Stránka 3 z 3
Re: HD+
Napsal: 29 črc 2010, 18:16
od Erzo
Preco nejde UPC direct a tiez je pripojene vonku. Predtym islo UPC. Zatial bez uspechu HD+.
2010/07/29 16:21:19 207 c01 hdbox (1801&000000/EF10/9C:ECFD): invalid (11 ms)
2010/07/29 16:21:19 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 16:21:19 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 16:21:19 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 16:21:26 207 c01 hdbox (1801&000000/EF10/9C:C864): invalid (11 ms)
2010/07/29 16:21:26 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 16:21:26 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 16:21:26 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 16:21:33 207 c01 hdbox (1801&000000/EF10/9C:3A1A): invalid (11 ms)
2010/07/29 16:21:33 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 16:21:33 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 16:21:33 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 16:21:35 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 16:21:37 207 c01 stapi: found new PMT_FILE /tmp/pmt1_1.tmp, pmt_cnt: 0
2010/07/29 16:21:37 207 c01 dvbapi: new program number: 7662 (STV 1)
2010/07/29 16:21:37 207 c01 dvbapi: set filter pid 160e, demux_index 0
2010/07/29 16:21:37 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 16:22:11 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 16:22:13 207 c01 stapi: found new PMT_FILE /tmp/pmt1_1.tmp, pmt_cnt: 0
2010/07/29 16:22:13 207 c01 dvbapi: new program number: 759B (Markiza)
2010/07/29 16:22:13 207 c01 dvbapi: set filter pid 15e6, demux_index 0
2010/07/29 16:22:13 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 16:22:24 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 16:22:26 207 c01 stapi: found new PMT_FILE /tmp/pmt1_1.tmp, pmt_cnt: 0
2010/07/29 16:22:26 207 c01 dvbapi: new program number: 75FF (TV JOJ)
2010/07/29 16:22:26 207 c01 dvbapi: set filter pid 15fb, demux_index 0
2010/07/29 16:22:26 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 16:25:22 207 c01 WARNING: ecm pending table overflow !
2010/07/29 16:25:32 207 c01 WARNING: ecm pending table overflow !
2010/07/29 16:25:42 207 c01 WARNING: ecm pending table overflow !
2010/07/29 16:25:52 207 c01 WARNING: ecm pending table overflow !
Re: HD+
Napsal: 29 črc 2010, 18:50
od Erzo
UPC uz mi ide. Zatial bez HD+. Skus sa pozriet kde je chyba.
Re: HD+
Napsal: 29 črc 2010, 19:45
si nepresny a snazis sa vymyslat si - ak nemas potrebne data. Provider moze mat maximalne 6 miest .
skus toto
Re: HD+
Napsal: 29 črc 2010, 20:12
od Erzo
Nefunguje.
2010/07/29 18:09:01 207 c01 hdbox (1830&000000/EF10/92:201F): invalid (10 ms)
2010/07/29 18:09:01 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:09:01 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:09:01 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:09:08 207 c01 hdbox (1830&000000/EF10/92:65A9): invalid (61 ms)
2010/07/29 18:09:08 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:09:08 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:09:08 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:09:15 207 c01 hdbox (1830&000000/EF10/92:5E5E): invalid (11 ms)
2010/07/29 18:09:15 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:09:15 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:09:15 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:09:22 207 c01 hdbox (1830&000000/EF10/92:EFAB): invalid (11 ms)
2010/07/29 18:09:22 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:09:22 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:09:22 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:09:29 207 c01 hdbox (1830&000000/EF10/92:35CD): invalid (10 ms)
2010/07/29 18:09:29 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:09:29 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:09:29 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:09:36 207 c01 hdbox (1830&000000/EF10/92:50C7): invalid (12 ms)
2010/07/29 18:09:36 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:09:36 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:09:36 207 c01 stapi: filter set demux_id 0, num 0
Re: HD+
Napsal: 29 črc 2010, 20:16
pouzivas oscam s dvbapi.
tam vo web rozhrani vidno ktore CAID pouziva dvbapi a ktore user hdbox. Nastav si automaticky refresh (napr5 sekund), alebo vzdy po prepnuti programu refreshni stranku a posli snimky toho web rozhrania. Je to 5 programov, tak 5 malych snimok nam ukaze kde je chyba.
