Oscam L2B
Vše ohledně Oscamu
pepanvl Czech Republic
Re: Oscam L2B
Příspěvek od pepanvl »
Prosím o radu
Mám přijímač VU+duo se, CI modul a kartu Skylink IRDETO M7
Jde sledovat jenom jeden kanál, PIP nebo současné nahrávání jineho je tma.
Stáhnul sem zde OSCam: 1.20_svn Build: r11715, nahradil původní binárku, ele nedaří se to rozchodit.
Výpis logu
2023/06/06 17:19:25 00000000 s     (main) Host name      = vuduo4kse
2023/06/06 17:19:25 00000000 s     (main) Release        = 4.1.45-1.17
2023/06/06 17:19:25 00000000 s     (main) Version        = #1 SMP Sat Sep 10 19:30:52 UTC 2022
2023/06/06 17:19:25 00000000 s     (main) Machine        = armv7l
2023/06/06 17:19:25 00000000 s     (main) Stb model      = dm8000
2023/06/06 17:19:25 00000000 s     (main) Stb vumodel    = vuduo4kse
2023/06/06 17:19:25 00000000 s     (main) Stb boxtype    = vuduo4kse
2023/06/06 17:19:25 00000000 s     (main) creating pidfile /tmp/oscam.pid with pid 1559
2023/06/06 17:19:25 00000000 s   (config) services reloaded: 0 services freed, 4 services loaded, rejected 0
2023/06/06 17:19:25 00000000 s   (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2023/06/06 17:19:25 00000000 s     (main) signal handling initialized
2023/06/06 17:19:25 00000000 s   (config) 2 provid's loaded
2023/06/06 17:19:25 00000000 s   (config) 21 service-id's loaded in 0 ms
2023/06/06 17:19:25 00000000 s      (net) newcamd: initialized (fd=3, port=1200)
2023/06/06 17:19:25 00000000 s      (net) -> CAID: 0000 PROVID: 001200
2023/06/06 17:19:25 00000000 s      (net) cccam: initialized (fd=4, port=12000)
2023/06/06 17:19:25 00000000 s   (reader) skylink_dolní [internal] creating thread for device /dev/sci0
2023/06/06 17:19:25 00000000 s   (reader) N+line_server [newcamd] creating thread for device VU
2023/06/06 17:19:25 00000000 s   (reader) Reader-2 [newcamd] creating thread for device VU
2023/06/06 17:19:25 22103906 r   (reader) skylink_dolní [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2023/06/06 17:19:25 22103906 r   (reader) skylink_dolní [internal] Reader sci internal, detected box type: vuduo4kse
2023/06/06 17:19:25 00000000 s     (main) waiting for local card init
2023/06/06 17:19:25 0DA5F2C0 p  (newcamd) proxy VU:0 newcamd525 (fd=0)
2023/06/06 17:19:25 0DA5F2C0 p        (-) -- Skipped 1 duplicated log lines --
2023/06/06 17:19:25 0DA5F2C0 p   (reader) N+line_server [newcamd] proxy initialized, server VU:0
2023/06/06 17:19:25 45060FBE p   (reader) Reader-2 [newcamd] proxy initialized, server VU:0
2023/06/06 17:19:25 6CF9EC6F h    (webif) webif: decompressed 159545 bytes back into 386200 bytes
2023/06/06 17:19:25 6CF9EC6F h    (webif) HTTP Server running. ip=0.0.0.0 port=8888
2023/06/06 17:19:27 00000000 s     (main) init for all local cards done
2023/06/06 17:19:27 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 0 ms
2023/06/06 17:19:27 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
2023/06/06 17:19:27 00000000 s     (gbox) local gbox failed init
2023/06/06 17:19:27 4CD7EC12 c   (client) plain dvbapi-client granted (dvbapiau, au=auto (3 reader))
2023/06/06 17:19:27 4CD7EC12 c   (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam.ccache
2023/06/06 17:19:27 4CD7EC12 c   (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 3 maximum number of filters is 64 (oscam limit is 64)
2023/06/06 17:19:27 4CD7EC12 c   (dvbapi) Detected /dev/dvb/adapter0/ca1 device, total available descramblers: 16
2023/06/06 17:19:31 4CD7EC12 c   (dvbapi) Demuxer 0 found 0 ECM pids and 5 STREAM pids in CA PMT
Poradí někdo?
Děkuji
Warder Slovakia
Re: Oscam L2B
Příspěvek od Warder »
Pises, a snad som to dobre pochopil, ze pouzivas kartu IRDETO M7 v CI module tak ti je akykolvek OSCAM na dve veci kedze ten s CI nepracuje. ;)
:89:
Re: Oscam L2B
Díky za rychlou odpověď.
Bohužel to tak asi bude, v tomhle modulu
https://interlink-static1.tsbohemia.cz/ ... 115689.jpg
mám katu která má vedle čipu napsáno: IRDETO 01
Takže jediná šance na současné nahrávání více programů je sehnat starší kartu do UNI čtečky.
Bude stačit tahle? https://elektro.bazos.cz/inzerat/169663 ... uly-ci.php
Pepa
Warder Slovakia
Re: Oscam L2B
Ak sa chces hrat s tou kartou pod OSCAMOM tak si ju musis strcit (samotnu kartu bez modulu) do slotu dole - do tej "STRBINY" a potom uz len nahrat spravnu verziu Oscamu ktora vie tu kartu "obsluhovat" + jeho patricne konfiguracne subory.....
:89:
Re: Oscam L2B
Dík za radu, kartu jsem dal do UNI čtečky nahrál bináku 11715 a už to jede, jenom je trochu problém u EMM, zkusím upravit nastavení nebo jinou binárku.
kenny69
Re: Oscam L2B
Příspěvek od kenny69 »
ahoj,..
mozem niekoho poprosit .. o bin oscamu co zvlada L2B nejaku poslednu verziu ...
dik moc
Dal poděkování: 5 poděkování
Re: Oscam L2B
a nestacia tie co su tu ?
kenny69
Re: Oscam L2B
len som sa spytal ci nahodou niekto nema alebo nevie kde by sa mohla nachadzat ... najnovsia
ale ano .. ak nieje nic novsie .. tak staci :)
Warder Slovakia
Re: Oscam L2B
A mozes nam prezradit ten rozdiel, ktory ti dosiahnes instalaciou tej tvojej "najnovsej" oproti tym ktore sa tu uz povaluju ? :colombo:
:89:
kenny69
Re: Oscam L2B
tato otazka je naco ?
mas-nema ... to je cele
Warder Slovakia
Re: Oscam L2B
kenny69 píše: 10 srp 2023, 11:33 ..... tato otazka je naco ? ......
Aby si nam prezradil, ze co take prevratne ocakavas od novej verzie co tunajsie verzie nemaju. :31:
:89:
spatko33
Re: Oscam L2B
Příspěvek od spatko33 »
...ahojte, prosím vás viete mi poradiť ako nastavit v oscame dekodovanie dvoch kariet Skylink ICE jedna cz region druhá sk region, príjmač Gigablue UE4K, niekde mám chybu a neviem kde, karty samostatne dekodujú
Ďakujem
oscam.server
[reader]
label = ICE_SK
enable = 1
protocol = internal
device = /dev/sci0
caid = 0624,0B00,0653
autospeed = 0
rsakey = FFFFFFFFFF722BEAF9F05AEA0897D355EF89144EDA9FBE91121A07F653A1CDEBD4C4292DD74F2D42DA03EDDF16484E3F07AE747F6CBA9E0FC71CDB7312A03ACB
force_irdeto = 1
dynamic_camkey = 1
needsemmfirst = 1
ecmtimeoutlimit = 1
group = 1
[reader]
label = ICE_CZ
enable = 1
protocol = internal
device = /dev/sci1
autospeed = 0
force_irdeto = 1
dynamic_camkey = 1
needsemmfirst = 1
ecmtimeoutlimit = 1
group = 1
Warder Slovakia
Re: Oscam L2B
Iba mala otazka. Preco silou mocou pchas skyshit karte caid-i Antiku a freeSATu ?
:89:
spatko33
Re: Oscam L2B
Warder píše: 28 zář 2023, 15:02 Iba mala otazka. Preco silou mocou pchas skyshit karte caid-i Antiku a freeSATu ?
...ďakujem, opravené, ale nepomohlo .
už som skúšal aj cez services, ale ani to nepomohlo, stále ide len jeden region keď prepnem medzi tak sa všetko sekne.
oscam.config
[global]
logfile = stdout
clienttimeout = 12000
unlockparental = 1
nice = -1
preferlocalcards = 1
[dvbapi]
enabled = 1
au = 1
pmt_mode = 1
delayer = 70
user = localcard
boxtype = dreambox
[webif]
httpport = 8888
#httpuser = root
#httppwd = oscam
httprefresh = 8
httphideidleclients = 1
httpallowed = 0.0.0.0-255.255.255.255
hideclient_to = 15
Warder Slovakia
Re: Oscam L2B
To ti nemalo pomoct riesit tvoj problem zo zdielanim 2 kariet ale to bola len mala otazka naco to tam pchas. :D
:89:
Zpět na „Oscam“
