Stránka 2 z 3
Re: RTi core RC11 Enigma 2
Napsal: 01 dub 2011, 20:55
od mkris
Áno, to viem, tam som to i zapísal, ale ako píšem, v "/dev" vôbec nie je také zariadenie (súbor) "/dev/sda1", "/dev/sda2"
... takže neviem čo na-mount-ovať do /media/hdd a /media/usb
Napsal: 01 dub 2011, 21:48
od anfro11
mkris píše:Áno, to viem, tam som to i zapísal, ale ako píšem, v "/dev" vôbec nie je také zariadenie (súbor) "/dev/sda1", "/dev/sda2"
Otvor si adresar etc v ktorom je subor fstab v nom su riadky /dev/hdb1/media/hdd auto defaults 0 0
a /dev/sda1 /media/usb auto defaults 0 0
Napsal: 01 dub 2011, 22:13
od robinek
Pokud neexistuji soubory /dev/sda, /dev/sda1 atd. pripadne sdb, tak mas problem s pripojenim usb disku.
Azbox jej proste nevidi. Soubory se totiz vytvori az po pripojeni a detekci usb disku.
Pripoj disk a zkus prikaz dmesg a uvidis co se deje. Mel bys tam videt detekci vcetne jeho typu atd.
root@AZBox:~# dmesg |grep usb
[14887.573000] usb 1-1: uevent
[14915.770000] usb 1-1: new high speed USB device using ehci_hcd and address 3
[14915.913000] usb 1-1: default language 0x0409
[14915.919000] usb 1-1: New USB device found, idVendor=1058, idProduct=1100
[14915.926000] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14915.933000] usb 1-1: Product: My Book
[14915.938000] usb 1-1: Manufacturer: Western Digital
[14915.943000] usb 1-1: SerialNumber: 57442D574341553436333734373830
[14915.951000] usb 1-1: uevent
[14915.980000] usb 1-1: usb_probe_device
[14915.984000] usb 1-1: configuration #1 chosen from 1 choice
[14915.994000] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[14916.001000] usb 1-1:1.0: uevent
[14916.017000] usb-storage 1-1:1.0: usb_probe_interface
[14916.022000] usb-storage 1-1:1.0: usb_probe_interface - got id
[14916.054000] usb-storage: device found at 3
[14916.058000] usb-storage: waiting for device to settle before scanning
[14916.074000] drivers/usb/core/inode.c: creating file '003'
[14917.281000] usb-storage: device scan complete
root@AZBox:~# cat /etc/fstab |grep sda
root@AZBox:~# mount /media/usb/
root@AZBox:~# mount|grep sda
/dev/sda1 on /media/usb type ext3 (rw,errors=continue,data=ordered)
root@AZBox:~# dmesg |grep -i ext3
[15397.692000] EXT3 FS on sda1, internal journal
[15397.697000] EXT3-fs: mounted filesystem with ordered data mode.
Napsal: 01 dub 2011, 23:04
od mkris
... Vďaka, po zadaní uvedených príkazov bol záver nasledovný:
root@AZBox:~# mount |grep sda
/dev/sda1 on /media/hdd type ext3 (rw,errors=continue,data=ordered)
[ 735.965000] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 735.972000] EXT3-fs: write access will be enabled during recovery.
[ 736.012000] EXT3-fs: recovery complete.
[ 736.017000] EXT3-fs: mounted filesystem with ordered data mode.
root@AZBox:~#
ale po následnom reštarte (počkal som asi 5 min. pre istotu) sa disk automaticky na-mount-oval do /media/hdd.
S tým diskom sa však muselo niečo stať, lebo som na ňom mal nakopírované nejaké videá a obrázky aj nejaké testovacie
nahrávky z RC9 a všetko to zmizlo.
I tak moc ĎAKUJEM za radu.
Napsal: 02 dub 2011, 10:32
od frcko73
zistil som,ze mi nejde PrimaHD...... :12:,dalej nefunguje Rescue Mode,vzdy mi to hodi Restart boxu.....
Napsal: 02 dub 2011, 11:57
od robinek
frcko73 píše:zistil som,ze mi nejde PrimaHD...... :12:,dalej nefunguje Rescue Mode,vzdy mi to hodi Restart boxu.....
potvrzuji .. rescue mode nejde
Napsal: 02 dub 2011, 15:43
od Stevo102
No tak to som zvedavi ako tampotom dame novu RC12 ked nejde rescue mode
Napsal: 02 dub 2011, 15:46
od robinek
Stevo102 píše:No tak to som zvedavi ako tampotom dame novu RC12 ked nejde rescue mode
Jednak to muzou opravit pres online update a nebo si lze pomoci tim, ze hodis patch.bin RC4 na flashku a pri bootu by to melo nabehnout do rescue (to jsem ale nezkousel)
Napsal: 02 dub 2011, 16:13
od dedecek_
Funguje to - vyzkoušeno. Vracím se takto i do origo softu.
Napsal: 02 dub 2011, 16:44
od frcko73
ak das na flasku akykolvek fw,strcis do boxu,vzdy to skoci do rescue mode.
Napsal: 02 dub 2011, 16:48
od Stevo102
Aha, tak to ma nenapadlo. Akurát som skúšal nastavenia HDMI, a funguje to správne len s nastavením 720p/50Hz. Nech nastavím čokolvek inak, tak po chvílke buď vyhodí error tuner alebo dáky PID error, a ani po prebudení zo standby nenabehne obraz. Takže jediná možnosť je nastaviť 720p/50Hz...
Napsal: 02 dub 2011, 17:38
od robinek
Tak tento problem ja nemam. A jelikoz to nikdo nehlasil jako bug, tak bych rekl, ze to je jen u tebe :roll:
Napsal: 02 dub 2011, 19:52
od frcko73
chlapy,to ozaj musite zbytocne citovat posledne prispevky? Potom je to neprehladne. Ved kazdeho napadne,ze odpovedate na posledny prispevok.
Napsal: 02 dub 2011, 20:08
od spejlo
mam podobny problem.. akurat som neskusal menit rozlisenie.. mam 1080i.. cas od casu mi napise aby som skontroloval tuner a jedina moznost je reboot.. signal vidim ale obraz ziadny.. vacsinou to robi ked viac krat prepinam.. inak tento problem mam od RC8
Napsal: 03 dub 2011, 10:51
od Stevo102
Ano presne toto sa mi stava, keď je tam ine nastavenie ako 720p/50 tak to vyhadzuje, inak nemusíš rebootovať, stačí ísť do nastavení A/V settings a zmeniť to na niečo iné a ono sa to rozbehne. Ale po nejakom čase ti to znova vyhodí, takže najjednoduchšie je dať tak ako som napísal a vyhneš sa týmto hláškam.
