Stránka 1 z 4
fw 1.08.94 FAC
Napsal: 29 bře 2011, 13:49
v downloade najdete dostupnu novu verziu
fw 1.08.94 FAC .
http://www.forum.satdigitalne.cz/viewto ... 234&t=5214
Re: fw 1.08.94 FAC
Napsal: 29 bře 2011, 19:08
od fefe88
--> Front vol. & ch. buttons interchanged issue solved (7105)
--> Blindscan works twice & Not running Blindscan solved
--> Calculating time error in recording information solved
--> Showing WAIT OFF on front display during recording in standby mode solved
--> Searching problem in specific TP in AsiaSat 3 solved
--> Freezing symptom in specific TP (12266 H 27500 Astra19) amended
--> Differences OSD language with OSD menu text display amended
--> Portuguese OSD Language : added
--> OSD Languages Translation ammended :
--> french, dutch and english
--> Spelling error as Power Saving in Standby Mode in A/V output setting menu amended
--> T1 & T2 Icons are presented on Service List and Service List with Single Tuner model solved by presenting only T1
--> USALS freezing issue solved
--> Playback problem in Standby Mode solved
--> Tuksat42E & Eutelsat7E night Ch. problem solved
--> Plugin OSD Jitter problem solved (7110+7105)
--> Plugin Interface upgrade : Plugin API V1.07
--> Pls. use NEW Plugins and WebZeal V1.80 !
--> PanScan Format for TV Aspect Ratio 16:9 added
--> Full Format for TV Aspect Ratio 4:3 added
--> Build Version 4551
Re: fw 1.08.94 FAC
Napsal: 29 bře 2011, 22:22
od SuiVanOrton
Takže ten NTFS tam nakonec není co ?
Re: fw 1.08.94 FAC
Napsal: 30 bře 2011, 07:57
od mmirousek
fefe88 píše:
chápu dobře, že s xCamem z předchozích verzí by mohl být problém ?
Re: fw 1.08.94 FAC
Napsal: 30 bře 2011, 14:25
od dk_line
fefe88 píše:
Asi bych to bral prinejmensim jako doporuceni jak se vyhnout pripadnym problemum.
Zajima me, jestli jste uz nekdo ten WebZeal V1.80 zkousel a jestli stoji za namahu to na instalovat.
Re: fw 1.08.94 FAC
Napsal: 30 bře 2011, 20:20
od siso.tt
mmirousek píše:fefe88 píše:
Neviem ako xCam , ale ja som skopcil komlet plugin oscam 4846 CS/SKY s predchadzajuceho firmw.
a vsetko bezi ako predtym teda zatial, 1/2 hod - testujem
WebZeal som stiahol - vyzera to zaujimavo, testovat budem az nebude doma zena
Re: fw 1.08.94 FAC
Napsal: 30 bře 2011, 23:28
od dk_line
siso.tt píše:
... od kud jsi stahoval a jakou verzi? Delam neco blbe a nebo verze nejdou mezi boxi zamenovat. To co jsem v rychlosti nasel a zkusil stahnout vcetne doporucovane 1.80 mi na HDBox nejde zadnym z uvedenych postupu nijak instalovat.
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 13:20
od siso.tt
dk_line píše:siso.tt píše:
myslim ze odtialto :
http://www.dark-sat-world.com/downloads ... le&id=2853
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 20:01
od dk_line
Tak WebZeal 1.80 jde stahnout i bez registrace
ZDE. Bohuel, jestli jsem spravne pochopil, tak na HDBOXu 9100 si to standardnim postupem neodzkousim, pro mount a nasledne spusteni je treba nit dve USB, presniji tedy predni USB :sad:
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 20:03
Neni náhodou tento plugin pre iné modely / s iným chipsetom / ?
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 20:35
od siso.tt
dempsey píše:Neni náhodou tento plugin pre iné modely / s iným chipsetom / ?
ja myslim ze nie http://.....
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 20:37
od gatecomputers
Tak jsem nahodil tento nový firmware 1.08.94 na HDBOX FS-9100. Taky se vám nezobrazuje š a ž v menu a podnabídkách? Všude mám pouze mezeru. Třeba Obnovení systému - Vyma e ulo enou pozici
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 20:48
od ShaMan
Webzeal a NTFS se týká zatím nové řady s jiným procesorem tzn HD-BOX FS-9105 apod Fortis based ,
tím pádem je třeba dávat bacha na changelogy , pravděpodobně budou některé pro a jiné pro jiné .
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 20:52
od dk_line
hmm... tak ted jsem uplne mimo, jeste ze jsi me tou tyci prastil. Chtel jsem verit tomu, ze Octagon SF1008SE+ a SF1008 jsou na totoznem zeleze jen rozsirene o ty usb a e-satu:???:
Re: fw 1.08.94 FAC
Napsal: 31 bře 2011, 21:08
od SuiVanOrton
gatecomputers píše:Tak jsem nahodil tento nový firmware 1.08.94 na HDBOX FS-9100. Taky se vám nezobrazuje š a ž v menu a podnabídkách? Všude mám pouze mezeru. Třeba Obnovení systému - Vyma e ulo enou pozici
taky taky, místo "živě" je tam " ivě" apod.
A ještě mám problém trošku s manuálním nahráváním, když třeba zapnu manuální nahrávání tak se stává že mi to hodí hlášku program zakodovan. Bud hned, nebo po chvíly když se vrátím na ten program který zrovna nahrávám. Jinak ale když nejsem doma tak se to nahraje ok. (tunery mám oddělené).
