ItalySat images
Images pro přijímač Clarke-Tech ET9000 HD , Xtrend ET9x00
Re: Rôzne images
New ItalySat 2.0
Dragon Edition
Support:
Dreambox: 500hd - 800 - 800se - 8000 - 7020hd
Vuplus: Vusolo - Vuduo - Vuuno - Vuultimo
Xtrend/CTech: Et5x00 - Et6x00 - Et9x00
-Migrating to project OpenPli (thanks to the team OpenPli)
-New bootlogo
-New Skin eXcort by mmark 1.3 (modified from Bobsilvio)
-New MultiEPG Chart with search
-Backup Manager Backup Manager integrated project based on 8.7 (for now only on Vu + and ET Box - Link)
-New ability to attach to an extra custom URL, just enter the file / etc / it_personal.url
-New Second Infobar
-New NFS panel
-Airplay system emulation (thanks to OpenAir - Link)
-Webinterface removed and inserted OpenWebinf
-Setting New Manager integrated with auto-update setting - SVDownloader -(thanksdalraist - Link)
-New CronManager
-New MountManager with automount and formatting
-Support autoresize for picons (100x60 e 130x80)
The image was produced and tested proprietary decoder, a heartfelt thanks to allthose people who have chosen to fit our image on their decoders for various tests.
Not having decoder for testing, some things may not work properly, we apologizein advance for any malfunction. Unfortunately we can not buy all decoders.
Thanks Bobsilvio (coder image) and Pappaalfio (beta tester very and many present), thanks all moderator and supermod of italysat.it
Many Thanks all Betatester, all italysat.it user for continue contribute, Openpli for open source, all plugins coder.
IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAYTV WITH OR WITHOUT A PAID SUBSCRIPTION.
:arrow: Download
Re: Rôzne images
New ItalySat 2.0
Dragon Edition
=============== Date: 13-04-2012, SVN 028 =====================
********************* PUBBLIC RELEASE ***************************
* Removed LCN scanner from Svdownloader (tnx darlast)
* Fix mediatomb start
* Fix Vu Box starting (tnx orion_quest11 for test)
PLI
* linux-etxx00: add workaround for dib0700 sleep race
* Update e2openplugins submodule
* dvbsnoop: use cvs-over-ssh instead of cvs-over-rsh, which is not available
* enigma2: combine RCONFLICTS assignments
* enigma2: force removal of the (depreciated) usbtunerhelper when using online update
* et-plugins: add livestream importer, build from external github repo
* fuse: add 2.8.7
* linux-etxx00: reworked dvb-usb patches by Gennar1
* remove usbtunerhelper
* linux-etxx00: dvb-usb-a867 dvbapi5.5 fix
* base-files: Make /media a volatile filesystem
* linux-etxx00: update to 3.3.0
* rtl8192cu: add a few productids
* hans channelsettings: 20120403 update
:arrow: Download
ItalySat - Dragon Edition
ItalySat2.0-et9x00-SVN_032 z 02-05-2012
-info v boxe stlac modre a potom zlte (Timeline) tlacitko na DO.
Online update /zelene-cervene - aktualiz.software...
===================== Date: 02-05-2012, SVN 32 =====================
* Fix Italysat Memory Panel crash
* Fix Italysat DTT Panel crash
* linux-etxx00: disable dvb-usb rc polling by default -saves usb bandwidth -avoids invalid ir events being reported by usb devices
* hans channel settings: 20120501 update
* openpli-image: add dosfstools to OPTIONAL_PACKAGES dosfstools contains mkfs.vfat
* Fix read new update in green panel
* Changend in skin box position, during update
* New driver DTT for Dreambox
===================== Date: 01-05-2012, SVN 31 =====================
* Fix Kernel Panel
* Added Panel for stop/start AirPlay
* Fix memory panel in ET box
===================== Date: 29-04-2012, SVN 30 =====================
Openembedded:
* djmount: repair package build
* libdreamdvd: optimize startup of playing dvds: directly go to dvd menu if possible
* rytec sources file update 2012-04-02
* dreambox drivers: 20120322 update
* base-passwd: use empty root password
* attr: use SAVANNAH_MIRROR in SRC_URI
* git: use KERNELORG_MIRROR in SRC_URI
* fix KERNELORG_MIRROR url
* libpng: update to V1.5.10
* update base-passwd to 3.5.24
* linux-etxx00: build ext2/ext3 modules
* volatile-media: Prevent deletion of fstab directories
* ntfs-3g: Remove ntfsprogs dependency, build with external libfuse
* busybox-mdev: Use /media as admin area, try harder to unmount
Enigma2:
* ServiceScan: add missing transponder status fields
* ServiceScan: fix showing illegal scan status fields
* ScanSetup: fix setting invalid sat transponder system
* servicedvb: fix disabling cached subtitles
===================== Date: 26-04-2012, SVN 029 =====================
* Wifi Rlt8192u added new 3 dongle
* New version OpenVpn 2.2.2
PLI
* Enigma2 Update 16.04.2012
:arrow: Download
Re: ItalySat - Dragon Edition
ItalySat Timeline Image
=============== Date: 09-05-2012, SVN 36 ==============
PUBBLIC RELEASE
* Fix crash in manual install panel *
* Added ceck binary in OpenVPN panel *
* Fix recognition picon in hdd etc..*
* Fix Gigablue debug error *
* linux-etxx00: it913x bulk read/write fix *
* Update e2openplugins submodule *
* servicedvb.cpp: getCachedSubtitle returns py_RETURN_NONE when cache is 0 *
* servicedvb.cpp: I just removed the incorrect PID != 0 check *
* servicedvb.cpp: Check on pid 0 not required in updateDecoder *
Je mozna online aktualizacia: zelene-cervene - dole aktualizacia software.
Po online aktualizacii a reastarte boxu nevie system spravne mountnut hdd a usb.
Mozna naprava za pomoci GSU pluginu od shamanna.
1.) stlac modre potom cervene tlacitko na DO, device panel manager - unmount HDD a USB
2.) v GSU plugine - device manager mountni HDD ako media/hdd a USB ako media/usb.
Nie je potrebny restart boxu a system bude vidiet hdd aj usb spravne.
=============== Date: 17-05-2012, SVN 37 ==============
Online update - > zelene - cervene - aktualizacia software
=============== Date: 19-05-2012, SVN 38 ==============
**************** Next RELEASE *********************
* Gigablue: fix time clock in stanby *
* Gigablue: fix keymap *
* Fix red and greep button on panel fullbackup *
* Added FullBackup beta for Gigablue (based on scp vers) *
* Update FullBackup to 9.6 *
* Update e2openplugins *
* dreambox-secondstage: update dm7020hd to #86 *
* dreambox-dvb-modules: update dm800se to 20120328 *
* fuse-exfat: Upgrade to 0.9.7 and add exfat-utils *
* fuse: Upgrade to 2.9.0 *
:arrow: Download
=============== Date: 27-05-2012, SVN 39 ==============
*** Save more space, -3mb ****
* Update skin excort to v 1.5 *
* Gigablue: add module autostart for smargo and other *
* Update e2openplugin *
* aio-grab: remove AC_OPENMP on powerpc builds *
=============== Date: 10-06-2012, SVN 44 ==============
**************** PRIVATE RELEASE **************
**************** New ItalySat 3.0 **************
* New Skin Gotham by mmark (bobsilvio mod) *
* New BootLogo Euro 2012 *
* New FullBackup scp based version 9.1 *
* Added Dreambox FullBackup (test and report) *
* Added in channel list New EPG code *
:arrow: Tu stiahni IS_3.0_SVN_044
=============== Date: 21-06-2012, SVN 45 ==============
*** RECOMPILED ***
* New Function -> Configuration Backup
--- Permette di effettuare il solo backup di tutte ---
--- le configurazioni e di ripristinarle in una ---
--- successiva installazione dell'immagine ---
* Fix Software Update
* Fix depends for Backup Gigablue
* Fix depends for Backup Dreambox
* Fix auto start wifi zd1211b
:arrow: Tu stiahni ItalySat3.0-et9x00-SVN_045
=============== Date: 27-06-2012, SVN 46 ==============
* Fix Dreambox FullBackup *
* Added packet openvpn in packet manager *
* New MultiGraphEpg *
* Fix Download and install new language in Wizard*
=============== Date: 28-06-2012, SVN 47 ==============
* Fix bug "starting" for all box *
:arrow: Tu stiahni ItalySat3.0-et9x00-SVN_047
Xtrend - ItalySat 4.0
ITALYSAT 4.0
Date: 03/11/2012, SVN 069
Based on OpenPLI 3.0
Based on OE 2.0
FOR
XTREND
(ET9X00)
Kernel: 3.6.0
PREMESSA:
Lo scopo di questa immagine, è quello di rendere all'utente finale, esperto o meno esperto, la facilità d'uso, sopratutto, avere la possibilità di installare su decoder differenti, sia come marchio che come modello, un' unica immagine capace di interfacciarsi con i vari box a disposizione.
