Stránka 1 z 2
fw 1.08.37
Napsal: 27 srp 2010, 22:42
Changes :
- Stability on Main SW improved
- Hang-up during long time recording - Fixed
- Hang-up during receiving EPG data - Fixed
- BlindScan function improved :
--> H/V control problem fix.
--> hang-up fix.
- Missing some TP in Auto Scan - Fixed
- German language error - Fixed
- Alarm message appears if storage capacity is not enough for the recording - Improved
- Playback problem of Radio channel recordings - Fixed
- Resolution problem at Zapping Mode Freeze and Resolution Auto mode - Fixed
- PMT File Update/Delete error fix.
- Unicable function - Improved
--> Improtant : Kathrein ESU33 Wall Socket Timing Adjustment will fix by coming SW
--> for Unicable-Protection (Turn off 18V after 400ms)
- Video error at the beginning of PIP - Fixed
- Incorrect PMT data filtering - Fixed
- Incorrect time information during EPG Event Search - Fixed
- Error if pressing Power button during recording - Fixed
- Showing current resolution when you change the resolution to above 576i in PAL TV - Improved
- Timeshift playback function - Improved
- Hang-up when recording multifeed service - Fixed
- Not able to change Audio track of a recording - Fixed
- Saveing the default (wifi-ethernet) configuration in Network Setting - Improved
- Time information of recordings shows the starting time of program - Modified
- User font (font - ttf file) Download via USB Stick add. + improved
--> create font folder and copy to USB Stick
--> Connect USB Stick to STB
--> Menu - System Setup - Data Transfer : Data download from USB Storage or
--> Software Download popup OSD : With left/right Cursor Buttons font folder finding
--> Red Button Download
--> User Font File setup Menu - Configuration - Language Setting
- MHW-EPG exit error - Fixed
- Auto. Timeshift when recording is done (stop) even though Timeshift start setting is Manual - Fixed
- Error in front LED of 430mm twin tunner model - Fixed (9100)
- MDU LNB Setup modified & improved (only for Digitürk Provider - Eutelsat 7°E)
- Boot procedure modified : HDD Check & Start1 improved
- Front Button Brightness Function fix.
- censorship add. & fix. by parental control
--> Menu - Configuration - Parental Control :
--> Censorship No Block, 4, 6, 8, 10, 12, 15, 18
http://www.sapro.cz/ftp/index.php?actio ... ory=HD-BOX&
Re: fw 1.08.37
Napsal: 28 srp 2010, 08:19
pozri si rcS a tam najdes, co vlastne pri starte robi .
Re: fw 1.08.37
Napsal: 29 srp 2010, 23:59
od 7lucas7
Takže klasicky: tovární nastavení, instalace FW, tovární nastavení a znovu nový setting.
Satelit se chova stejně jako vychvalovany 1.08.26 vše funguje jak má takže doporučuji přejít na 1.08.37, EMU a vše stabilní i nahrávání a timesetting. konečně!! (verze 34 = děs hrůza) zítra dokončím setřídění setting (Skylink, a UPC kdo bude mít zájem mohu pak poslat FDU
poznámka instalce nový Fw na maxiboot: u lidí co mají i Enigmu (/a tím maxiboot, to sem i případ já, vše funguje akorat u načítání Fw jsou vidět procenta, ale po restartu a instalaci nove FW uz maxiboot píše jen Update == vypadato jako by se nic nedelo (ale on to opravdu zavadi nutne pockat!!!!! cca 3-4minuty. (u original zavadeciho softu to zde pise opet procenta (coz maxiboot neumi) tak se nelekejte
po doinstalaci pak bezi vse jako originalu.
Re: fw 1.08.37
Napsal: 30 srp 2010, 22:41
od heroo
No ked pridem domov tak nainstalujem a vyskusam, ak je to naozaj stabilne tak potom klobukom dole :-) Ten 34 bola katastrofa.
