Skylink nastavenie oscam problem
Vše ohledně Oscamu
300319 Austria
Re: Skylink nastavenie oscam problem
Příspěvek od 300319 »
2024/03/03 19:13:49 00000000 s (main) init for all local cards done
2024/03/03 19:13:49 00000000 s (emmcache) loaded 565 emmcache records from /etc/tuxbox/config/oscam.emmcache in 5 ms
2024/03/03 19:13:49 00000000 s (emmcache) loaded 36 emmstat records from /etc/tuxbox/config/oscam.emmstat in 0 ms
2024/03/03 19:13:49 00000000 s (gbox) local gbox failed init
2024/03/03 19:13:49 102EBC67 c (client) plain dvbapi-client granted (dvbapiau, au=auto (5 reader))
2024/03/03 19:13:49 102EBC67 c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam.ccache
2024/03/03 19:13:49 102EBC67 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum number of filters is 64 (oscam limit is 64)
2024/03/03 19:13:49 102EBC67 c (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 8
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0624 ECM_PID: 0474 PROVID: 000000
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0D96 ECM_PID: 0475 PROVID: 000000
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0500 ECM_PID: 0476 PROVID: 051910
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 047B PROVID: 000000
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0B02 ECM_PID: 047C PROVID: 000000
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 ecmpid 5 CAID: 181D ECM_PID: 047D PROVID: 000000
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 found 6 ECM pids and 8 STREAM pids in CA PMT
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 0
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 0624 PROVID 000000 ECMPID 0474 ANY CHID PMTPID 044C VPID 0456
2024/03/03 19:13:54 64E97FA9 r (reader) SKYLINK [irdeto] Maybe you don't have the entitlements for this channel
2024/03/03 19:13:54 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:5282B55C15E544ED3B54CE06897CF87E): not found (51 ms) by SKYLINK
2024/03/03 19:13:54 102EBC67 c (dvbapi) Demuxer 0 restarting decoding requests after 0 ms with 1 enabled and 5 disabled ecmpids!
2024/03/03 19:13:55 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:5282B55C15E544ED3B54CE06897CF87E): not found (1 ms) by SKYLINK
2024/03/03 19:13:55 102EBC67 c (dvbapi) Demuxer 0 restarting decoding requests after 1 ms with 1 enabled and 5 disabled ecmpids!
2024/03/03 19:13:55 102EBC67 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 0624 PROVID 000000 ECMPID 0474 ANY CHID PMTPID 044C VPID 0456
2024/03/03 19:13:56 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:5282B55C15E544ED3B54CE06897CF87E): not found (1 ms) by SKYLINK
2024/03/03 19:13:56 102EBC67 c (dvbapi) Demuxer 0 restarting decoding requests after 1 ms with 1 enabled and 5 disabled ecmpids!
2024/03/03 19:13:56 102EBC67 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 0624 PROVID 000000 ECMPID 0474 ANY CHID PMTPID 044C VPID 0456
2024/03/03 19:13:57 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:5282B55C15E544ED3B54CE06897CF87E): not found (0 ms) by SKYLINK
2024/03/03 19:13:57 102EBC67 c (dvbapi) Demuxer 0 restarting decoding requests after 1 ms with 1 enabled and 5 disabled ecmpids!
2024/03/03 19:13:57 102EBC67 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 0624 PROVID 000000 ECMPID 0474 ANY CHID PMTPID 044C VPID 0456
2024/03/03 19:13:57 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:5282B55C15E544ED3B54CE06897CF87E): not found (12 ms) by SKYLINK
2024/03/03 19:13:57 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:E64408565C8A09656D3C9B69620C9C2A): found (76 ms) by SKYLINK
2024/03/03 19:14:07 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:A91F6CBD39CCF79367CDCF0B3639FCF4): found (73 ms) by SKYLINK
2024/03/03 19:14:17 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:C2930729B9878EFD253B4F0EB5A1C3A0): found (72 ms) by SKYLINK
2024/03/03 19:14:27 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:769186F59291B69FB4E04F2AC10E517A): found (72 ms) by SKYLINK
2024/03/03 19:14:37 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:8B2FC72D4BF83248923A6EEC921562C5): found (73 ms) by SKYLINK
2024/03/03 19:14:47 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:8472374DC9EE0BD1D0F244AC93734A77): found (72 ms) by SKYLINK
2024/03/03 19:14:57 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:E757E9FC3D4FE7100B4EE1D55CE28D21): found (73 ms) by SKYLINK
2024/03/03 19:15:07 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:A53D95AE2DCF3150C6F4054A085E6EA3): found (72 ms) by SKYLINK
2024/03/03 19:15:17 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:30281574E87F978301F0BB1E5F615859): found (89 ms) by SKYLINK
2024/03/03 19:15:23 64E97FA9 r (reader) SKYLINK [irdeto] dvbapiau emmtype=global, len=30 (hex: 0x1E), cnt=0: error (34 ms)
2024/03/03 19:15:27 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:2362F8D950570BC6527631FB89527397): found (72 ms) by SKYLINK
2024/03/03 19:15:37 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:42B3DE1A5292A26E871E731AF0F95B60): found (73 ms) by SKYLINK
2024/03/03 19:15:47 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:79F8AC83A2BC0AEB73638114128E712C): found (72 ms) by SKYLINK
2024/03/03 19:15:57 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:0E52152F3FDBEA9564FE8B1D05E7A65A): found (94 ms) by SKYLINK
2024/03/03 19:16:07 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:9745420101D0E2535E56847B1042A147): found (72 ms) by SKYLINK
2024/03/03 19:16:17 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:1896DCA2C9CCE8A138ECFB45A8358E04): found (72 ms) by SKYLINK
2024/03/03 19:16:27 102EBC67 c (ecm) dvbapiau (0624@000000/0000/1F41/5C:C9EF3526AF703C666D9228E81BA44CEC): found (73 ms) by SKYLINK
300319 Austria
Re: Skylink setting problem
Dobrý večer. Omlouvám se, jestli jsem udělal protokol příliš velký. Nyní jsem přešel na Prima Krimi HD. Tento kanál by měl být součástí mého balíčku.
[reader]
label = SKYLINK
protocol = smartreader
device = Serial:Reader 07E10C3
caid = 0624
boxkey = A1C6F3D8B5E1F2C1
rsakey = 79EA25A763DA2C3E02B456A13962E60BCE63E628A2C177BE951CED96A9C6131A146F98D5867B7AE6682324FD6481913C0241F065C8D3457E54BB59B7B5DE0362
force_irdeto = 1
detect = cd
mhz = 600
cardmhz = 600
group = 3
emmcache = 0,1,1,0
lb_weight = 300
2024/03/03 19:24:12 102EBC67 c (dvbapi) Demuxer 0 restarting decoding requests after 1 ms with 1 enabled and 4 disabled ecmpids!
2024/03/03 19:24:12 102EBC67 c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0624 PROVID 000000 ECMPID 1798 ANY CHID PMTPID 1770 VPID 177A
2024/03/03 19:24:12 102EBC67 c (ecm) dvbapiau (0624@000000/A000/36EC/59:FF9793BBC4ED73E798BE7F1539EDB828): not found (0 ms) by SKYLINK
2024/03/03 19:24:12 102EBC67 c (ecm) dvbapiau (0624@000000/A000/36EC/59:FF9793BBC4ED73E798BE7F1539EDB828): not found (1 ms) by SKYLINK
2024/03/03 19:24:12 102EBC67 c (dvbapi) Demuxer 0 restarting decoding requests after 0 ms with 1 enabled and 4 disabled ecmpids!
300319 Austria
Nainstaloval jsem tento Oscam do Dreamboxu:
oscam-1.20_svn-satlodge-team11734-799-arm-newnigma2-linux-gnueabihf-ssl-libusb
Myslím, že by to mělo fungovat.
Dekuji mocrkat za pomoc!!
berrysam Austria
Příspěvek od berrysam »
300319 píše: 03 bře 2024, 19:42 Nainstaloval jsem tento Oscam do Dreamboxu:
Myslím, že by to mělo fungovat. :107:
[reader]
label                         = M7_L2b
autospeed                     = 0
caid                          = 0624
rsakey                        = 1B4368AD00D5AE23977576FCB202D84897994B358F006B42CB4BCC2301D1FAE2BCF4C397ED4DC7DE6DCE4A1A3D88682DB672827831FA8E6B6E29E7AD37D0A21F
force_irdeto                  = 1
needsemmfirst                 = 1
detect                        = cd
ident                         = 0624:000000
group                         = 1
emmcache                      = 1,3,15,0
blockemm-unknown              = 1
Naposledy upravil(a) berrysam dne 04 bře 2024, 08:55, celkem upraveno 1 x.
300319 Austria
Dobrý večer!
Dobrý večer! Díky za tip na instalaci správného Oscamu. Jen jsem musel do souboru Oscam.server vložit carmhz=600. Nyní jsou tam všechny kanály! Moc děkuji za pomoc! Skvělé!!!
300319 Austria
Dobrý den! V podstatě všechny kanály v balíčku fungují. Můj dotaz zní, proč vždy trvá 20 minut, než se karta znovu rozsvítí... Dekuji za odpoved!
pilarcik Slovakia
Dostal poděkování: 11 poděkování
Re: Oscam download podpora l2b m7 karty
Příspěvek od pilarcik »
U tejto verzie OSCam_11750-800 si nemusite lamat hlavu ani s RSA ani BOX klucom.netreba ho zadávať.
Staci vam jednoducha "minimalisticka" konfiguracia citacky.
[reader]
label = M7
protocol = internal
device = /dev/sci0
caid = 0624
force_irdeto = 1
detect = cd
group = 1
emmcache = 1,3,15,0
Dal poděkování: 6 poděkování
vtedy oscam spracuje EMM-U pre danu kartu
fevlad
Dal poděkování: 5 poděkování
Příspěvek od fevlad »
funguje aj na share?
300319 Austria
Omlouvám se za svou neznalost. To znamená, že je to normální a je třeba počítat s určitou čekací dobou. Pochopil jsem to správně? Děkuji mnohokrát!
Warder Slovakia
Příspěvek od Warder »
:89:
pilarcik Slovakia
Funguje bez problémov aj na share aj reshare
cardak Slovakia
Příspěvek od cardak »
Prosím o radu ako ho nainštalovať keď nemá koncovku ipk?
nijak, prepises uz naistalovany tymto
pilarcik Slovakia
Enosat vieš koľko ľudí to nevie a treba im to pracne písať. dakedy je to na nervy ale v pohode keď ma človek časť Dakedy tomu nechápem toľko je toho o tom ako sa to inštaluje popísané po známych fórach. Ale nie nikomu sa nechce hľadať a trochu vynaložiť úsilia. Pohodlnejšie je napísať a babo raď. No čo už.
Zpět na „Oscam“
