OpenATV image
Fishburn
Re: OpenATV image
Propadlé zápisy na kartě proved refresh ... a restartuj box
Formuler F4 Turbo Combo hevc
anfro11
Re: OpenATV image
To je prve co som skusal, ale v tom to nebolo. Niekde mi chyba nieco doplnit/zmenit v nastaveni stanice?PiD
Fishburn
Re: OpenATV image
Mel jsem podobný problém a pomohlo to ,ale pod cccamem ( ale ne staženém v přístroji), ale stahnul jsem zde s fora cccam 2,3,0 a tam mi zápisy prošli
JohnCenaWWE
Re: OpenATV image
hosi xcem ist na tento image poradte mi ako mam postupovat mam open 2,1 kernel 2,66 co mam urobit najprv?nahrat kernel?aky azup?dik
a este openATV vie blindscan?
Bond
Re: OpenATV image
Prechadzal som na OpenATV presne z tohto image co mas aj ty. Image OpenATV uz obsahuje kernel, tak len jednoducho spustis box v rescue mode, spustis AZUp napises IP adresu co je na boxe a spustis instalaciu. Instalacia mi prebehla a uz si postahujes pluginy ake chces. Ja som si dal Cccam 2.3.0
JohnCenaWWE
Re: OpenATV image
ID Team : OE-A
ID Enigma : Alliance
Version : .
About E2 : Enigma2
Kernel : ULK-3.9.2
22:02:14 > Connecting...
22:02:16 > Login...
22:02:16 > Login Success.
22:02:16 > Checking kernel ver...
22:02:17 > You have NEW kernel in your AZBox
22:02:17 > Getting Enigma Info...
22:02:17 > Detect E2 in AZBox - NOK
22:02:17 > Checking files...
22:02:18 > Checking files - done
22:02:18 > Overclock Checking...
22:02:18 > Your AZBox is not OverClocked.
22:02:18 > Checking rescue mode...
22:02:19 > Rescue mode - OK
22:02:55 > Free RAM Checking...
22:02:56 > Free RAM = 81148 KB
22:02:56 > Sending Kernel ...
22:02:58 > Sending Kernel - Done
22:02:58 > Copying kernel...
22:06:30 > Copying kernel - Done
22:06:30 > Switching to UnLicensed Kernel...(1 | 0)
22:06:39 > Switching to UnLicensed Kernel Done
22:06:39 > Storage Device Checking...
22:06:40 > Storage Device Checking - Done
22:06:40 > Creating Partitions...
22:06:40 > Size of DOM Checking...
22:06:41 > Size of DOM = 256 MB
22:06:47 > Creating Partitions - Done
22:06:48 > Formatting Partitions...
22:06:56 > Formatting Partitions - Done
22:06:56 > Preparing...
22:06:56 > Free RAM Checking...
22:06:56 > Free RAM = 79392 KB
22:06:58 > Sending E2 Image ...
22:07:09 > Sending E2 Image - Done
22:07:10 > Image Size Checking...
22:07:12 > Image Size = 98 M
22:07:12 > Copying E2 files...
22:08:20 > Copying E2 files - Done
22:08:20 > Finalising Installation
22:08:21 > Removing tmp files...
22:08:25 > E2 installed successfully.
22:08:25 > Rebooting... after ~5sec
AZUP 2.2.7
Version : .
About E2 : Enigma2
Kernel : ULK-3.9.2
22:02:16 > Login...
AZUP 2.2.7
JohnCenaWWE
Re: OpenATV image
hosi ako som nainstaloval flashexpander mi moutnute usb zmizlo z media/usb
a vsetky veci co som mal na usb su v /usr/ neznate ked stahujem pluginy ci to dava rovno na usb?tak isto aj filmy lebo v media/nic neni a ked stahujem daco tak usb blika,
- VraKo
Re: OpenATV image
JohnCenaWWE píše:ID Team : OE-A
Version : .
About E2 : Enigma2
Kernel : ULK-3.9.2
Zkus mrknout do info o programu, tam mi píše kernel 3.3.1
JohnCenaWWE
Re: OpenATV image
aj mne nechapem preco potom v Azupe pise 3.9.2 a v menu 3.3.1
ale idem asi prec je to strasne pomale
Bond
Re: OpenATV image
Presne ako pises v Azupe pise 3.9.2 a v menu 3.3.1. Ja som instaloval na redukciu SD karty namiesto DOM. Inak maju uz kernel 3.9.2 ale je to este beta verzia. Odkaz je od goricka z 27 Júl 2013, 19:57 na prvej strane tohto vlakna.
JohnCenaWWE
Re: OpenATV image
ID Team : OpenRSI
ID Enigma : OpenRSI_for_Azbox
Version : 3.0
About E2 : Enigma2
Kernel : ULK-3.3.1
18:10:05 > Connecting...
18:10:06 > Login...
18:10:07 > Login Success.
18:10:07 > Checking kernel ver...
18:10:07 > You have NEW kernel in your AZBox
18:10:07 > Getting Enigma Info...
18:10:08 > Detect E2 in AZBox - NOK
18:10:08 > Checking files...
18:10:09 > Checking files - done
18:10:09 > Overclock Checking...
18:10:09 > Your AZBox is not OverClocked.
18:10:09 > Checking rescue mode...
18:10:10 > Rescue mode - OK
18:10:25 > Free RAM Checking...
18:10:26 > Free RAM = 83700 KB
18:10:26 > Sending Kernel ...
18:10:33 > Sending Kernel - Done
18:10:33 > Copying kernel...
18:12:53 > Copying kernel - Done
18:12:54 > Storage Device Checking...
18:12:54 > Storage Device Checking - Done
18:12:54 > Creating Partitions...
18:12:54 > Size of DOM Checking...
18:12:55 > Size of DOM = 256 MB
18:13:02 > Creating Partitions - Done
18:13:03 > Formatting Partitions...
18:13:11 > Formatting Partitions - Done
18:13:11 > Preparing...
18:13:11 > Free RAM Checking...
18:13:12 > Free RAM = 82416 KB
18:13:13 > Sending E2 Image ...
18:13:21 > Sending E2 Image - Done
18:13:21 > Image Size Checking...
18:13:23 > Image Size = 100 M
18:13:23 > Copying E2 files...
18:14:31 > Copying E2 files - Done
18:14:31 > Finalising Installation
18:14:32 > Removing tmp files...
18:14:35 > E2 installed successfully.
18:14:35 > Rebooting... after ~5sec
Version : 3.0
About E2 : Enigma2
Kernel : ULK-3.3.1
18:10:06 > Login...
JohnCenaWWE
Re: OpenATV image
no cakal som trosku viac ale asi sa vraciam na 2,1 pretoze ta mi sedela najviac aj rychlost je lepsia ako u 3,0
JohnCenaWWE
Re: OpenATV image
nainstaloval som si OpenATV na usb ale ked som nahodil HBBtv tak nejde pise its no running web browser
JohnCenaWWE
Re: OpenATV image
aj u vas?
anfro11
Re: OpenATV image
Testnul som to (hbbtv) vcera a chodilo to OK.
