fw 1.07.89
Re: fw 1.07.89
Mne prijímač s fw 1.07.89 + mgcamd nahrával bez problému. Skontroluj si config mgcamdu
Potom ako ho upravíš reštartni mgcamd
# EMM messages
#    00 don't show any EMMs (default)
#    01 show only valid EMMs
#    02 show valid and bad EMMs with complete data display
M: { 00 }
# ECM messages
#    00 don't show anything about ecm
#    01 normal mode, show pids processed, decoded ecm and cw
#    02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
#    00 disable, no emm pids processed
#    01 enable, emm pids always processed for soft-au and shared cards
#    02 auto, emm started only if channel cant be decoded
#    03 process emm pids for network cards update only
A: { 02 }
# key update (sum 01 or 02 with 04)
#    01 update only new keys, default setting
#    02 update all keys (used for valid PMK checking)
#    04 enable TPS au
#    + tps au pid
U: { 02 } 0x12c0
# config files folder (softcam, autoroll, ignore/priority)
#    00 files in /var/keys
#    01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
#    00 no network (default)
#    01 newcamd netclient
#    02 radegast netclient
#    04 camd3 netclient
#    08 gbox netclient
G: { 01 }
# network retry, use summ for several options
#    00 disable
#    01 retry every new ecm
#    02 try to connect to offline shares every Q: seconds
#    04 try to detect and fast reconnect to lost (and not used atm) server
#    + XX messages number and YY seconds to reconnect
#    mg will reconnect to server, if no answer to last XX ecm/keepalive or
#    if no answer for last ecm or keepalive sent for YY seconds
#    set to 0 to disable
N: { 07 } 5 30
# network ecm timeout in seconds
K: { 02 }
# newcamd dead routes connect retry, sec
Q: { 600 }
# network shares priority
# 00 gbox, newcamd, radegast, camd3 (default)
# 01 camd3, radegast, newcamd, gbox
# 02 newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
#    00 No OSD (default)
#    01 neutrino
#    02 enigma
#    03 relook
#    + user password for http auth
O: { 01 } root newcs
# on screen display Options, summ of:
#    01 show emu ecm
#    02 show network shares messages
#    04 show decoding failed / fta
#    08 show emm keys update
#    + web port to use for osd
S: { 03 } 8080
# Log option, summ of:
#    00 off
#    01 network udp log
#    02 log to console
#    04 file, appended ! delete it by yourself, before it eat all your hdd
#    + IP udp-port log-file-name
L: { 02 } 127.0.0.1 28007 /tmp/mgcamd.log
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 15 }
# cache option, summ of:
#    00 Off (default)
#    01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
#    02 Ecm data cache, remember CW for (E:) time
#    04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 07 }
# reread files, summ of:
#    00 No (default)
#    01 reread config file on channel change (including priority and ignore, but not replace/cache)
#    02 reread SoftCam.Key on channel change
#    04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 00 }
# box type
# 00 autodetect, change only if you think wrong type detected.
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 12 Fortis
B: { 12 }
# urls for aes keys update, any number or urls allowed,
# url data must contain key in format 0500:007C00:0000000000:00:key1:keyl
# W: { http://some.host.com/keys.php }
Libor73
Re: fw 1.07.89
Příspěvek od Libor73 »
jerry píše:
v newcs.xml staci prepnut v <newCSconfig><newcamdserver><user><au>off</au>.
to mam,
v priority.list:
V: { 02 07 10 }
#X: { 0D 0F }  #gital (cslink) karta
X: { 0D 03 }  #Skylink biela karta
#X: { 0D 70 }  #Skylink modra karta
#X: { 0D 00 }  #Skylink modra karta
# pre nepouzivane karty je potrebne pred zaznam pridat #
#X: { 0D 02 }  # UPC Cryptoworks karta
kartu mam bilou T&T, pouze s napisem Trade and Technology
MartinK. Czech Republic
Re: fw 1.07.89
Příspěvek od MartinK. »
[quote="dempsey"]Mne prijímač s fw 1.07.89 + mgcamd nahrával bez problému. Skontroluj si config mgcamdu
Celé jsem to zkopíroval a dal do mého configu a pořád stejný problém u nahraného souboru se objeví znak "€" a je to tma bez zvuku.
maximální spokojenost
Re: fw 1.07.89
zmaz zoznam programov a naskenuj znovu .
ja mam zas opacny problem - nikdy sa mi nepodarilo nahrat kodovany program. Raz som chcel nasimulovat taky stav. samozrejme,ze ked som vytiahol kartu, tak nedekodovalo, ale s vlozenou kartou sa mi to nikdy nepodarilo . a to som zmazal aj pomocne ignore a priority. Hold- kazdy sme v niecom iny dobry .
