S dialkovým choď do : Menu - NG-Image Settings - Camd settings - s OK zastav oscam a tiež s OK spusti najskôr newcs a potom mgcamd.
Potom reštartni celý box.
Spustí sa newcs+mgcamd a pôjde aj tá karta v hornom slote a aj emulátor
Ak nepôjde tak som to skúšal až potom ako som urobil tú zálohu ktorá je na fóre - mne to teraz ide
b
i
n
n
e
w
c
s
Reading Config file from /var/tuxbox/config/newcs.xml
TCP-log password is enabled, set to: NewCSpwd
level: normal
type: init
output: console,tcp,udp
logger config: level 1 type 3 output 7
Console log options: level 1 type 3
udp log: host 192.168.2.102 port 44000
UDP log options: level 3 type 255
tcp port: 45000
TCP log options: level 1 type 3
[ 01:09:13 ] [ Box detect ] Box type 1
[ 01:09:13 ] [ Config ] Pincode for device 0 (internal): 0000
[ 01:09:13 ] [ Config ] /dev/tts/0 ECM priority: round
[ 01:09:13 ] [ EMM Cache ] Initialising Cache with 20 entries
[ 01:09:13 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 674
[ 01:09:13 ] [ Loader ] Reader type 12 on node /dev/tts/0
[ 01:09:13 ] [ coolstream ] Opening device /dev/tts/0
KAL Trace Initializaing ...
KAL Trace init Complete
KAL mmap'ings:
cached[0] = 0x2fe10000 (0x09e00000)
uncached[0] = 0x30810000 (0x05800000)
content[0] = 0x34e10000
cached[1] = 0x39610000
uncached[1] = 0x39610000
content[1] = 0x3af10000
Init smartcard api
Open smartcard unit 1
coolstream
[ 01:09:13 ] [ /dev/tts/0 ] smartcard clock: 1000000
Cool: reset card, handle 0x89e67bcc
[ 01:09:13 ] [ /dev/tts/0 ] Reset smartcard....
[ 01:09:13 ] [ /dev/tts/0 ] Reset done
Read smartcard atr....
Timeouts: uCardActTime 45004, uCardDeactTime 8, uATRSTime 40000, uATRDTime 19200, uBLKTime 0, uCHTime 9588, uCHGuardTime 0, uBKGuardTime 4
Smartcard convention: 0
[ 01:09:13 ] [ /dev/tts/0 ] Params: protocol 1 uFI 1 uN 0 uDI 1 uPI1 0 uPI2 0 uII 0 retries 799997952
[ 01:09:13 ] [ /dev/tts/0 ] smartcard clock: 1000000 , Ff=372 Df=1
ATR: 3B 78 12 00 00 A0 C4 06 00 8F F1 90 00
[ 01:09:13 ] parseAtr: 3B 78 12 00 00 A0 C4 06 00 8F F1 90 00
[ 01:09:13 ] [ ATR ] T=0 1etu=186.00us Guardtime:12etu WWT:19200etu BWT 971 CWT 12
[ 01:09:13 ] [ ATR ] Fi 1 (372) Di 2 (2)
[ 01:09:13 ] [ ATR ] Historical bytes: [A0] [C4] [06] [00] [8F] [F1] [90] [00]
[ 01:09:13 ] [ ATR ] freq 1000000.000 config freq 3570000.000
[ 01:09:13 ] [ /dev/tts/0 ] new smartcard clock: 3570000
[ 01:09:13 ] [ Loader ] Init Cryptoworks card
[ 01:09:17 ] [ Keyman ] Adding key 2E04005A27 type 0 on Provider 000000 for caid 0D70 ID=0
[ 01:09:18 ] [ Keyman ] Adding key 2E04005A27 type 1 on Provider 000004 for caid 0D70 ID=0
[ 01:09:18 ] [ Keyman ] Adding key 2E04005A27 type 1 on Provider 000008 for caid 0D70 ID=0
[ 01:09:18 ] [ Keyman ] Adding key 2E04005A27 type 1 on Provider 00000C for caid 0D70 ID=0
[ 01:09:18 ] [ Keyman ] Adding key 2E04005A27 type 1 on Provider 000010 for caid 0D70 ID=0
[ 01:09:22 ] [ Loader ] Card 0D70 on port /dev/tts/0 ready
[ 01:09:22 ] [ Loader ] Starting Newcamd Server on port 49000
[ 01:09:22 ] [ NewCS ] Ready to GO! :)
