JaZUp 2.3
2.3
- Adapt JaZUp for new Rescue Mode procedure
- Fix italian language
- Include Official_to_E2 (patch.bin) to use on an USB Stick from official to E2. Once your Azbox is in Rescue Mode proceed with JaZUp to flash your E2 image.
- Include Back_to_Official (patch.e2) to use via JaZUp to go from E2 to Official. Once back in upgrade screen proceed with an USB Stick containing an official firmware patch.bin file.
2.2
- New GIT compiled kernel detection and full support
- Added support for ext4 only on GIT based compiled kernel
---****> please READ the attached Manual since ext4 has an impact for you <<<---
- Current 1.1.12 RTi released version is not recognised has ext4 compatible since the kernel is "old style": this is not a bug.
2.1
- Allows users having used FW4USB to return to official firmware in DOM without bricking their Azbox (error: connect as...).
- More languages added: Catalan, Polish, Greek and Chinese - now support 11 languages.
2.0
- Support for the new patch.e2 file format
- Multilingual user interface and messages
- patch.e2 files are now loaded from your PC, no more USB needed.
So if you are familiar with JaZUp 1.x the way of working has changed, please read the attached PDF.
- when installing to USB only the target USB Stick is needed
- When creating backup of official firmware data, file is now downloaded and you can set the name of your backup file
- No more support for patch.bin file format
- Disable Hardware Acceleration even in Rescue Mode
- Uninstall Priority Manager from official firmware to avoid conflict when upgrading
- fix E2 partitions problems on official DOM (256MB) if needed
- Automatic rename dummy patch.bin into _patch.bin to allow Azbox full reboot after upgrade
Download
http://www.ulozto.cz/9220589/jazup-2-3- ... nd-pr2-zip
Azbox HD Elite,Openrsi 3.0 Kernel v3.3.1,Samsung G3 Station 1TB , multifeed 4 lnb(28.2+23.5+19.2+13),Skylink,Samsung LE40B650