Re: HD+
Napsal: 29 črc 2010, 20:25
od Erzo
2010/07/29 18:22:03 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:22:03 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:04 207 c01 hdbox (1830&000000/EF10/92:559E): invalid (11 ms)
2010/07/29 18:22:04 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:04 207 c01 dvbapi: set filter pid 1acc, demux_index 0
2010/07/29 18:22:04 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:08 205 p04 connect(fd=36) failed: (errno=110)
2010/07/29 18:22:08 205 p04 proxy cardsharing-cc.dyndns.org:20003 newcamd525 (fd=36)
2010/07/29 18:22:10 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:10 207 c01 stapi: found new PMT_FILE /tmp/pmt1_1.tmp, pmt_cnt: 0
2010/07/29 18:22:10 207 c01 dvbapi: new program number: EF11 (VOX HD)
2010/07/29 18:22:10 207 c01 dvbapi: set filter pid 1ace, demux_index 0
2010/07/29 18:22:10 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:11 207 c01 hdbox (1830&000000/EF11/92:659E): invalid (11 ms)
2010/07/29 18:22:11 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:11 207 c01 dvbapi: set filter pid 1ace, demux_index 0
2010/07/29 18:22:11 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:13 205 p04 connect(fd=36) failed: (errno=110)
2010/07/29 18:22:13 205 p04 proxy cardsharing-cc.dyndns.org:20003 newcamd525 (fd=36)
2010/07/29 18:22:16 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:17 207 c01 stapi: found new PMT_FILE /tmp/pmt1_1.tmp, pmt_cnt: 0
2010/07/29 18:22:17 207 c01 dvbapi: new program number: EF74 (SAT.1 HD)
2010/07/29 18:22:17 207 c01 dvbapi: set filter pid 1aea, demux_index 0
2010/07/29 18:22:17 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:18 207 c01 hdbox (1830&000000/EF74/92:C4DE): invalid (11 ms)
2010/07/29 18:22:18 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:18 207 c01 dvbapi: set filter pid 1aea, demux_index 0
2010/07/29 18:22:18 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:18 205 p04 connect(fd=36) failed: (errno=110)
2010/07/29 18:22:20 207 c01 hdbox (1830&000000/EF74/92:3124): invalid (11 ms)
2010/07/29 18:22:21 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:21 207 c01 dvbapi: set filter pid 1aea, demux_index 0
2010/07/29 18:22:21 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:24 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:25 207 c01 stapi: found new PMT_FILE /tmp/pmt1_1.tmp, pmt_cnt: 0
2010/07/29 18:22:25 207 c01 dvbapi: new program number: EF75 (ProSieben HD)
2010/07/29 18:22:25 207 c01 dvbapi: set filter pid 1aec, demux_index 0
2010/07/29 18:22:25 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:25 207 c01 hdbox (1830&000000/EF75/92:ED37): invalid (11 ms)
2010/07/29 18:22:26 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:26 207 c01 dvbapi: set filter pid 1aec, demux_index 0
2010/07/29 18:22:26 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:27 207 c01 hdbox (1830&000000/EF75/92:D09F): invalid (11 ms)
2010/07/29 18:22:27 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:27 207 c01 dvbapi: set filter pid 1aec, demux_index 0
2010/07/29 18:22:28 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:32 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:32 207 c01 stapi: found new PMT_FILE /tmp/pmt1_1.tmp, pmt_cnt: 0
2010/07/29 18:22:32 207 c01 dvbapi: new program number: EF76 (kabel eins HD)
2010/07/29 18:22:32 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:22:32 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:33 207 c01 hdbox (1830&000000/EF76/92:2379): invalid (11 ms)
2010/07/29 18:22:33 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:33 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:22:33 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:34 207 c01 hdbox (1830&000000/EF76/92:06B4): invalid (11 ms)
2010/07/29 18:22:35 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:35 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:22:35 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:41 207 c01 hdbox (1830&000000/EF76/92:21B0): invalid (11 ms)
2010/07/29 18:22:41 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:41 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:22:41 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:48 207 c01 hdbox (1830&000000/EF76/92:B8B3): invalid (11 ms)
2010/07/29 18:22:48 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:48 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:22:48 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:22:55 207 c01 hdbox (1830&000000/EF76/92:7E52): invalid (11 ms)
2010/07/29 18:22:56 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:22:56 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:22:56 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:23:02 207 c01 hdbox (1830&000000/EF76/92:9572): invalid (11 ms)
2010/07/29 18:23:02 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:23:02 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:23:02 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:23:09 207 c01 hdbox (1830&000000/EF76/92:2065): invalid (11 ms)
2010/07/29 18:23:09 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:23:09 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:23:09 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:23:16 207 c01 hdbox (1830&000000/EF76/92:FF13): invalid (10 ms)
2010/07/29 18:23:16 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:23:16 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:23:16 207 c01 stapi: filter set demux_id 0, num 0
2010/07/29 18:23:23 207 c01 hdbox (1830&000000/EF76/92:5032): invalid (10 ms)
2010/07/29 18:23:23 207 c01 stapi: filter removed demux_id 0, num 0
2010/07/29 18:23:23 207 c01 dvbapi: set filter pid 1aee, demux_index 0
2010/07/29 18:23:23 207 c01 stapi: filter set demux_id 0, num 0
Re: HD+
Napsal: 29 črc 2010, 20:28
vies spravit snimku stranky,resp. jej vyrez ? ty mi stale prikladas log - aj to neuplny (na uplny log si to nevies prepnut .) )
Re: HD+
Napsal: 29 črc 2010, 20:44
toto je snimka stranky ! z nej jasne vidno,ze hdbox pouziva sice spravne CAID ,ale klient nepouziva ziadne , takze to nedekoduje !
Re: HD+
Napsal: 29 črc 2010, 20:56
od Erzo
Vcera na UPC mi islo spolahlivo mgcamd a na oscame uz robi problemy. Cim viac skusam HD+ tak nejde UPC. HD+ uz nebudem pouzivat.
Re: HD+
Napsal: 29 črc 2010, 21:01
mam oscam , upc z cccam serveru a ide to absolutne v pohode.
musis byt presny - to je hlavna zasada .
Re: HD+
Napsal: 29 črc 2010, 21:08
od Erzo
Oscam nespohlivo pripaja na server a vypadne na off. Teraz som dal mgcamd hned nabehlo a je stale pripojeny.
Re: HD+
ked nevies rozchodit Oscam , skus pouzit mgcamd fixnuty na HD+ , predstav si - mame ho v downloade
a uz dost davno ...
http://www.forum.satdigitalne.cz/viewto ... 173&t=5426
Re: HD+
Napsal: 29 črc 2010, 21:10
ja na oscame nepouzivam nastavenia timeout a podobne- v oscam.server.
beztak to nefunguje spolahlivo a casove jednotky ,ktore su tam, rozhodne neznamenaju sekundy ,ale mne neznamu casovu mieru
Re: HD+
Napsal: 29 črc 2010, 22:16
od Erzo
Ani tamto nefunguje. Nevady aj tak dakujem. Hlavne ide UPC direct komplet.
