SW 1.12 07.01.2010
Napsal: 07 led 2011, 17:04
od NXP256HD
new http://www.multiupload.com/P34L9OSB9D
* if is set recording directly by red button , that is good set any limitation for record
example 2 hour or set choice 1,5..2..2,5..3 hour
if it be to the contrary is record without limitation to full disc
------add ,when u recording ,press red icon again to enable this fucntion.
* DVD files is starting playing in small size of picture isnt fit to screen
after set to full screen and use FF is return to small picture
----maybe do it later next s/w
-----now priority is is , CAS(card)>share> patch
* in MENU -YOUTUBE-VPN Setup arent tinge line for putting of parameters
only first line
-----ok
* when is seting SMB File Setup if is possible add some informatiom if is address
correct after show example connected
---- next s/w
* Menu Instalation - Usals Setup -if is possible add there scale Quality and Strength
same like is in Antena seting (there is place below) it can men ahelp at seting dish
-----ok
* WEB Radio - many time rebooting at switching from link to link
example TOP100 choice first station , choice 2-nd , a next next and is reboot
----PLS CHECK AGAIN
* Add possiblity set position for subbitles at media player
now are subbtitles too lowly , if is large text is cutting
-----OK
*Possibility of seting size (thickness) of subbitles
-----OK
* at scaning Hotbird 13E TP 11449 are TV chanels stored to Radio
with s/w 1.06 it was OK , BTW there is many channels which after scannig are show
when is sorting FTA / HD264 is SD and sorted like HD ....
------OK,PLS check again
*EMM ON/OFF , if is possille add to MENU CA - choice for passing of EMM to card
-------- later
* in Czech OSD only
OSD there is one day moved in day in EPG :
SUN = Ned , Mon=Pon , Tue:
------OK
* Poland EPG
Cyfry+ EPG isnt show Ok , see pictures , same as before , NXP AVIRA have OK
------OK
*Subtitles in movies
TXT subtitles for movies are displayed desychronized ... even if good work on PC, or other media player
dont pass with actual time of movie ..
------OK
* Display mode - in movies 16:9 is only show OSD message but without effect change
------OK
* chanels sorting still is there :-( after
use example press by key no.1 is example TVP1
but by press OK , is TVP1 on the position 56
------OK
Re: SW 1.12 07.01.2010
Napsal: 08 led 2011, 11:43
od NXP256HD
add new function x-timeshift,exit all menu ,press F1 234 to enable
About X-Timeshift:
Everybody knows Timeshift, what's X-Timeshift?
When you are using NewCAMD,CCCam,Gsh to watch the N-D-S S-K-Y channels,
normally need fast internet to get back the CW in 800ms, but sometimes
CW get back more than 1s, even more 2s, 3s. You will get the freezing
picture. If you are using X-Timeshift, you will get smooth picture even
you get delayed CW.
Disadvantage: When you are in X-Timeshift, you will get the video
picture delayed 15s and you can not do anything, only can change the
Volumn up and down.
need use connected HDD , Flash USB
Napsal: 09 led 2011, 01:08
od Duce
Funkčný telnet s funkčnými príkazmi
Testovacie webrozhranie
Share CCCam, newcamd, Gshare
BUGS:
Nekorektné zobrazovanie EPG
Problém pri ladení, ani pri sieťovom ladení nenájde všetky stanice a TP
