Pomoc s wifi
Peterrr94
Re: Pomoc s wifi
Příspěvek od Peterrr94 »
vikino píše:tak pokial heslo k wifi rotru len hadas, tak to tazko pripojis.
Ale vyberam len zo styroch hesiel ine som tam nedal urcite a aj tak to stale napise skuste znova.Ty ked tam das ine ,tak ti to tiez napise?A este som sa chcel opytat v tom network service mam vsetko vypnute ,ma to tak byt???dik
Re: Pomoc s wifi
Ten postup som ti napisal vyssie. ked skusas rozne hesla o to to mas zlozitejsie. Vsak sa pozri do routru ake tam mas heslo: zadaj do web prehliadaca IP routru. Malo by byt 192.168.0.1 Ake je meno a heslo do routru sa ma nepytaj, uz neviem ake bolo defaultne. Heslo k wifi si nastavis, alebo pozries v Wireless Setup.
Network servis v boxe mozes pozapinat vsetko okrem DNS. Ale nema to vplyv na pripojenie do internetu cez router, ale na pripojenie do domacej LAN, FTP apod.
zbyneksk Czech Republic
Pomoc s wifi - heslo
Příspěvek od zbyneksk »
Tak si tam nastav nove heslo, to snad neni tak velky problem.
A at se ti neztrati, napis si ho treba zespodu na router nejakym centrofixem.
Peterrr94
Re: Pomoc s wifi
Takze takto to je:zadam http://192.168.0.1 hodi ma do toho menu ,tam stlacim wireless setup,tam stlacim na Wireless Connection Setup wizard ,s tade ma hodi do:
Welcome to the D-Link Wireless Security Setup Wizard
This wizard will guide you through a step-by-step process to setup your wireless network and make it secure.
Step 1: Set your Wireless Network.
Step 2: Set your Wireless Security Password
Stlacim next ,hodi ma do:
Step 1: SETUP YOUR WIRELESS NETWORK
Give your network a name, using up to 32 characters.
Wireless Network Name (SSID) Peter
1.Automatically assign a network key (Recommended)
To prevent outsides from accessing you network, the router will automatically assign a security key(also called WEP or WPA key) to your network.
2.Manually assign a network key
Use this option if you prefer to create your own key.
Use WPA encryption instead of WEP (WPA is stronger than WEP and all D-LINK wireless client adapters support WPA)
Stlacim next a hodi ma do:
SETUP COMPLETE!
Below is a detailed summary of your wireless security settings. Please print this page out, or write the information on a piece of paper, so you can configure the correct settings on your wireless client adapters.
Wireless Network Name (SSID) : Peter
Wep Key Length : 128 bits
Default WEP Key to Use : 1
Authentication : Open
Network Key : 9A6C8E7746A4FC8F565D849BF6
Note: In some smart wireless ultilities (e.g. DLINK wireless ultility or wireless zero configuration), you only select Wireless Network Name and enter Network Key to access Internet.
Stlacim save a je to.
Samozrejme som tam zadaval to tristomiestne heslo a neslo to a ked som ho zmenil a ulozil a potom som sa tam zase pozrel ,tak tam bolo zase toto heslo.
Re: Pomoc s wifi
chod do manualneho nastavenia a tam dole mas aktualne heslo, tak ho zmen a uloz.
Peterrr94
Re: Pomoc s wifi
Je to neuveritelne ,ale ide mi to :) Dal som namiesto toho WPA AES - WEP 64/128(open) a zadal 13 miestny kod stlacil som pripojenie ,potom nastavenie a vsetko krasne nacitalo a napisalo dokoncene a uz som len v systemovych nastaveniach pozeral ako pise IP Normalne(pripojene).Som tomu ani neveril,este som pozeral ,ci tam nemam pripojeny kabel :96: tymto chcem vsetkym podakovat,ale samozrejme najviac vikinovi ,ktory ma naviedol na spravnu cestu.Dik
tear12
Re: Pomoc s wifi
Příspěvek od tear12 »
to taky záleží jaké nastavení šifrování máš v routeru a obecně se moc šifrování wep nedoporučuje, protože i trochu schopný soused je schopen se ti během pár minut pomocí notebooku do tvé sítě nabourat, zatím neúčinější šifrování je wpa2 -aes pokud to podporuje tvůj router určitě je to lepší než wep (open) dáváš tak najevo že tvoje síť je otevřená a může se na ní kdokoliv připojit
hades
Re: Pomoc s wifi
Příspěvek od hades »
Já mám bezdrát zcela nezabezpečený šifrováním, ale mám nastavené filtrování MAC adres - povoleny jen dvě své. Myslím si, že je to bezpečnější a bezproblémové.
