PLS, pomozte !
Vzdy po nejakom case v kazdej verzii E2 co som skusal mi prestane fungovat nastavenie a spadne system vzdy ked sa chcem don dostat. Pridavam aj crash log, co sa objavi na obrazovke. Som amater a nic mi to nehovori, kde moze byt zrada. Vie niekto pomoct ? Vdaka
okbuttonClick
ParentalControlSetup ParentalControlSetup
Screen <class 'Screens.Menu.Menu'>((<Element 'menu' at 0x104f158>,), {}): <type 'exceptions.KeyError'>
Traceback (most recent call last):
File "/usr/lib/enigma2/python/mytest.py", line 226, in create
return screen(self, *arguments, **kwargs)
File "/usr/lib/enigma2/python/Screens/Menu.py", line 186, in __init__
File "/usr/lib/enigma2/python/Components/PluginComponent.py", line 133, in getPluginsForMenu
File "/usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py", line 1908, in startSetup
if menuid == "setup" and config.plugins.softwaremanager.onSetupMenu.value:
File "/usr/lib/enigma2/python/Components/config.py", line 1577, in __getattr__
KeyError: 'onSetupMenu'
open /dev/dbox/fp0 for wakeup timer clear failed!(No such file or directory)
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 66, in action
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
File "/usr/lib/enigma2/python/Screens/Menu.py", line 56, in okbuttonClick
File "/usr/lib/enigma2/python/Screens/Menu.py", line 24, in __call__
File "/usr/lib/enigma2/python/mytest.py", line 294, in openWithCallback
dlg = self.open(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 305, in open
dlg.isTmp = True
AttributeError: 'NoneType' object has no attribute 'isTmp'
(PyObject_CallObject(<bound method NumberActionMap.action of <Components.ActionMap.NumberActionMap instance at 0x1983968>>,('OkCancelActions', 'ok')) failed)
getResolvedKey config.plugins.crashlogautosubmit.sendAnonCrashlog failed !! (Typo??)
getResolvedKey config.plugins.crashlogautosubmit.addNetwork failed !! (Typo??)
getResolvedKey config.plugins.crashlogautosubmit.addWlan failed !! (Typo??)
</enigma2crashlog>
</crashlogs>
</openpli>
Crash problem v AZBoxe
Otázky pro začátečníky E2
JohnCenaWWE
Re: Crash problem v AZBoxe
Příspěvek od JohnCenaWWE »
aky image je tam zly SwManager
OpenPLi 7,0 Kernel 3.3.1
Momentálne OpenRSI-3.0-azboxhd-20140104.zip ale robi mi to aj pri inych ako napr. AlonzoBLUE 2.2 alebo OpenPLi_AlonzoREVOLUTION_V8.0, rovnaky CRASH v nastaveniachJohnCenaWWE píše:aky image je tam zly SwManager
Dnes som sa hral a neviem to ešte na 100 percent potvrdit, ale zdá sa mi, že to robí plugin TSpanelrony1977 píše:Momentálne OpenRSI-3.0-azboxhd-20140104.zip ale robi mi to aj pri inych ako napr. AlonzoBLUE 2.2 alebo OpenPLi_AlonzoREVOLUTION_V8.0, rovnaky CRASH v nastaveniachJohnCenaWWE píše:aky image je tam zly SwManager
JohnCenaWWE
ano moze byt daj ho prec,aky mas skin
Skin tam je OpenPLI HD, ale už môžem potvrdiť že to robí TSplanel vo verzii 7.3. Inak škoda, celkom sa mi páčil. Existuje niečo čo by nahradilo tento Plugin ?JohnCenaWWE píše:ano moze byt daj ho prec,aky mas skin
JohnCenaWWE
skus ts panel 7,2!!!!!!!!!!!ak nepomoze skus zmenit skin
