Přechod Freesat z družice Thor na družici Astra23
Napsal: 26 bře 2024, 14:20
Prosím o pomoc s nastavením OSCamu.
Po přetočení paraboly na Astru23 a aktivace karty mi přestalo fungovat nastavení v OSCam. Bohužel tomu moc nerozumím konfiguraci mi dělal kamarád který je teď mimo.
oscam.version:
Unix starttime: 1711458603
Starttime: 26.03.2024 14:10:03
Version: oscam-build-DreamOSat-1.20_svn-r11734-799
Compiler: mipsel-oe20-linux-gnu
Box type: vuzero (generic)
PID: 990
TempDir: /tmp/.oscam
GBox tmp_dir: not defined using: /tmp/.oscam
ConfigDir: /var/keys/oscam_atv_ymod/
WebifPort: 8888
Build: by. audi06_19 || info@dreamosat-forum.com
SuPPort: https://www.dreamosat-forum.com/board/
Web interface support: yes
LiveLog support: yes
jQuery support intern: yes
Touch interface support: no
SSL support: no
DVB API support: yes
DVB API with AZBOX support: no
DVB API with MCA support: no
DVB API with COOLAPI support: no
DVB API with COOLAPI2 support: no
DVB API with STAPI support: no
DVB API with STAPI5 support: no
DVB API with NEUTRINO support: no
DVB API read-sdt charsets: no
DVB API with ICAM v9 stream relay support: yes
Anti-cascading support: yes
Debug mode: no
Monitor: no
Loadbalancing support: no
Cache exchange support: yes
Cache exchange AIO support: yes
CW Cycle Check support: yes
LCD support: no
LED support: no
Clockfix with realtime clock: yes
IPv6 support: no
Emulator support: yes
Built-in SoftCam.Key: yes
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: yes
radegast: yes
scam: yes
serial: yes
constant CW: yes
Pandora: yes
ghttp: yes
Reader support: yes
Nagra: yes
Nagra Merlin: yes
Irdeto: yes
Conax: yes
Cryptoworks: yes
Seca: yes
Viaccess: yes
NDS Videoguard: yes
DRE Crypt: yes
TONGFANG: yes
Bulcrypt: yes
Griffin: yes
DGCrypt: yes
cardreader_phoenix: yes
cardreader_drecas: yes
cardreader_internal_azbox: no
cardreader_internal_coolapi: no
cardreader_internal_coolapi2: no
cardreader_internal_sci: yes
cardreader_sc8in1: yes
cardreader_mp35: yes
cardreader_smargo: no
cardreader_pcsc: no
cardreader_smartreader: no
cardreader_db2com: yes
cardreader_stapi: no
cardreader_stapi5: no
cardreader_stinger: yes
oscam.server:
# oscam.server generated automatically by Streamboard OSCAM build-DreamOSat-1.20_svn SVN r11734-799
[reader]
label = FreeSat_Astra23
protocol = internal
device = /dev/sci0
autospeed = 0
caid = 0624
rsakey = 79EA25A763DA2C3E02B456A13962E60BCE63E628A2C177BE951CED96A9C6131A146F98D5867B7AE6682324FD6481913C0241F065C8D3457E54BB59B7B5DE0362
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 1,3,15,0
blockemm-unknown = 1
[reader]
label = emulator
enable = 0
protocol = emu
device = emulator
disablecrccws_only_for = 0E00:000000
caid = 0500,0604,0D00,0E00,1010,1801,2600,2602,2610
detect = cd
ident = 0500:020A00,021110;0604:000000;0D00:0000C0;0E00:000000;1010:000000;1801:000000,001101,002111,007301;2600:000000;2602:000000;2610:000000
group = 1
emmcache = 2,1,2,1
emu_auproviders = 0604:010200;0E00:000000;1010:000000;2610:000000
v Logu mám:
2024/03/26 14:10:03 00000000 s (main) System name = Linux
2024/03/26 14:10:03 00000000 s (main) Host name = vuzero
2024/03/26 14:10:03 00000000 s (main) Release = 3.13.5
2024/03/26 14:10:03 00000000 s (main) Version = #1 SMP Wed Jan 21 15:08:36 CET 2015
2024/03/26 14:10:03 00000000 s (main) Machine = mips
2024/03/26 14:10:03 00000000 s (main) Stb model = dm8000
2024/03/26 14:10:03 00000000 s (main) Stb vumodel = vuzero
2024/03/26 14:10:03 00000000 s (main) Stb boxtype = vuzero
2024/03/26 14:10:03 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 16107
2024/03/26 14:10:03 00000000 s (config) services reloaded: 0 services freed, 16 services loaded, rejected 0
2024/03/26 14:10:03 00000000 s (emu) OSCam-Emu version 799
2024/03/26 14:10:03 00000000 s (config) userdb reloaded: 24 accounts loaded, 0 expired, 0 disabled
2024/03/26 14:10:03 00000000 s (main) signal handling initialized
2024/03/26 14:10:03 00000000 s (config) 1306 provid's loaded
2024/03/26 14:10:03 00000000 s (config) 8728 service-id's loaded in 203 ms
2024/03/26 14:10:03 00000000 s (config) WARNING: You risk high CPU load and high ECM times with more than 2000 service-id's!
2024/03/26 14:10:03 00000000 s (config) HINT: --> use optimized lists from https://wiki.streamboard.tv/wiki/Srvid
2024/03/26 14:10:03 00000000 s (config) 140 tier-id's loaded
2024/03/26 14:10:03 00000000 s (net) newcamd: initialized (fd=6, port=7701)
2024/03/26 14:10:03 00000000 s (net) -> CAID: 0D97 PROVID: 000004, 000008, 00000C, 000010
2024/03/26 14:10:03 00000000 s (net) cccam: initialized (fd=7, port=7702)
2024/03/26 14:10:03 00000000 s (reader) FreeSat_Astra23 [internal] creating thread for device /dev/sci0
2024/03/26 14:10:03 00000000 s (main) waiting for local card init
2024/03/26 14:10:03 12AD2A48 r (reader) FreeSat_Astra23 [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2024/03/26 14:10:03 12AD2A48 r (reader) FreeSat_Astra23 [internal] Reader sci internal, detected box type: vuzero
2024/03/26 14:10:03 56242BE5 h (webif) webif: decompressed 171235 bytes back into 451928 bytes
2024/03/26 14:10:03 56242BE5 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
2024/03/26 14:10:04 12AD2A48 r (reader) FreeSat_Astra23 [internal] card detected
2024/03/26 14:10:05 12AD2A48 r (reader) FreeSat_Astra23 [internal] ATR: 3B 78 12 00 00 54 C4 03 00 8F F1 90 00
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] Hist. Bytes: TĦ#3;
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] detect irdeto card
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] caid: 0653, acs: 0.05, country code: CZE
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] WARNING: For Irdeto cards you will have to set 'mhz= 600' in oscam.server
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] active providers: 4 (0093ff,ffffff,ffffff,ffffff)
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] found card system irdeto
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max allotted of 1
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] entitlements for provider: 1, id: 0093FF
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B59, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5B, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 7FFE, date: 2024/03/14 - 2024/04/13
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 7FFD, date: 2024/02/28 - 2024/03/09
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: FFD8, date: 2014/11/21 - 2014/12/01
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5C, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5F, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:14 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] ready for requests
2024/03/26 14:10:14 00000000 s (main) init for all local cards done
2024/03/26 14:10:14 00000000 s (emmcache) loaded 0 emmcache records from /var/keys/oscam_atv_ymod/oscam.emmcache in 1 ms
2024/03/26 14:10:14 00000000 s (emmcache) loaded 0 emmstat records from /var/keys/oscam_atv_ymod/oscam.emmstat in 0 ms
2024/03/26 14:10:14 00000000 s (anticasc) anti cascading disabled
2024/03/26 14:10:14 00000000 s (gbox) local gbox failed init
2024/03/26 14:10:14 3DCC59F6 c (client) encrypted cccam-client 10.0.7.1 granted (usr1, au=auto (2 reader))
2024/03/26 14:10:14 0ADEA774 c (client) plain dvbapi-client granted (dvbapiau, au=auto (2 reader))
2024/03/26 14:10:14 1676C960 c (client) encrypted cccam-client 178.209.155.129 granted (jakubr2, au=off)
2024/03/26 14:10:14 77C17878 c (client) encrypted cccam-client 178.209.147.193 granted (HanaD1, au=off)
2024/03/26 14:10:14 0ADEA774 c (dvbapi) dvbapi channelcache loaded from /var/keys/oscam_atv_ymod/oscam.ccache
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum number of filters is 64 (oscam limit is 64)
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 16
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0B02 ECM_PID: 060C PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 181D ECM_PID: 060A PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0624 ECM_PID: 0604 PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 060B PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0500 ECM_PID: 0606 PROVID: 051910
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 found 5 ECM pids and 5 STREAM pids in CA PMT
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
2024/03/26 14:10:19 0ADEA774 c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/26 14:10:20 3DCC59F6 c (ecm) usr1 (0624@000000/A000/3CF4/4B:435B52B0D70365C3FE6908F6A01FA6ED): rejected group (0 ms) (no matching reader)
2024/03/26 14:10:24 0ADEA774 c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/26 14:10:30 3DCC59F6 c (-) -- Skipped 1 duplicated log lines --
2024/03/26 14:10:30 3DCC59F6 c (ecm) usr1 (0624@000000/A000/3CF4/4B:F2F905DB536DE40A1FF516620A8CC82C): rejected group (1 ms) (no matching reader)
oscam.version:
PID: 990
WebifPort: 8888
SSL support: no
Debug mode: no
Monitor: no
LCD support: no
LED support: no
IPv6 support: no
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: yes
radegast: yes
scam: yes
serial: yes
constant CW: yes
Pandora: yes
ghttp: yes
Reader support: yes
Nagra: yes
Nagra Merlin: yes
Irdeto: yes
Conax: yes
Cryptoworks: yes
Seca: yes
Viaccess: yes
NDS Videoguard: yes
DRE Crypt: yes
TONGFANG: yes
Bulcrypt: yes
Griffin: yes
DGCrypt: yes
cardreader_pcsc: no
oscam.server:
[reader]
protocol = internal
device = /dev/sci0
autospeed = 0
caid = 0624
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 1,3,15,0
[reader]
label = emulator
enable = 0
protocol = emu
device = emulator
detect = cd
group = 1
emmcache = 2,1,2,1
v Logu mám:
