keymap.xml
Napsal: 06 úno 2011, 17:03
od robinek
Vychazi z keymap.xml, ktere zverejnil Topol211 zde
viewtopic.php?f=262&t=6962
Jen jsem namapoval na stredove sipky (vlevo, vpravo) otevreni seznamu programu (lepsi tlacitko mne zrovna nenapadlo).
nakopirovat do usr/share/enigma2
Topol211 píše:
Celkom vydareny keymap funkcia klaves skoro ako v originalnom fw.
- Multimedia keys OK
- Record on REC
- Timeshift on Play/Pause
- Stop on Stop button (Duh!)
- Subtitles on Sub-t (Red)
- Audio selection on Lang (Yellow)
- Recording list on Aux
- Delete (when supported by list) on DEL/BACK
- Switch between TV/Radio on TV/RADIO
- EPG on GUIDE
Vyskusajte:
subor rozbalit a nakopirovat do usr/share/enigma2
dakujem pingflood
Re: keymap.xml
Napsal: 22 úno 2011, 02:18
od robinek
Vychazi z vyse uvedeneho.
Zmeny:
- tlacitko GUIDE spusti plugin Cool TV Guide. Pokud neni instalovan, tak spousti Graphical Multi EPG
- tlacitko RESOLUTION zobrazi/skryje panel 'Ecm and TP Status' (pouze pokud je aktivni skin HD_Glass16)
Instalace:
- rozbalit do korenoveho adresare ftp
- restartovat AZBox
Re: keymap.xml
Napsal: 14 bře 2011, 14:20
od robinek
Mapovani DO v RC6
- tlacitko RESOLUTION spousti plugin Scaling Mode pro nastaveni rozliseni viz.
viewtopic.php?p=58628#p58628 (funguje v TV, Media Center .. zatim nefunguje v puvodim media playeru)
Instalace:
- restartovat AZBox
Re: keymap.xml
Napsal: 03 dub 2011, 20:21
od monkus
tak, konecne keymap naozaj podobny originalnemu firmwaru!
Re: keymap.xml
Napsal: 04 dub 2011, 09:44
od vikino
changelog:
As usual, put keymap.xml in /usr/share/enigma2
Put patched InfoBarGenerics.py in /usr/lib/enigma2/python/Screens
After this, *restart the AzBox* (not just the GUI!)
Some changelog:
2011-04-02
Fixed MyTube Player
Small tweaks in multimedia actions
Code cleanup. Removed references for all DM RC alternatives [ we have AzBox, right?
2011-02-20
Patched InfoBarGenerics.py to get
RED => Subtitles when watching TV.
2011-02-06:
Guide => GraphMultiEpg
Info => Info from current event (was Guide before)
Left/Right => Volume +/-
Some small changes on inputbox actions:
FASTFORWARD and Del/Back => Delete
REWIND and Caps/Num => Backspace
On GraphMultiEpg:
OK == RED => Zap (check program informations on Info)
Regards,
pingflood
Re: keymap.xml
Napsal: 25 kvě 2011, 15:47
od babo12
Moja uprava keymap pre SIF Team Enigma2 20110419
staci kopirovat keymap.xml do /usr/share/enigma2/
BLUE KEY = SIF panel
GUIDE = coolEPG,CSFD
EXIT KEY = channel infobar
INFO KEY = EPG event info
ostatne skoro rovnake ako na origo FW
Re: keymap.xml
Napsal: 24 pro 2011, 16:54
od johnyhol
Moje úprava originálního keymapu RSI E2 0.3.
Přemapování tlačítek:
středové šipky/ok - nahoru/dolů -> přepínání kanálů
- ok -> vyvolání seznamu kanálů
search -> info baner (toggleShow)
Jinak vše zachováno.
Re: keymap.xml
Napsal: 04 bře 2012, 21:27
od johnyhol
Úprava originálního keymapu RTi 1.7.0
středové šipky - nahoru/dolů -> přepínání kanálů
Kdyby ještě někdo dokázal namapovat středové šipky - doprava/doleva na volume + / - . (hodilo by se hlavně kvůli nové funkci teletextu)
AZku zdar!
