PKT SF1018 E2 HAARP v2 Image
Napsal: 26 zář 2011, 20:24
Enigma2 OpenSource SH4 Duckbox Project GIT-2704 PKT mod SVN-1156 HAARP v2 Image
Image is designed for installation SATA/USB device
Support receiver: Octagon SF1018/HDBOX/AT-7000
Added by sh4 Duckbox Team:
- [stm24] OSS SND kernel configs not needed any more (e.g. CONFIG_SND_PCM_OSS)
- [stm24] added lzma patch for squashfs
- [stm24] ext4 can now be used for ext2/3
- [make/ffmpeg] - updated ffmpeg 0.6.1
- [multicom-3.2.4_rc3] add new multicom driver
- [eplayer3] playback aac-he streams with aac-lc
- adding opkg binary to default build
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- [stm24] added squashfs-tools 4.0 lzma patch
- add busybox 1.18.5 stable
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- [player2_191] fsynth bugfix
Added by PKT:
- first build on stm24 kernel
- add new WebInterface v 1.6.7
- new function "live ecm" in infobar
- show Channel Number on Front Pannel + ON/OFF in setup menu
- fast switching channel
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- MPlayer fix GS of EOF
- upgrade formating device in Install Manager
- update API of MyTube based on last CVS source
- update EmuManager v1.0.6: add sh4Cam support & gbox fix
- font FIX moved to Skin setup
- remove unnused files or BP menu settings modification
- fix showing processes
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
* optimize starting WLAN driver
- fix show event-progress in channel selection
- fix crossEPG
- PKT InstallManager 1.2.2
- PKT KeyMapper 1.5
- update Permanent Clock
- fix EMUManager russian translate
- add green button support in Media Player
- fix streamproxy after reboot
- Add Auto 3D Skin Switch by Dr.Best
Known issue:
- subtitles in MediaPlayer not working good
- some Polish HD channels not support
FTP login: user: root, passwd: pkteam
http://www.edisk.cz/stahnout-soubor/044 ... .03MB.html
Added by PKT:
- fix crossEPG
- PKT KeyMapper 1.5
Known issue:
