Re: SAPRO Image Octagon SF8008 a SF8008mini
Stáhni nové images a diskuze k přijímač Octagon SF8008.
Moderátor: zilizila
Warder Slovakia
Dostal poděkování: 102 poděkování
Příspěvek od Warder »
SAPRO Image 1.9 for Octagon SF8008 + SF8008mini
Use distro: OpenATV 6.4
Enigma version: 23-03-2021
Kernel version: 4.4.35
DVB version: 13-03-2021
GStreamer version: 1.17.0
Python version: 2.7.16
Resolution mode: 1080p
Default language: Czech
Default skin: HD Glass 17
OSCam: r11689 - port 8888 - 0624
Pre-installed plugins:
- AJPanel - 1.2.5
- ArchivCZSK with SCC - 1.3.8 - 2.1.24
- Chocholousek picon - 4.0.210301
- CSFD - 12-50-20180505
- CoolTVGuide - 7.7.0
- HBBTV - 2.0-r0-35
- Netflix - 2.2 + 20201119-r0
- MediaPortal - 2020060301
- SubsSupport - 1.5.8-20201004
- webradioFS - 19.40
- XStreamity - 2.90
- Youtube - git793
- Kodi 18.9
- under Kodi Skylink Live TV - 1.7.2
- under Kodi Netflix - 1.12.3
- under Kodi Stream Cinema - 1.3.28
- under Kodi Stream Cinema Community - 2.4.41
Pre-installed skins:
- HD Glass 17 - 5.14
- Metrix-ATV - 3.0-git1966
Login :
Password: sapro
Installation:
- copy the file to a USB stick and install via Online image change.
Download:
You can download version for SF8008 from https://mega.nz/file/Ms0C1Z5J#jZrkPNsae ... nya2bkhFq4
You can download version for SF8008mini from https://mega.nz/file/58F0mRZb#cOsYHX2fe ... L4EHfPuQ4g
:89:
Warder Slovakia
SAPRO Image 2.0 for Octagon SF8008 + SF8008mini
New
- add support new rcu F3 and F4 key
- sf8008 update drivers
- update key magic send now F10
Repaired
- views EPG
- views CSFD
Enigma version: 04-04-2021
DVB version: 02-04-2021
- AJPanel - 1.2.8
- HBBTV - 2.0-r0-38
- XStreamity - 2.90
- Youtube - git795
- Kodi 18.9
- under Kodi Netflix - 1.12.4
- under Kodi Stream Cinema Community - 2.4.43
- HD Glass 17 - 5.16
Login :
Password: sapro
Installation:
Download:
You can download version for SF8008 from https://mega.nz/file/thdy3R6T#yGuo-E7Tr ... Am-VvZcjGQ
You can download version for SF8008mini from https://mega.nz/file/lx0QXKyB#4lNM1RqOx ... YB-X3XvL4Y
:89:
Warder Slovakia
SAPRO Image 2.1 for Octagon SF8008 + SF8008mini
New
- CSFD has been changed to CSFDLite version because it does not currently work
- Update Enigma2 and pre-installed plugins
Enigma version: 20-05-2021
- AJPanel - 1.4.0
- ArchivCZSK with SCC - 1.3.8 - 2.1.25
- Chocholousek picon - 5.0.210501
- CSFDLite - 1.02
- HBBTV - 2.0-r0-38
- MediaPortal - 2020070101
- SubsSupport - 1.5.8-20200522
- webradioFS - 19.51
- XStreamity - 2.94
- Youtube - git815
- Kodi 18.9
- under Kodi Stream Cinema Community - 2.4.58
- HD Glass 17 - 5.19
- Metrix-ATV - 3.0-git1970
Login :
Password: sapro
Installation:
Download:
You can download version for SF8008 from https://mega.nz/file/0w8jWS6D#pBhQz0xY9 ... Pj0i-k2vr8
You can download version for SF8008mini from https://mega.nz/file/0w8jWS6D#pBhQz0xY9 ... Pj0i-k2vr8
:89:
fanynsat
Příspěvek od fanynsat »
Zdravím, ta verze 2.1 pro mini není náhodou stejná jako pro velký box 8008.