(Nejhorší smrt je z vyděšení)
tear12
Re: Pomoc s wifi
Pokud to máš nezabezpečené, není problém odposlechnout MAC adresu a použít útok Man-in-the-middle, kde hacker má tvou odposlechnutou MAC adresu a svůj notebook umístí mezi tvůj router a přístroj který máš přes wifi připojen a modifikuje pakety a ty ani nezjistíš že se něco děje to není dobré řešení :107:
hades
Re: Pomoc s wifi
Nikdy nejsem od routeru dál než 6m. Takže žádný hacker se mezi nás asi nedostane, jedině že by to hackla manželka. :lol:
Re: Pomoc s wifi
To "mezi" je mysleno obrazne, aby jsi se pak nekdy nahodou nedivil.
Vse zalezi na konstrukci budovy, vyskovem umisteni, umisteni vlastniho routru, respektive poloze anteny a sile vysilaneho signalu WiFi.
Pokud bude dostatek signalu, tak se nejaky sikula dostane i ze sousedniho 30-50 m vzdaleneho baraku.
Kdyz tak si precti pekny clanek - Surfujeme zdarma v cizí Wi-Fi ...(Chip 07/2009).
Zbavte se spolusurfařů
Náš trik se zneužitím DNS funguje jen u hot-spotů, za které chce pronajímatel zaplatit.
U domácích access pointů a routerů je třeba na několika frontách provést opatření, aby se
k nim nikdo nepřipojil.
ZABEZPEČENÍ ROUTERU
Když vybalíte router z krabice a připojíte ka-bely, většinou už funguje. I notebook se sám
připojí k otevřené Wi-Fi a vše se zdá v pořádku. Většina uživatelů se proto ani nesnaží
nic měnit a nechá Wi-Fi tak, jak je. To je ovšem ten nejhorší případ – Wi-Fi síť je
nezabezpečená, kdokoliv se k ní může přihlásit a změnit nastavení routeru. Je proto třeba
provést potřebná zabezpečení. Jak zabezpečení provést, to si ukážeme na
routeru AirLive WN-300R. Spusťte internetový prohlížeč a zadejte adresu
http://192.168.1.254. Výchozí adresu svého routeru najdete v návodu, někdy bývá adresa
napsaná na spodní části routeru. Router bude požadovat uživatelské jméno a heslo.
Jméno zadejte »admin«, heslo »airlive«. V menu poté zvolte »Password«.
Router bude vyžadovat napsání starého hesla (airlive) a dvakrát budete muset zadat
nové heslo. Doporučujeme zvolit délku aspoň osm znaků.
cila70 Hungary
Re: Pomoc s wifi
Příspěvek od cila70 »
Ja mam tiez problem wifi routerom.Mam DRAYTEK VIGOR 2700 VGST router! Ako mozem zistit ake heslo mam napisat do Azboxu?Lebo siet najde ale ja neviem ake heslo mam napisat?
DREAMBOX 920 UHD , AZBOX PREMIUM PLUS 500gb
Re: Pomoc s wifi
ip adresa routru byva 192.168.1.1 alebo 192.168.0.1, mas to v navode. Zadaj ju do web prehliadaca v PC a nacita ti stranku tvojho routra. Je potrebne sa prihlasit. Defaultne meno heslo byva admin admin, ak je ine, tiez najdes asi v navode. Po prihlaseni sa dostanes do nastaveni tvojho routra a vo Wireless Setup si nastav heslo, uloz.
Blackfire
Dal poděkování: 5 poděkování
Re: Pomoc s wifi
Příspěvek od Blackfire »
cila70 píše:Ja mam tiez problem wifi routerom.Mam DRAYTEK VIGOR 2700 VGST router! Ako mozem zistit ake heslo mam napisat do Azboxu?Lebo siet najde ale ja neviem ake heslo mam napisat?
A neskusal si pripajat sa s Notebookom? Resp. od koho mas net, niektorí provideri pouzivaju rodne čislo ako default heslo pre wi-fi :-)
AZBOX Premium, LNB Inverto Black ULtra, SG2100, Gital, WI-FI, Interny HDD wd 2.5" scorpio blue 500gb, plazma Samsung PS50, pes
Zpět na „Dotazy začátečníků“
