Project Valerie
Pluginy a utility E2
vikino Ukraine
Dal poděkování: 9 poděkování
Project Valerie
Příspěvek od vikino »
Project Valerie
The aim of project valerie is to create an easy to use full feature media center for all enigma2 based set top boxes.
The main improvement to a standard enigma2 installation is that instead of being multimedia support just a nice re on the side, in Project Valerie multimedia support is the key feature.
webside:
http://code.google.com/p/project-valerie/
Download:
http://code.google.com/p/project-valerie/downloads/list
How to Install project-valerie_rev473_mipsel_oe16.ipk :
Put file project-valerie_rev473_mipsel_oe16.ipk bu FTP in /tmp
Connect by telnet on AzBox and execute this command :
cd /tmp
opkg install project-valerie_rev473_mipsel_oe16.ipk
After you have installed Valerie, unpack file Files.zip and transfer files :
em8634dvb.ko and irvfd.ko to /lib/modules/2.6.22.19-19-the_ripper/extra
libshowiframe.so.0.0.0 to /usr/lib/enigma2/python/Plugins/Extensions/ProjectValerie
Wizard.py to /usr/lib/enigma2/python/Screens
After that, reboot your device.
NOTE: Stop button is mapped to Resolution button.
PC App : project-valerie_rev420_pc.tar is application to use on PC and to manage Valerie.
thx MickeySa
PC Aplication Use:
I do like this for setup:
for mpg files you have to add that format in PC aplication
first i sync in the box - takes a very long time the first run.
After that, with pc sinc, and after setting the azbox ip in the PC application i do download archive from box. This will download the sinc files.
Second step is : sync - this will sinc all files from internet.
3. : edit files that the info doesn't correspond to the movie file name. in the list select the movie in the colum search string. Insert the correct name of the movie. Do this to all files ( after string edited the line becomes yellow )
4. Click parse button. This will update the edited information from web.
5. download art from web if some movies don't have artwork.
6. finaly click the buton upload archive to box. This send all updates info from pc app to the box. Now you are ready to use Valeire in its full potential.
To add different file types , for example mpeg, iso etc, just go to settings and add the file termination to file management
thx moicas3004
schmegea
Re: Project Valerie for AzBox HD E2
Příspěvek od schmegea »
verze 478,
funguje OK i bez úprav v RC4
pro ty co stáhli můj balíček DCC_2 instal, přejmenovat na valerie.ipk a nahrát do media/hdd/instal
gorick
Dal poděkování: 3 poděkování
Příspěvek od gorick »
Project Valerie rev. 1270
MediaCenter plugin for enimga2
Zpět na „Pluginy a utility E2“