Warder Slovakia
fanynsat píše: 21 kvě 2021, 17:50 Zdravím, ta verze 2.1 pro mini není náhodou stejná jako pro velký box 8008.
Pravdu mas, pre MINI najdete na https://mega.nz/file/58llxQJZ#DLLqqSx-Q ... AyzBN-425M
:89:
Morpr Czech Republic
Příspěvek od Morpr »
Zdravím,verze 2.1 na SF 8008 mi háže chybu,vyzkoušel sem všechny postupy.
Warder Slovakia
Skua sa podelit aj o aku chybu sa jedna.
:89:
zbyneksk Czech Republic
Příspěvek od zbyneksk »
Tak je hezké. Chybu - a jakou? Co ti to píše, nebo dělá / nedělá?
Naskočí modrá obrazovka a píše Kernel error pak naskočí crashlog /home/root/logs.Když zkouším přes zap,vyp + přední tlačítko,nenajde to žádný soubor.
Warder Slovakia
Kedze mas podla mna dojebabrany system tak odporucam pouzit subor Sapro-basic-sf8008_recovery_emmc.zip , rozpakovat ho na USB kluc, vykonat kombinaciu vzadu vypinacom zapnutie + predne tlacidlo a nasledne Flash Recovery Image.
Ked to budes mat tak potom si skupirovat na kluc subor Sapro-2.1-sf8008-backup_recovery.zip a po stlaceni Modreho tlacidla vybrat Flashovanie Online .........
:89:
Díky moc,no dělal jsem dva roky obnovu ze zálohy z lenosti... Takže mám opravdu chybu v systému,nepomohlo ani tovární nastavení.Jen nemužu nikde sehnat ten soubor Sapro basic pro obnovu.
Warder Slovakia
Sapro-basic pre SF8008 a SF8008Mini
Pre SF8008 - https://mega.nz/file/A1lSGRqa#S1typ88FL ... 2lSY52V_LM
Pre SF8008Mini - https://mega.nz/file/l91kFBba#smiR2oNrv ... 3-UTHBFWVg
Užívajte v zdraví.
:89:
Naposledy upravil(a) Warder dne 27 kvě 2021, 18:09, celkem upraveno 1 x.
:89:
dodo76
Příspěvek od dodo76 »
daj tam Openatv_6.4_recovery_emmc a potom v druhom kroku ten image Sapro 2.1 ako radi kolega
Díky moc,už funguje :55: :87:
Warder Slovakia
SAPRO Image 2.6 for Octagon SF8008 + SF8008mini
New
- Update Enigma2
- Update GStreamer
- Update KODI - Widevine CDM
- Update pre-installed plugins
- Add plugin - Streamlink
Enigma version: 17-09-2021
GStreamer version: 1.18.5
OSCam: r11696 - port 8888 - 0624
- AJPanel - 2.5.0
- ArchivCZSK - 1.3.8
- Chocholousek picon - 5.0.210820
- CSFDLite - 1.04
- DreamSat Panel - 1.1
- Filmon - 1.5
- HBBTV - 2.0-r0-43
- Multi-Stalker - 1.3
- Streamlink - 3.3
- SubsSupport - 1.6.2
- XStreamity - 3.18
- Youtube - git819
- Kodi 18.9
- under Kodi Skylink Live TV - 1.7.3
- under Kodi Netflix - 1.12.6
- under Kodi Stream Cinema Community - 2.4.94
- HD Glass 17 - 7.02
- Metrix-ATV - 3.0-git2000
Login :
Password: sapro
Installation:
Download:
You can download version for SF8008 from https://mega.nz/file/EgMSEb6I#D22AkdSZv ... SRjObrXiYU
You can download version for SF8008mini from https://mega.nz/file/YhNgkL5K#TfIQ4uPJa ... lPXRfhfz28
SAPRO Basic-Image for Octagon SF8008 + SF8008mini
New
- Update Enigma2
- Update GStreamer
- CSFDLite - 1.04
- XStreamity - 3.18
- Youtube - git819
Download:
You can download version for SF8008 from https://mega.nz/file/ptkAVQZB#KHoRB-eJz ... tjywlsdiCU
You can download version for SF8008mini from https://mega.nz/file/ks1WVKDS#2dRGIUYNd ... JNmDjBx7Dc
:89:
