contents not displaying properly
8. Fashion TV addon updated (v1.02)
9. Hang up when Divx file play
:arrow: Tu klikni pre stiahnutie
Upozornenie ! Dvojkova verzia sw !. Kto ma v boxe staru verziu 1.0x.xx - pozri sem :arrow:
Dôležite!
dempsey
Re: fw 2.09.61
Příspěvek od dempsey »
Prvá vec ktorú som si všimol je fakt že konečne funguje zobrazenie stavu share pod tlačítkom nula.
Už sa nezobrazí len prázdna lišta - dá sa meniť prio list v Xcame :-)
/ používam Xcam z 1.9.2011 /
jarynn92
Re: fw 2.09.61
Příspěvek od jarynn92 »
nefunguje posuv filmu rycleji,u předešlého FW 2.09.49 to šlo.mate stejny problem?
garett
Re: fw 2.09.61
Příspěvek od garett »
Ott služby hlásia chybu sietoveho pripojenia. Nejde you tube ani iné služby sieť mám pritom pripojenu správne. Verzia .49 sa správa ok. Aj vám to blbne?
style78
Re: fw 2.09.61
Příspěvek od style78 »
Posun filmov aj FreeTV+ ide uplne bez problemov.
Skus po nainstalovani FW pouzit tovarenske nastavenia a potom nastavit box rucne a stiahnut si iba zoznam kanalov.
skala
Re: fw 2.09.61
Příspěvek od skala »
Me zae s tim finfarem jsem mel problem pri sledovani kanalu ze mi to k CSlink/skylink/UPC CZ/SK zakladni nabidce vsem kanalu priradil ze to je HD a pak jsem to musel prepisovat pres editor nazpet ze to nei HD kanal a po nahrani settingu mi to vypsalo to same. Ani restart ani tovarni nastaveni vymazani vsechn TP nepomohlo. Tak jsem to downgradoval a pak vse OK.
garett
Re: fw 2.09.61
Skúsil som postupovať podľa odporúčania s továrenským nastavením, ale nič nepomohlo. Pri You tube a ostat. službách stále vyskočí chybové hlásenie "Skontrolujte sieťové nastavenia" a potom FreeTV padne a naskočí tuner s aktulnym tv programom. Sieť funkuje OK lebo webzeal ide normálne. tiež síce najskôr napíše sieť nie je aktívna, ale potom nabehne a dá sa surfovať. pluginy sa taktiež dajú stiahnuť zo siete, takže pripojenie mám štandardné ako pri nižšej verzii, kde sa tento problém nevyskytoval. Inak používam Wifi dongle TP-link s čipsetom Ralink. Opakujem že pri predposlednej verzii fw išlo všetko ako hodinky.
alftech
Subtitulky
Příspěvek od alftech »
Nefunguji subtitles, muzete overit, potvrdit vyvratit?
maiden
Re: fw 2.09.61
Příspěvek od maiden »
Pre garret: V sobotu som mal možnosť testovať tento prístroj a zistil som, že FreeTv mi išlo iba keď som sa pripojil cez LAN. Mám aj wifi, ale výsledok bol ten istý, ako u teba.
HD Box 9100, DM500s,Samsung 40LE650, 23,5E, 19,2E, 13E, 1W
karel631
Re: fw 2.09.61
Příspěvek od karel631 »
Mě jede všechno OK. Pokud se stane někomu, že mu po upgradu firmwaru FreeTV nejde, je jenom nutné vypnout a zapnout přijímač a pak všechny programy jedou bez problémů.
garett
Re: fw 2.09.61
problém je v tom, že ja som samozrejme prijímač vypol aj zapol x-krát aj vzadu aj cez DO a nič stále ta istá hláška "chyba sieťového pripojenia" LAN kábel sa mi do prijímača ťahať nechce lebo router mám v inej izbe.
profikx
Re: fw 2.09.61
Příspěvek od profikx »
Nazdar
Aktualizoval som firmware z 1.09.35 na > 1.09.99 potom na > 2.09.49 a prestalo mi ist Youtube. Namiesto toho tam mam OTT- sluzby - videoklipy . Ked to spustim tak mi zamrzne prijmac a musim ho vypnut zo siete.
Najnovsi firmware 2.09.61 je ten isty problem. Ako to rozbehat ? Web zeal mi ide
style78
Re: fw 2.09.61
Este jeden postreh z FW 2.09.61 okrem toho, ze vypisuje HD na SD programoch.
Skusal som zmazat cely adresar aj so subormi cez HDBox priamo (konkretne to bol adresar v ktorom bol Divx + titulky) a box sa restartol a ostal vysiet s napisom L6.20 na displey. Pomohol az restart vypinacom.
Ma niekto rovnaku skusenost, ci som zrely na pouzitie tej FlashV6 mediciny? :D
Re: fw 2.09.61
2.09.61 nevie korektne mazat data na usb disku .
Zpět na „Odkaz na firmware a diskuze k firmware - HD-BOX FS-9105 PVR“
