As a reminder this plugin is for those who have no amp to decode the DTS by the optical output.
This plugin allows the ON or OFF according to the DTS.
Why ON / OFF?
The libraries of this plugin allows decoding of DTS but do not allow the decoding of another sound source.
So if you need to play any other format, setting off allows a return to original mode of the demodulator.
I realized and tested this plugin on image for my Open ET9000-fold.
When you enable DTS and you cast a movie.
It may be that the first few seconds there have not sound.
A simple press the button 3 on the remote control will correct that.
DTS Plugin
Pluginy a utility pro přijímač Clarke-Tech , Xtrend
vikino
DTS Plugin
DTS Plugin
Zpět na „Clarke-Tech , Xtrend Pluginy a utility“
