Jak nastavit OSCam
Vše ohledně Oscamu
Dal poděkování: 36 poděkování
Re: Jak nastavit OSCam
Příspěvek od zilizila »
Tak jak psal tomík, dlho som písal. :roll:
Příspěvek od marsim21 »
jj mělo by to fičet já si toho ani na začátku nevšiml. :87:
bobika.99 Czech Republic
Příspěvek od bobika.99 »
Ano používám ApenATV 6.4, pořád černá obrazovka na klientovi
server:
[global]
logfile                       = /tmp/oscam.log;stdout
disablelog                    = 0
maxlogsize                    = 500
unlockparental                = 1
nice                          = -10
preferlocalcards              = 1
waitforcards                  = 1
saveinithistory               = 1
lb_mode                       = 1
lb_retrylimit                 = 1600
clienttimeout 				= 20000
[monitor]
port                          = 989
nocrypt                       = 127.0.0.1
aulow                         = 120
hideclient_to                 = 15
monlevel                      = 4
appendchaninfo                = 1
[cccam]
port                           = 12000
reshare                        = 0
version                        = 2.1.4
[dvbapi]
enabled                       = 1
au                            = 1
boxtype                       = dreambox
user                          = dvbapiau
pmt_mode                      = 6
[webif]
httpport                      = 8888
# httpuser                      = root
# httppwd                       = oscam
httphelplang                  = de
httprefresh                   = 10
httpallowed                   = 127.0.0.1,0.0.0.0-192.168.255.255
httphideidleclients           = 0
httpreadonly                  = 0
httpsavefullcfg               = 0
oscam.user
[account]
user                          = zero4k
pwd                           = zero4k
group                         = 1,2,3,4
uniq                          = 3
au                            = 1
[account]
user                          = dvbapiau
pwd                           = heslo
group                         = 1,2,3,4
uniq                          = 3
au                            = 1
log
2020/05/17 21:42:12 60849C70 c      (ecm) dvbapiau (0624@000000/0000/335B/58:C611CFDB2AD8D724E0F16299B3E9A4A1): found (82 ms) by Skylink_0624
2020/05/17 21:42:12 3A4A0AE7 c   (client) encrypted cccam-client 192.168.88.113 granted (zero4k, au=auto (3 reader))
2020/05/17 21:42:26 60849C70 c      (ecm) dvbapiau (0624@000000/0000/335B/58:CFD9C4B2D81710B7220AFF64CAEE1C9A): found (82 ms) by Skylink_0624
klient:
oscam.server
[reader]
enable 					= 1
label                         = servr
protocol                      = cccam
device                        = 192.168.88.117,12000
user                          = zero4k
password                      = zero4k
group                         = 1
cccversion                    = 2.1.4
cccmaxhops                    = 2
ccckeepalive                  = 1
audisabled                    = 1
log
2020/05/17 21:42:00 00000000 s      (net) monitor: initialized (fd=5, port=989)
2020/05/17 21:42:00 00000000 s   (reader) servr [cccam] creating thread for device 192.168.88.117
2020/05/17 21:42:00 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
2020/05/17 21:42:00 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
2020/05/17 21:42:00 387A30CD p   (reader) 192.168.88.117: resolved ip=192.168.88.117
2020/05/17 21:42:00 387A30CD p   (reader) servr [cccam] connecting to 192.168.88.117:12000
2020/05/17 21:42:00 387A30CD p   (reader) servr [cccam] connect failed: Connection refused
2020/05/17 21:42:00 387A30CD p   (reader) servr [cccam] proxy initialized, server 192.168.88.117:12000
2020/05/17 21:42:00 1A228C11 h    (webif) webif: decompressed 172266 bytes back into 414168 bytes
2020/05/17 21:42:00 1A228C11 h    (webif) HTTP Server running. ip=0.0.0.0 port=8888
2020/05/17 21:42:13 387A30CD p   (reader) servr [cccam] connecting to 192.168.88.117:12000
U klienta musí být taky přístupy v souboru oscam.user nebo tam nebude nic?
A máš tú IP servera na pevno? Lebo keď nie, tak je už možno na inej a klient ho nenájde.
bobika.99 píše: 17 kvě 2020, 21:55 U klienta musí být taky přístupy v souboru oscam.user nebo tam nebude nic?
U klienta stačí mať usera dvbapi.
IP adresy jsou napevno na routeru přes MAC a navíc na ně koukám přes webif, tam problém asi nebude.
Takže vo webif by si mal vidieť aj to, či máš pripojeného klienta na serveri a opačne. ???
Dal poděkování: 5 poděkování
postuduj uniq a ver na servery ked to vyzadujes
EnoSat píše: 17 kvě 2020, 22:12 postuduj uniq a ver na servery ked to vyzadujes
vůbec netuším co tím myslíš...
Skús vypnúť na serveri v account unique:
[account]
user                          = zero4k
pwd                           = zero4k
group                         = 1,2,3,4
uniq                          = 0
au                            = 1
Beze změny...
9000peter Slovakia
Příspěvek od 9000peter »
bobika.99 píše: 17 kvě 2020, 23:17 Beze změny...
Keď si uložil zmeny tak dúfam že si reštartol oscam!!!
Jasně, vždy na serveru i klientovi.
Zpět na „Oscam“
