Debian home iptv server (OSCAM + TVHeadend + Plustelka DVB-T/T2)
Volná diskuze.
johnyzh94 Slovakia
Příspěvek od johnyzh94 »
Zdravim,
snazim sa rozbehat kombinaciu oscam s tvheadent a irdeto kartou Plustelka. Neviem si vsak uz rady. Nizsie posielam configy a logy. Dufam, ze sa tu niekto najde, kto mi poradi.
Pri pokuse spustit hocijaky plustelkovy program, napr. CT1, hlasi mi oscam chybu ivalid SID.
Log Oscamu:
root@skzvjc-server:~# oscam
06:14:29 00000000 s >> OSCam << cardserver log switched, version 1.20_svn, build r11507 (x86_64-linux-gnu)
06:14:29 00000000 s     (main) System name    = Linux
06:14:29 00000000 s     (main) Host name      = skzvjc-server
06:14:29 00000000 s     (main) Release        = 4.9.0-8-amd64
06:14:29 00000000 s     (main) Version        = #1 SMP Debian 4.9.144-3.1 (2019-02-19)
06:14:29 00000000 s     (main) Machine        = x86_64
06:14:29 00000000 s     (main) creating pidfile /tmp/.oscam/oscam.pid with pid 19072
06:14:29 00000000 s   (config) services reloaded: 0 services freed, 2 services loaded, rejected 0
06:14:29 00000000 s   (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
06:14:29 00000000 s     (main) signal handling initialized
06:14:29 00000000 s   (config) 15 service-id's loaded in 0 ms
06:14:29 00000000 s      (net) newcamd: initialized (fd=4, port=22222)
06:14:29 00000000 s      (net) -> CAID: 069A PROVID: 000000, 000001, 000002, 000003
06:14:29 00000000 s   (reader) Plustelka [mouse] creating thread for device /dev/ttyUSB1
06:14:29 00000000 s     (main) waiting for local card init
06:14:29 7A786657 h    (webif) webif: decompressed 165026 bytes back into 400960 bytes
06:14:29 7A786657 h    (webif) HTTP Server couldn't bind on port 8777 (errno=98 Address already in use). Not starting HTTP!
06:14:29 3513D53D r   (reader) Plustelka [mouse] Reader initialized (device=/dev/ttyUSB1, detect=cd, mhz=600, cardmhz=600)
06:14:30 3513D53D r   (reader) Plustelka [mouse] card detected
06:14:31 3513D53D r   (reader) Plustelka [mouse] ATR: 3B 9F 21 0E 49 52 44 45 54 4F 20 41 43 53 20 56 37 2E 30 9F
06:14:32 3513D53D r   (reader) Plustelka [mouse] detect irdeto card
06:14:33 3513D53D r   (reader) Plustelka [mouse] Irdeto SC 70 version 2 revision 0, patch level 2
06:14:33 3513D53D r   (reader) Plustelka [mouse] caid: 0668, acs: 0.06, country code: SVK
06:14:33 3513D53D r   (reader) Plustelka [mouse] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
06:14:36 3513D53D r   (reader) Plustelka [mouse] active providers: 4 (040528,ffffff,ffffff,ffffff)
06:14:36 3513D53D r   (reader) Plustelka [mouse] found card system irdeto
06:14:36 3513D53D r   (reader) Plustelka [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No  1 out of max alloted of 1
06:14:36 3513D53D r   (reader) Plustelka [irdeto] entitlements for provider: 1, id: 040528
06:14:36 3513D53D r   (reader) Plustelka [irdeto] chid: 0007, date: 2019/03/30 - 2019/12/09
06:14:36 3513D53D r   (reader) Plustelka [irdeto] chid: 7FFE, date: 2019/03/30 - 2019/04/29
06:14:36 3513D53D r   (reader) Plustelka [irdeto] chid: 7FFD, date: 2019/01/20 - 2019/01/30
06:14:36 3513D53D r   (reader) Plustelka [irdeto] chid: 0002, date: 2019/03/30 - 2019/04/30
06:14:36 3513D53D r   (reader) Plustelka [irdeto] chid: FFD8, date: 2019/01/30 - 2019/02/09
06:14:42 3513D53D r   (reader) Plustelka [irdeto] ready for requests
06:14:43 00000000 s     (main) init for all local cards done
