MaZ / správca súborov
Užitečné programy
tear12
Re: MaZ / správca súborov
Příspěvek od tear12 »
Dovolil jsem si upravit češtinu z verze 2.3.0.0 na 3.0.0.0 od Golema, tak doufám že to nevadí ;) Soubor cz.lng stačí nakopírovat do složky s Maz a po spuštění Mazu v nastavení vybrat cz.
riki100
Příspěvek od riki100 »
MaZ v.3.1 - Manager for AzBox Hd
by morser
Changelog:
- Now do not download the list of plugins and FIRMS at startup, a button has been enabled to do so if you want but it has left an option to be able to do well at first as usual.
- Fixed problem with KingOfSat
- Fixed bug when you save the backup from the list of channels in Win7
- Now is not the list of most downloaded plugin and firmware at startup, and it added a button to do so if required, there is the possibility to set the program to automate this as in the previous version.
MaZ 3.2
- Fixed problem with downloads of 16 º E KOS
- Added Brazilian Portuguese language, thanks segroll.
- Modified the Catalan language by pe.tardo last, thanks.
- Modified the Italian language by Dr. Who last sent, thanks.
- Fixed problem with lists of suppliers for 5209 firmwares on. This was not a problem of maize but the conversion of the channel lists version 9 to version 10 that made the firmware, now send the list from Maz, if you have a firm upper 5209 or send the list with the number from version 10 for the firmware does not change.
- Made changes to use the lists of Premium A + with a tuner other than the SAT.
The changes I have made ​​fast and have not tried a lot, especially the issue of Premium + because I have an Elite and I can not prove anything and now I have also since E2, so if you see something strange what you say
riki100
MaZ 3.2.app.for.Mac OSx
Zpět na „Utility AzBox HD“
