1. Freezing Scrren when Flash writing : fixed
2. Diseq Command error : fixed
3. Voltage changing issue when receiver turn to standby condition during recording: fixed
4. not appearing popup message for plugin download : fixed
5. Audio delay sync feature added and it can set on AV Output Menu
6. Recording fail message appears in case default recording device is set incorrectly: fixed
receiver will ask to find correct recording device.
7. incorrect channel searching result between two TP which has very near frequency : fixed
receiver operated it as same TP with last version SW.
8. TP data update(eutel W2 16.0E), new Satellite added (eutel sesat 1 16.0E)
9. receiver hangup in System Informaiton Menu: fixed
http://www.sapro.cz/download/hdbox/download2.php?id=33
fw 1.08.01 pre 9100
Odkaz na stažení firmware a diskuze k aktuálnímu firmware.
Zpět na „Odkaz na firmware a diskuze k firmware - HD-BOX FS-9100 PVR“
