Thanks Persian PrincePersian Palace Clean 11.0 By Persian Prince (DVBApp-OE1.6-Mipsel)
Release Date : 06-December-2011
Published By : Persian Professionals Team
Script Manager
- Swap Manager
- Mount Manager
-- USB
-- HDD
-- Mount
-- Format
-- UnMount
- Update Modules
- Delete Crash Logs
- IPK Server Manager
-- Size Check
-- MD5Sum Check
-- SHA1Sum Check
-- USB
-- HDD
- Picon Path Manager
-- USB
-- HDD
- Plugin Path Manager
-- USB
-- HDD
- Software Informations
-- Date
-- Swap
-- System
-- UpTime
-- Activity
-- Host Name
-- Process List
-- File Systems
-- Kernel Version
-- Kernel Informations
-- Installed Packages Informations
- Hardware Informations
-- CPU
-- MAC
-- Memory
-- Free Space
-- Free Memory
-- Kernel Modules
-- HDD Performance
--- HDD Status
--- HDD Temperature
--- HDD Informations
-- Internet Performance
--- Ping
--- Netstat
--- NS Look Up
--- Trace Route
--- What Is My IP
--- Reset Network
--- Use Open DNS - Temporary
- Timeshift Path Manager
-- USB
- Time Update
-- Time Update
-- Time Update Plugin
- OPKG Update + Upgrade
- Persian Empire ******* Image By Persian Prince
-- After Update Scripts
--- Fix Spinner
--- Fix Boot Logo
--- Fix Ajax Loader
--- Fix WebIF - Xtrend
--- Fix WebIF - Vuplus
--- Fix Remote Pictures - Xtrend
--- Fix Remote Pictures - VuPlus
--- Fix Remote Pictures - DreamBox
--- Fix ******* Settings - Xtrend
--- Fix ******* Settings - VuPlus
--- Fix ******* Settings - DreamBox
-- Persian Empire ******* Image Creator (Coming Soon)
--- Xtrend (All HD Models)
Backup/Restore
- Plugins
-- Restore
-- USB
-- HDD
- Skins-Picons
-- Restore
-- USB
-- HDD
- DVBApp Settings
-- Restore
-- Backup
-- Backup With Date
-- USB
-- HDD
- Restore Skin.XML Backup
- Restore Language Backup
Channel - Settings Downloader
- RR Settings
- Likra Settings
- Dona Settings
- Cyrus Settings
- Rytec Settings
- Cajton Settings
- Others Settings
-- Sin Settings
-- Ciefp Settings
-- Serjoga Settings
-- Predrag Settings
-- Catseye Settings
-- Beli1910 Settings
-- Dzunglaxx Settings
-- SGTFlipFlop Settings
-- Morpheus883 Settings
- Persian Settings
-- AdelSat Settings
-- Farshadmb Settings
- Corvone Settings
- Vhannibal Settings
- Remove Channels - Settings
-- Remove Settings
-- Remove Channels
-- Reset Factory Defaults
- Data Channels Converter (*** 19.2E)
Satellites-Terrestrial XML Downloader
- Cables.XML (DVB-C)
- Satellites.XML (DVB-S)
- Terrestrial.XML (DVB-T)
Persian Language For DVBApp Images
- Persian Language Adder (Translated By Persian Prince)
- Persian Language Update (Translated By Persian Prince)
Cleaner
- USB
- HDD
- Temp
Installer
- USB
- HDD
- URL
- Temp
- Xtrend Drivers-Modules - ZIP
-- ET5x00HD
-- ET6x00HD
-- ET9x00HD
File Extractor
- IPK
- NFI
- ZIP
- RAR
- TAR.GZ
Font Changer (DejaVuSans 2.33) - Supports Unlimited Fonts
- Bold Font
- Normal Font
- Read Me Before Do Anything !
Default Channel Audio Configuration
- English
- Persian
About Persian Palace
- Wish List
- To Do List
- Change Logs
- Informations
- Last Server Update
- Persian HD Project News
- Upgrade To Latest Version
File Hashes
File Name :
dvbapp-plugin-persianpros-persianpalace-clean_11.0_mipsel.ipk
CRC32: 1DD664B0
MD5: 69482A11623F3C153C02036A01458BCD
SHA-1: 85952A737E9C2F3588BB47CDDE261656FC3DE8BC
Files : 205
Folders : 19
Scripts : 162
XML Lines : 736
ChangeLogs
Read Them Via About->Change Logs
Help - FAQ
You Can Remove Previous Versions With "opkg remove" Command
I Recommend To Install It On A Fresh Image
Comments & Requests :
->Link Removed<-
Questions & Problems :
->Link Removed<-
All 1.x ~ 10.x Versions Are Outdated/Unsupported
Please Remove Them From EveryWhere , Thanks In Advance
Isn't It Nice That "Persian Prince" Always Brings New Features For You ?
Special Thanks To
- AdelSat
- Farshadmb
- Ali Khavari
- KAMSAT10
- Glimpser
- emanuel
- gutemine
- AliAbdul
- pcd
- Shaderman
- fsenes
- DooMSaT
- unicorn0815
- alborland
- Horst Schmid
- Dr.Best
- Bauernbub
- 2boom
- DDamir
Feel Free To Contact Me : ->Email Removed<-
You Can Provide Direct Links For Settings , Satellites.XML , ...
I Will Add Them To The Next Version
Good Luck
Available Via Download Manager
