Enigma2 - test verzia
Rei
Re: Enigma2 - test verzia
Emu Manger Panel:
Quote:
Originally Posted by arcibald
and/or
enigma2-plugin-glasssysutil_2.39_mipsel.ipk
Once these are installed, you just have correct the path for the file CCcam.cfg:
SGC_menu:
From SGC panel installed the CCcam 2.14 and go to the correct path and the environment (-dC /etc/CCcam.cfg) in the startup script CCcam_2.1.4.sh:
/usr/bin/CCcam_2.1.4
/etc/CCcam.cfg
/usr/cams/CCcam_2.1.4.sh
Glasssutil:
This will install various emu in the path:
/usr/UCM_CamSrv_bin # including cccam (2.0.11) & cccam214.
The startup scripts will find them in /usr/UCM_CamSrv_script:
Cccam_Cam.sh
Cccam214_Cam.sh
Then enter here the path and the environment (-dC /etc/CCcam.cfg) and you're done.
Now you can manage your CCcam from panel with their emu_manager and having a complete list of additional features.
Thanks ... to development teams of these plugins
Regards
and/or
SGC_menu:
/etc/CCcam.cfg
Glasssutil:
Cccam_Cam.sh
Cccam214_Cam.sh
Regards
Rei
Cvs emu:
Quote:
again, a big shift mower and others in the co
congratulations
those who threw the last enigma and video driver for codirane channels
here's my little contribution
cccam and mgcamd
cccam and mgcamd for azbox the plugin can start / stop / restart / cam info / autostart / desable autostart
installation
can manually via telnet but also with management software>> install local extensions>> internal flash
copy one by one file in / (that is the root of the image) to say totalcommander
upon installation, delete files or install in the order written down
and then delete one by one.
The order of installation
1.enigma2-plugin-extensions-userscripts_2.4-r4_mipsel.ipk
2.enigma2-plugin-camd-mgcamd.1.35a_2.4-r1_mipsel.ipk
3.enigma2-plugin-camd-cccam.2.1.4_2.4-r0_mipsel.ipk
4.napravi folder / var / etc for your cccam files
restart box
5.otidji the main menu plugins-user scripts user-execute script from / usr / script
there can do anything for the emu
for mgcamd course should you put in your config files if you use to cccam gbox or cs in / var / keys
6.a this is very important to put the emu radio mg_cfg for azbox with everything needed for cccam gbox or configuration
# box type
# 00 autodetect, change only if you think wrong type detected.
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox / mips
# 08 entered / kathrein
# 09 entered / ipbox
# 11 entered / openbox
b: {06}
so you have to make any necessary changes to your way of use in all files for mgcamd 1.35
it seems to me that mgcamd now works better than the azbox cccam but it takes longer to test.
Thanks to its author:thum:
congratulations
cccam and mgcamd
installation
restart box
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
b: {06}
alinko68
Stále mi to nenabíhá E, nevím proč??? Vše jsem udělal dle návodu, naběhlo geeko
a pak rescue mode, pak IP, tu jsem zadal do AZUP, všechno napsalo OK, ale AZBOX Premium stále píše na displeji 100% a nic a furt se snaží nabíhat do 100% nic a nic a nejde to ani znova updatovat. Co mám teď dělat??
To jsou teda návody na update!
alinko68
- gorick
Stala sa mi podobna vec,s tym rozdielom,ze mne E2 nabehla ok.Dnes som vsak chcel nahodit novy skin.Vsetko podla navodu,zvolil som skin v menu,nastal restart a potom problem.Na VFD displayi tahalo par krat do 100%, az to na tom seklo.Cez Azup som chcel vratit original FW,ale dalsi problem,ze vraj mam novy kernel.Problemy som vyriesil nasledovne:alinko68 píše:Stále mi to nenabíhá E, nevím proč??? Vše jsem udělal dle návodu, naběhlo geekoa pak rescue mode, pak IP, tu jsem zadal do AZUP, všechno napsalo OK, ale AZBOX Premium stále píše na displeji 100% a nic a furt se snaží nabíhat do 100% nic a nic a nejde to ani znova updatovat. Co mám teď dělat??
Z fora satpimps som stiahol subor BACK TO ORIGINAL FW.rar /prikladam/.V nom su 2 subory backup_kernel a update, ktore treba prekopirovat cez FTP do priecinkov v azboxe /backup_kernel do MMP a update do tmp (priecinok MMP som tam nemal,tak som si ho vytvoril)/.Potom som cez Maz spustil telnet a zadal prikazy:
Nasledne by sa mal spustit progres do 100, reboot a uz znama modra obrazovka s format AA.cd /tmp
chmod 755 update
./update /MMP/backup_kernel
Naposledy upravil(a) gorick dne 24 říj 2010, 15:33, celkem upraveno 2 x.
alinko68
Enigma 2 v1.0.27
Devices suitable for flashing : Elite and Premium
What is new :
- DiseQc FIX ( 1.0 , 1.1 , 1.2 Manual and USALS too )
- DVB-S2 FIX
- Integrated BlackShadow2 skin by Matrix10
- Fixed boot error
ATTENTION: Use AzUP v1.1 for Flashing this version of Enigma 2 into Your devices !!!
Download: http://www.azbox-enigma.eu/upload/E2_AZBox_1.0.27.rar
What is new :
- DVB-S2 FIX
- Fixed boot error
Naposledy upravil(a) vikino dne 26 říj 2010, 22:17, celkem upraveno 2 x.
jhrin
Enigma 2 v1.0.28
What is new :
- Fix for no signal on DVB-S2 tuner for some users
- Multimedia fix for various formats by sattomy
Download: http://azbox-enigma.eu/upload/E2_AZBox_1.0.28.rar
What is new :
AZBOX HD Elite, parabola Gibertini 90cm, okuliare na 3xLNB Invacom 0,3dB, DiSEq 4xLNB EMP Centauri, druzice 19,2 - 23,5 - 13,0., Pristup k UPC, SKYLINK, CSLINk. Reciever Onkyo TX-SR605.
- asconn
Podařilo se Vám někomu v E2 rozchodit CSLINK nebo SKYLINK kartu pomocí CA modulu?
Technotrend S2-3600 HD USB + Asus K52JC, AZBOX Elite HD (E2-OpenRSI-OpenPLI 3.0), Illusion M3-Kyng, Dreambox DM800HD, SkyLink ICE, SG 2100 USALS, Samsung LE40A559 Full HD, Samsung LE37C550
robinek
Jestli jsem to dobre pochopil, tak by mela byt E2 jiz pouzitelna - tedy co se tyce DVB-S2 tuneru, emulace (cccam a mgcam), prehravani MKV ?
Predpokladam ze nahravat to asi jeste neumi ze ?
pikas
Rei píše:Cvs emu:
congratulations
cccam and mgcamd
installation
restart box
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
b: {06}
Fungu je to!!! Mgcamd dekoduje!!!!!!!......
robinek
Nemohl by pls nekdo sepsat funkce ktere jsou jiz pouzitelne ?
Ani na ofiko webu se prakticky neda poradne zjistit co uz E2 pro Azbox umi. Zadny feature list jsem nenasel.
A priznam se ze se mi to tam nechce nalit abych pak zjistil ze to jeste nejde pouzivat a zase se vracet na ofiko fw
Diky
Diky
- Bárt
Tak co, má někdo zkušenosti už? Dokáže někdo už porovnat výhody a nevýhody oproti orig. fw.pro azbox? Nahrává Anigma?
lahr
Z toho co jsem četl plyne, že Enigma už umí :
-naladit kanály na tuneru
-neumí použít interní čtečku karet, takže zatím pouze nekódované kanály, nebo se připojit k serveru jako klient a použít kartu jiného přijímače
-po dohrání souborů už umí přehrávat i některé formáty filmů z HDD (toto by chtělo upřesnit, nevím jaké přesně formáty DivX, XviD, ? )
Co nevím :
- zda a jak funguje EPG ?
Pokud EPG umí, byl by to pro mě motiv , proč již nyní (v ranném stádiu ) na Enigmu přejít.
Věci jako Youtube, web prohlížeč, jsou dle mého názoru naprosto zbytečné.
Co nevím :
- hitman222
-Přehraje všechny formaty dokonce DTSlahr píše:Z toho co jsem četl plyne, že Enigma už umí :
Co nevím :
-EPG funguje vyborně
-přechod bych ještě nedoporučoval je tam problem,nenaskakuje zvuk
-je to ještě v procesu vývoje,ale hodně dobrého.
-na satpimps.com se dozvíš všechno
Dream800 HDse_OpenPli
Vu+Solo2_OpenPli
Cloud-ibox3_OpenPli
Dreambox 7020,Dreambox 500
Samsung UE46ES8000
motor SG2100(SKY Link)
Vu+Solo2_OpenPli
Cloud-ibox3_OpenPli
Samsung UE46ES8000
