fw 2.11.87
Napsal: 17 dub 2014, 13:07
fw 2.11.87 - dostupne aj cez Menu - update .
Re: fw 2.11.87
Napsal: 18 dub 2014, 17:58
od zdent
grantec píše:fw 2.11.87 - dostupne aj cez Menu - update .
Byl by k ní update list?
Re: fw 2.11.87
Napsal: 19 dub 2014, 09:43
od maja5
Release note Version 2.11.87
1. DNS setting by force for stable YouTube connection
First DNS : 8.8.8.8 / Second DNS : 8.8.4.4
2. YouTube Category rearranged based on changed YouTube category
(Top Rated / Top Favourite / Most Viewed Removed)
3. Connectivity of AirTivi+ under WiFi network : Improved
4. Weird character in FAV List after choosing Persian : Solved
5. Incorrect Quality level : Solved
6. Parental control for Media, web browser, TV Portal+ : Added
7. Asking for REBOOT, DEEP Standby, Standby when pressing and hold power key on remote : Added
8. Short cut key(Recall button) to make video full screen in Torrent Player : Added
9. Channel recording will be continued even if the channel get Scrambled and De-Scrambled : Added
10. Receiver freezing after few hours if leave it on MENU OSD : Solved
11. Receiver will change the resolution according to the channel resolution : Added
12. Compatibility with plugin Xcam2 and Mcas : Improved
13. Starting plugin by Green will start the plugin without asking YES/NO : Added
14. Time Calibration : Added
=> Getting the correct TIME info from satellite transponder and make the EPG available with correct time information
Re: fw 2.11.87
Napsal: 23 dub 2014, 08:41
od zdent
maja5 píše:Release note Version 2.11.87
Díky za informace. Mohu se zeptat, kde jsou tyto informace k nalezení? Děkuji předem.
Re: fw 2.11.87
Napsal: 20 bře 2015, 15:02
od davidas
u tohoto fw je nefunkcni presouvani programu, programy jdou sice presouvat, ale je to zmatene, zmeny se neprojevuji
Re: fw 2.11.87
Napsal: 23 bře 2015, 09:13
od zdent
davidas píše:u tohoto fw je nefunkcni presouvani programu, programy jdou sice presouvat, ale je to zmatene, zmeny se neprojevuji
Mám také tuto verzi a přesouvání i mazání mi v ní chodí normálně. Několikrát jsem programy přesouval a mazal a vždy fungovalo naprosto správně. Tato verze se mi jeví jako stabilní a bez chyb, alespoň pro akce, které používám. Zkuste vymazat adresář /var (třeba pomocí programu rcc z PC), resp. znovu nainstalovat tuto verzi.
Re: fw 2.11.87
Napsal: 24 bře 2015, 18:52
od MartinK.
Někdy se stane po přehrání FW, že je třeba změnit nastavení seřazení programů.
Na ovladačí: "OK" - modré tlačítko(volby seznamu programů) - nechat zapnutý jenom první řádek :87:
Re: fw 2.11.87
Napsal: 25 bře 2015, 14:02
od zdent
MartinK. píše:Někdy se stane po přehrání FW, že je třeba změnit nastavení seřazení programů.
Ano, na tohle jsem zapomněl. To se stane , alespoň u mně, při každém nahrání fw i stejné verze a je to třeba nastavit, protože pak jsou opravdu programy zmatečně rozházeny.
