zdravim, neviete poradit kde by som nasiel pre Clarka 9100-vku tieto dva CCcamy? Skusal som nejake ipk instalacky pre mipsel ale nic.Zrejme musi byt totozny aj s image.
dakujem
CCcam 2.0.11 / 2.1.4 v Open PLi 4.0 ?
DM900UHD Triple_Merlin_Oscam, ET10000HD G-edition 3xDVB-S2+DVB-C_OpenPli_Oscam,FUBA DDA110 AL_LNB Invacom Twin,40mm Feed,0,3 dB_motor 30W-75E+FE perforated 90cm_08W,LNB Inverto Twin Black Ultra 0,2 dB
http://www.openinfo1036.estranky.cz/
Re: CCcam 2.0.11 / 2.1.4 v Open PLi 4.0 ?
Nejake tie TS panely, persian panel, ci GSU si neskusal?