Inak - existuje aj program na PC - offline decoder.
Re: fw 1.07.89
Tak som to znovu skontroloval:
Nahrať nahrá ale zakódovaný. Bezprostredne po nahratí to ide, ale asi na staré ECM.
Idem to skúsiť v Enigme - ale musím znovu naformátovať disk...
Re: fw 1.07.89
V Enigme / používam AAF Olympia / to nahráva dekódované. :)
Re: fw 1.07.89
1.07.89 uz ma cast novych driverov, tak mozno pomoze zakazanie prechodu emm . v mg_cfg . potom aj zalezi na verzii mgcamdu , nasilu tam davat 1.35 verziu netreba a mysmim,ze vezria 1.33 bola celkom dobre odladena. vlastne je to vsetko o verzii lib , ktore pouziva (su sucastou fw ) .
Ja som napriklad 1.07.89 vskutocnosti ani nemal v prijimaci- Mal som 1.07.86 a potom som uz len enigmu pouzival.
Libor73
Re: fw 1.07.89
grantec píše:Silne zalezi od toho ,co si myslis, ze si "blokol". V zasade na bezproblemovy chod je treba bloknut prechod emm - aby neprepisalo zapisy na karte, ale ecm treba povolit.
jak zkontroluji, ze mam ecm povolene? diky za radu
Re: fw 1.07.89
jednoducho - ak dokaze dekodovat , tak su povolene. Kontrola sa robi cez web rozhranie -Newcamd users. pocet ecm musi stupat, pocet emm musi byt 0 .
kukni na obrazok.
Pri polozke cas pripojenia 1d znamena 1den, potom idu hodiny ,minuty,sekundy.
Ked je niekto pripojeny 1d 14hod a odobral len 4ecm, znamena to,ze sa len prihlasil,ale bud nepozera programy,alebo ma vlastnu kartu. V priloženom rozhrani je moznost zmeny zapisov na karte pridana len lokalnemu uzivatelovi , vsetci ostatny to maju zakazane, preto maju emm 0 .
Libor73
Re: fw 1.07.89
grantec píše:jednoducho - ak dokaze dekodovat , tak su povolene.
prave ze nedekoduje..a v obou sloupcich (ecm i emm) mam 0
zkousel jsem pouze s fw 89 a 97, vecer zkusim jeste s 86
Libor73
Re: fw 1.07.89
grantec píše:jednoducho - ak dokaze dekodovat , tak su povolene. Kontrola sa robi cez web rozhranie -Newcamd users. pocet ecm musi stupat, pocet emm musi byt 0 .
kukni na obrazok.
Ked je niekto pripojeny 1d 14hod a odobral len 4ecm, znamena to,ze sa len prihlasil,ale bud nepozera programy,alebo ma vlastnu kartu. .
tak jsem udelal printscreen po bloknuti zapisu
pred bloknutim bezi cas prene podle tveho obrazku, po bloknuti se to zmeni na offline
Re: fw 1.07.89
krasne si to blokol - na 100% neprejde nic.
klient sa totiz na server vobec nepripojil
asi si editoval newcs.xml notepadom vo windowse.
na pracu so subormi v HDboxe pouzivaj RCC. Je v downloade pre HDbox.
Libor73
Re: fw 1.07.89
po nove instalaci pluginu a editaci newcs.xlm pspadem vse bezi jak ma..diky moc za pomoc a ja se jdu pustit do dalsi prace..pridani sitoveho disku :)
zuchnet
Re: fw 1.07.89
Příspěvek od zuchnet »
Hello I have a question my friend.
What have I do to HDBox FS-9200 see a near transponders for examlpe
Eutelsat W6
10972 V 2170 3/4 Baghdad TV Channel
10975 V 2170 3/4 Oman TV Satellite
Recivier see only one transponder the same :70: but they are two different channels
This is a big error
Best regards
