OSCAM pre Azbox
Napsal: 17 črc 2013, 13:36
od JohnCenaWWE
Ahojte poradte mi aky najlepsi Oscam pre nas AZBOX pouzit?pouzivam Oscam ymod t40 aj s EMU /sem tam seka/ , skusal som aj Oscam1,20 8532 srv /taky sem tam seka/
pouzivam share a posielam dalej reshare,pred tym com mal cccam 2,1,3 ale u 2 boxu ide lepsie ked mam v Azboxe Oscam ale zase v Azboxe to zacalo dost sekat,server je dobry ,niekedy seka aj EMU
ked som daval do Azboxu Oscam ymod 39 ako 1prvy krat secko slo krasne 2 dni super az potom to zacalo sekat tak isto aj u kamosa co som mu robil VU DUO 2 dni ok a potom to sekalo jedna radost,poradte aky najstabilnejsi oscam aj s emu dat?diki moc budem vam vdacny
Re: OSCAM pre Azbox
Napsal: 21 črc 2013, 09:25
od JohnCenaWWE
nieco som nasiel na nete ale nedari sa mi to spojazdnit ako to spustit?
OSCam AZBox 1.20-Rev.8414 for Opensat firmware
- Changeset [8414] by gf
cscrypt: Do not use internal MD5 functions when linking with libcrypto.
Its silly to use our own MD5 functions when libcrypto provides them
for us (in case we are linking with libcrypto).
bloat-o-meter reports ~3.8k savings on make USE_LIBCRYPTO=1 build:
add/remove: 0/4 grow/shrink: 0/1 up/down: 0/-3877 (-3877)
function old new delta
MD5 108 - -108
__md5_crypt 1467 1307 -160
MD5_Final 781 - -781
MD5_Update 840 - -840
MD5_Transform 1988 - -1988
- Changeset [8413] by gf
Kill csctapi/csctapi.h
- Changeset [8412] by gf
Include cscrypt/sha1.h where it is needed.
- Changeset [8411] by gf
Include cscrypt/md5.h where it is needed.
- Changeset [8410] by gf
Include cscrypt/des.h where it is needed.
- Changeset [8409] by gf
Move crc32() function in oscam-string.c
-In folder "OpenXCAS-exemple-" is present file "module.seq",
need edit it if you use others emu, remember to use symbol #
before the names of no-active emu.
-In folder "OpenXCAS-exemple/oscamCAS" are present exemple files
generated in compilation and added right file openxcas.conf.
-In folder "OSCam 1.20" and "OpenXCAS-exemple/oscamCAS"
is present build oscam file to put in "/PLUGINS/OpenXCAS/oscamCAS"
with chmod 755.
-All details in Info file.
-Modified webinfo style in module-webif-pages.c before crosscompiling
sorry if no like you
Source files streamboard.tv:8001/browser/trunk
used toolchain sigma "smp86xx_toolchain.20080505".
Thanks to all friends that spend time for enjoy us.
Thanks streamboard.tv for possibility to play with OScam.
Compiled & mod web style by Arbabe
Re: OSCAM pre Azbox
Napsal: 21 črc 2013, 18:30
od Yano
Toto je oscam pre original fw, ked mas Enigmu tak ti to nepojde.
A ked chces oscam predsa len pod original fw, mam dojem ze nepodporuje internal card reader, takze len cez nejaku ext. usb reader.
Re: OSCAM pre Azbox
Napsal: 22 črc 2013, 08:45
od JohnCenaWWE
aj som si myslel diki,nie chcem pre E2