Re: fw 1.08.37
Napsal: 31 srp 2010, 12:56
od karamba
Zdravím,
přes USB flash jsem dal tento fw (původní 1.08.26), vše funguje až na to, že box najednou nevidí USB flash. Tu samou, ze které jsem před tím nahrával tento fw. Zkusil jsem i vypnutí vzadu a nepomohlo. Co udělat aby ji viděl? Chci si zazálohovat data a programy. Dík
Re: fw 1.08.37
Napsal: 31 srp 2010, 14:29
od karamba
Takže jsem zkusil jinou starou flešku a to samé. Vzhledem k tomu že byla prázdná tak jsem ji naformátoval v boxu a vše je OK, box ji našel a zazálohoval jsem vše potřebné. Jinak při update jsem nedělal továrko ani před ani po, myslíte že to má nějaký význam? Mám čistý fw bez jakýchkoliv plugin.
Re: fw 1.08.37
Napsal: 31 srp 2010, 14:43
ma to vyznam ,tak isto ako ma vyznam aj zmazanie zalohy nastaveni .
Inak - k tym USB klucom. Kazde pripojenie ma za nasledok pridanie core suborov na kluc (tam su data zo "stratenych" oblasti disku) . To je novinka,ale problem s nefunkcnym usb klucom som nezaznamenal .
Re: fw 1.08.37
Napsal: 31 srp 2010, 22:07
od heroo
grantec píše:ma to vyznam ,tak isto ako ma vyznam aj zmazanie zalohy nastaveni .
Mne toto presne robila ta verzia 34... Akykolvek USB aj ten co predtym korektne fungoval som musel naformatovat na HDboxe.
Re: fw 1.08.37
Napsal: 31 srp 2010, 23:06
ano , to som pisal k verzii 1.08.34 . Tu sa bavime o verzii 1.08.37 . V tejto verzii to uz nerobi .
Re: fw 1.08.37
Napsal: 01 zář 2010, 01:06
od henryx
Nahodil som si tento FW 1.08.37 a po naladeni programov mi nechce skylink karta vobec dekodovat programy. Pred tym som mal FW 1.08.22 a tam to slo dekodovat i kde obcas pri pozerani nejakeho programu sa stalo ze sa obraz zastavil a po chvili zasa spustil. Myslel som ze to novym FW vyriesim.
Skusil som sa vratit aj k FW 1.08.22 ale tam mi to uz tiez nechce dekodovat. Karta je nova kupovana pred tyzdnom.
Dakujem za kazdu radu co s tym.
Re: fw 1.08.37
Napsal: 01 zář 2010, 01:37
My ale nemôžeme vedieť akú kartu máš a či je vôbec aktivovaná...
Re: fw 1.08.37
Napsal: 01 zář 2010, 11:53
od henryx
dempsey píše:My ale nemôžeme vedieť akú kartu máš a či je vôbec aktivovaná...
Karta je OK. Ono mi to vsetko islo. Prestalo to dekodovat ked som nahodil novy FW. Proste mi nedekoduje programy. Info z citacky karty je taketo:
Typ: CryptoWorks
Label: CryptoWorks
Algo Ver: ff ff 20 08 07
Algo Type: ff ff 20 08 01
CA SYS ID: 0x0d96
Entitlements: Operator: FFFF
Re: fw 1.08.37
Napsal: 01 zář 2010, 12:00
Karta neni ok - karta je problém pretože je to ICE karta / 0D96 / a neprešli Ti na ňu oprávnenia po promo režime.
Re: fw 1.08.37
Napsal: 01 zář 2010, 12:05
od henryx
dempsey píše:Karta neni ok - karta je problém pretože je to ICE karta / 0D96 / a neprešli Ti na ňu oprávnenia po promo režime.
A co sa da s tym teraz robit?
Re: fw 1.08.37
Napsal: 01 zář 2010, 12:15
Ja ICE kartu nemám tak budeš musieť počkať na niekoho iného