06:14:43 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
06:14:43 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
06:14:43 053AB5FE c  (newcamd) client connected to 22222 port
06:14:43 3665247E c   (client) plain dvbapi-client granted (anonymous, au=off)
06:14:43 04DEC7DF c  (newcamd) client connected to 22222 port
06:14:43 053AB5FE c   (client) anonymous disconnected from 127.0.0.1
06:14:43 3665247E c   (dvbapi) dvbapi channelcache loaded from /usr/local/etc/oscam.ccache
06:14:43 3665247E c   (dvbapi) Using TCP listen socket, API forced to DVBAPIv3 (0), userconfig boxtype: 11
06:14:43 04DEC7DF c   (client) encrypted newcamd:22222-client 127.0.0.1 granted (1, au=auto (1 reader))
06:14:43 04DEC7DF c  (newcamd) user 1 authenticated successfully (Tvheadend)
06:14:43 04DEC7DF c  (newcamd) AU disabled for user 1
06:14:43 04DEC7DF c      (ecm) 1 (069A@000000/0002/03F0/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:14:43 04DEC7DF c      (ecm) 1 (069A@000000/0008/03F0/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:14:43 04DEC7DF c      (ecm) 1 (069A@000000/0061/03F0/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:14:43 04DEC7DF c      (ecm) 1 (069A@000000/0062/03F0/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:14:44 04DEC7DF c      (ecm) 1 (069A@000000/0002/03F0/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:14:44 04DEC7DF c      (ecm) 1 (069A@000000/0008/03F0/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:14:44 04DEC7DF c      (ecm) 1 (069A@000000/0061/03F0/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:15:10 04DEC7DF c      (ecm) 1 (069A@000000/0002/03EF/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:15:10 04DEC7DF c      (ecm) 1 (069A@000000/0008/03EF/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:15:10 04DEC7DF c      (ecm) 1 (069A@000000/0061/03EF/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:15:10 04DEC7DF c      (ecm) 1 (069A@000000/0062/03EF/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:15:14 04DEC7DF c      (ecm) 1 (069A@000000/0002/03EF/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:15:14 04DEC7DF c      (ecm) 1 (069A@000000/0008/03EF/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
06:15:14 04DEC7DF c      (ecm) 1 (069A@000000/0061/03EF/59:00000000000000000000000000000000): invalid (0 ms) (invalid SID)
^C06:15:21 00000000 s   (dvbapi) dvbapi channelcache saved to /usr/local/etc/oscam.ccache
06:15:21 00000000 s (emmcache) saving emmcache disabled since no reader is using it!
06:15:21 00000000 s (emmcache) saving emmstats disabled since no reader is using it!
Log tvheadend:
2019-04-02 06:51:47.293 mpegts: 586MHz in DVB-T Network - tuning on Silicon Labs Si2168 #1 : DVB-T #0
2019-04-02 06:51:47.293 capmt: sss: Starting CAPMT server for service "CT1" on adapter 1
2019-04-02 06:51:47.293 subscription: 0118: "HTTP" subscribing on channel "CT1", weight: 100, adapter: "Silicon Labs Si2168 #1 : DVB-T #0", network: "DVB-T Network", mux: "586MHz", provider: "Towercom", service: "CT1", profile="pass", hostname="127.0.0.1", client="VLC/3.0.6 LibVLC/3.0.6"
2019-04-02 06:51:54.189 cwc: Can not descramble service "CT1", access denied (seqno: 4517 Req delay: 4 ms) from cwc-localhost-22222-069A
2019-04-02 06:51:56.066 descrambler: cannot decode packets for service "CT1"
oscam.conf
[global]
logfile = stdout
bindwait = 30
nice = -1
lb_mode = 1
[newcamd]
port = 22222@069A:000000,000001,000002,000003
keepalive = 1
mgclient = 1
[dvbapi]
enabled                       = 1
au                            = 1
pmt_mode                      = 4
listen_port                   = 9000
user                          = tvh
read_sdt                      = 2
write_sdt_prov                = 1
boxtype                       = pc
[webif]
httpport = 8777
httpuser =
httppwd =
httprefresh = 10
httpallowed = 127.0.0.1,localhost
oscam.service
[plustelka]
caid = 0668
provid = 000000,000001,000002,000003,000004,FFFFFF
srvid = 0FA1,0FA2,0FAE,0FA4,0FA5,0FA6,0FAC,0FAF,0FAA,0FA3,0FAD,0FAB,0FA7,0FA9,0FA8,03EE,03EA
[volnatelka]
caid = 0668
srvid = 132A,1329,1452
oscam.server
[reader]
label = Plustelka
protocol = mouse
device = /dev/ttyUSB1
boxkey = B1B2B3B4B5B6B7B8
rsakey = AB722A8CAA9F58DE0D1CBB6FF329C961ED9DD759B103082D1BAE64C27A861D42E7F631891C2660EFA57484F80BBB4E0E8249A8368E31BD3FFC369FBE95160528
detect = cd
mhz = 600
cardmhz = 600
group = 1
caid = 0668
emmcache = 0,1,2,0
blockemm-u = 1
oscam.srvid2
# oscam.srvid2 generated automatically by Streamboard OSCAM 1.20_svn SVN r11507
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.srvid2.txt
# Plustelka DVB-T
0668:0FAB|PLUSTELKA|VH1|TV|Plustelka
0668:0FA6|PLUSTELKA|Film+|TV|Plustelka
0668:0FA4|PLUSTELKA|Eurosport 1|TV|Plustelka
0668:0FA5|PLUSTELKA|Eurosport 2|TV|Plustelka
0668:0FAA|PLUSTELKA|Nickelodeon|TV|Plustelka
0668:0FA7|PLUSTELKA|Viasat Explore/Spice|TV|Plustelka
0668:0FA9|PLUSTELKA|Viasat History|TV|Plustelka
0668:0FA8|PLUSTELKA|Viasat Nature|TV|Plustelka
0668:0FA2|PLUSTELKA|CT2|TV|Plustelka
0668:0FA1|PLUSTELKA|CT1|TV|Plustelka
0668:0FA3|PLUSTELKA|RiK|TV|Plustelka
0668:0FAE|PLUSTELKA|Eroxx|TV|Plustelka
0668:0FAC|PLUSTELKA|JOJ Cinema HD|TV|Plustelka
0668:OFAD|PLUSTELKA|Sport 2|TV|Plustelka
0668:0FAF|PLUSTELKA|JOJ HD|TV|Plustelka
oscam.user
[account]
user = 1
pwd = 1
description = JA
monlevel = 4
keepalive = 1
au = 1
group = 1,2
cccmaxhops = 9
services = plustelka,volnatelka
oscam.dvbapi
I: 0624
I: 0100
I: 1815
I: 0B00
P: 0D96
P: 0D97
P: 069A
P: 0653
P: 0668
tvheadend CA:
Dakujem za rady
dym1 Slovakia
Re: Debian home iptv server (OSCAM + TVHeadend + Plustelka DVB-T/T2)
Příspěvek od dym1 »
V oscam.conf. mas port = 22222@069A:000000,000001,000002,000003
Karta je 0668
Ak ti bezi tvh aj oscam na jednom stroji. Tak v tvhKonfiguracia /CAs radsej pouzi CAPMT (linux Network DVDAPI). Namiesto newcamd.
efendy55 Slovakia
Dal poděkování: 16 poděkování
Příspěvek od efendy55 »
skús napr. takto ... a na jakého frasa používaš services ??? a zmaž si to v dvbapi ..... máš v tom trochu bordel ..... alebo si to uprav podla tvojej potreby . používaš aj 069A ??? ked ho máš ako P: :D
[reader]
label = Plustelka
protocol = mouse
device = /dev/ttyUSB0
autospeed = 0
detect = cd
mhz = 600
cardmhz = 600
group = 1
emmcache = 0,3,2,1
KLUDNE SI TO UPRAV PODLA SEBA .... ale takto to ide bez jediného problému ... :106:
Všetko4K,Linux E2
marian34
Příspěvek od marian34 »
efendy55 píše: [reader]
label = Plustelka
protocol = mouse
autospeed = 0
detect = cd
mhz = 600
cardmhz = 600
group = 1
emmcache = 0,3,2,1
Hele maďare, a to mu je načo? Však karta sa mu inicializuje, takže zrovna to má dobre.
Dal poděkování: 6 poděkování
marian34 píše:
efendy55 píše:KLUDNE SI TO UPRAV PODLA SEBA .... ale takto to ide bez jediného problému ... :106:
to je pekne ze dobre , len ju ma zakazane ozivit EMM-kom
marian34
Nemáš pravdu bystričane, nič také, ako popisuješ, zakázané nemá.
Zpět na „Volná diskuze“