Molto è cambiato dalla versione 1.0 ; abbiamo ascoltato le esigenze degli utenti del forum ed abbiamo reso l'immagine allo stesso tempo, completa, con le stesse funzioni su tutti i decoder supportati, ma anche leggerissima e veloce.
L'immagine ha tutti i servizi, come pcscd, cron, device mount, DVB-T driver, Network mount (mediatomb, minidlna, djmount, ecc).. ma allo stesso tempo è priva di tutti questi file, che verranno installati dall'utente, semplicemente entrando nei appositi pannelli !!
Infatti installando l'immagine vi ritroverete i servizi essenziali ma, con un paio di click del vostro telecomando, tutto sarà configurabile in autodownload.
Sovra***ricare una immagine di servizi non espressamente utili all'utente, è un imperativo dato che la immagine puo essere installata su Decoder che hanno dai 64 mb ad 1Gb di flash !!
La ItalySat 4.0 vuole essere leggera ma allo stesso tempo vuole supportare tutto.
Sicuramente è più facile capire quello che può darvi, provandola piuttosto che descrivendola !!
Thanks to:
OpenPLI, for great work
Mmark for vanity skin
Dalraist for Svdownloader
Nemesis old source, infobar, memory and cam manager
Gianathem for daemon
ItalyTech.it for Gigablue and Sponsor support
Impex-sat.de for Gigablue support
Oe-Alliance
Vix for Device and Cron Manager
Pedro_Newbie for backuptool, and scp for modded version for giga and dream
and for very big work in Team ItalySat:
Steno - Server Maintainer
Pappaalfio - Betatester
Paolopaz - Betatester
Nibis - Betatester
:arrow: Tu klikni pre stiahnutie img ItalySat4.0-et9x00-SVN_069
ITALYSAT 4,0
Timeline
=============== Date: 07/11/2012, SVN 070 ==============
Fix Mytube (ora compare nella lista plugin estensioni Network) Fix MyTube
Fix DTT smsusb (ministick) - Attivare sia Part1 che Part2
Merge Enigma2 con OpenPLI 5/11 ore 13:00
Merge Oe con OpenPLI 5/11 ore 13:00
Merge Enigma2-plugin con OpenPLI 5/11 ore 13:00
ITALYSAT 4,0
Timeline
=============== Date: 30/11/2012, SVN 074 ==============
Tutti gli update presenti nella SVN 073
Merge Enigma2 con OpenPLI 27/11 ore 13:30
Merge Oe con OpenPLI 27/11 ore 13:30
Skin: fix multiepg
Skin: fix wifi button
Update SVDownloader tnx Darlaist
Fix DTT module (dib0700 etc..)
Removed firmware for dtt in image
New WIFI Download panel
New Kernel Module Download panel
Added Ipk remove in Manual remove panel
Translate IT language tnx Pappaalfio
Added some string for translation
Moved "Mange addons extension" in Plugin menu
Added smargo decode in small/medium/full infobar
****Reduced image of another 5 mb**** (measures vary depending on the box)
:arrow: Tu klikni pre stiahnutie img ItalySat4.0-et9x00-SVN_074
ITALYSAT 4,0
Timeline
=============== Date: 09/12/2012, SVN 076 ==============
Fix stanby crash
Added Ntpdate (alternative metod for time update via internet)
Merge Enigma2 con OpenPLI 08/12 ore 21:00
Merge Oe con OpenPLI 08/12 ore 21:00
Update enigma2-plugins 85/12 ore 21:00
Added ntfs-3g for gigablue
Fix wifi load on start enigma2(da testare)
Fix DTT for all Box (da testare su larga scala)
Fix vuultimo update
:arrow: Tu klikni pre stiahnutie img ItalySat4.0-et9x00-SVN_076
Zpět na „Clarke-Tech ET9000 HD , Xtrend ET9x00 Images“
