Tak jsem přes OSCAM 8532 zjistil následující..
Karta dle níže uvedeného je detekována, ale stále označeno jako "NEEDINIT". Zápisy na kartě mám z jiného boxu certifikovaného na skylink.
Něco futr dělám zle, ale fakt nevím co.. Je tu někdo kdo poradí ?
hide Thread ID Type ID Label AU Crypted Address Port Protocol Login Online CAID:SRVID Current Channel LB Value/ Reader Idle Status
Hide 0x515e20 s 0 root 127.0.0.1 0 server 31.12.14 16:47:27 00:15:34 0000:0000 00:15:33 OK
Hide 0x5e1b30 h 1 root 127.0.0.1 0 http 31.12.14 16:47:28 00:15:33 0000:0000 00:00:00 OK
Readers 0/1
Hide 0x5e0380 r 1 citacka ON OFF 127.0.0.1 0 internal 0000:0000 no data 00:15:33 NEEDINIT (no entitlements)
2014/12/31 16:47:27 0 s >> OSCam << cardserver started, version 1.20-GSU-, build r8532 (mipsel-unknown-linux-gnu-ssl)
2014/12/31 16:47:27 0 s creating pidfile /tmp/.oscam/oscam.pid with pid 2001
2014/12/31 16:47:27 0 s services reloaded: 0 services freed, 2 services loaded, rejected 0
2014/12/31 16:47:27 0 s userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2014/12/31 16:47:27 0 s signal handling initialized
2014/12/31 16:47:28 0 s 8981 service-id's loaded in 594ms
2014/12/31 16:47:28 0 s WARNING: You risk high CPU load and high ECM times with more than 2000 service-id's!
2014/12/31 16:47:28 0 s HINT: --> use optimized lists from
http://www.streamboard.tv/wiki/Srvid
2014/12/31 16:47:28 0 s 124 tier-id's loaded
2014/12/31 16:47:28 0 s 940 provid's loaded
2014/12/31 16:47:28 0 s citacka [internal] creating thread for device /dev/sci0
2014/12/31 16:47:28 0 s loadbalancer: can't read from file /tmp/.oscam/stat
2014/12/31 16:47:28 0 s waiting for local card init
2014/12/31 16:47:28 5E0380 r citacka [internal] Reader initialized (device=/dev/sci0, detect=cd, mhz=500, cardmhz=357)
2014/12/31 16:47:28 5E1B30 h webif: decompressed 52163 bytes back into 150152 bytes
2014/12/31 16:47:28 5E1B30 h HTTP Server listening on port 8888
2014/12/31 16:47:29 5E0380 r citacka [internal] card detected
