fw 1.08.65 FAC
Libor73
Re: fw 1.08.65 FAC
Příspěvek od Libor73 »
dodkomajka píše: ignore = 0D03,0D70,0624,0100,0D0F
priority = 0D03
Neměl by jsi právě 0D03 z ignore smazat?
dodkomajka Slovakia
Re: fw 1.08.65 FAC
Příspěvek od dodkomajka »
Libor73 píše:
priority = 0D03
Nepomohlo, ale v čítačke 2 mi píše prosím čakajte. To vyzerá ako keby ju nevedelo načítať.
HD-BOX FS-9200 PVR,fw 1.11.57 , plugin Oscam 8972 , Mcas + Xcam , SatElita 2000HD ECO,
dodkomajka Slovakia
Re: fw 1.08.65 FAC
Hide 2A9484E8 r 1 dolna 0 0 127.0.0.1 0 internal 14.12.10 09:50:24 00:04:40 0000:0000 no data 00:04:40 ERROR
Hide 2B1484E8 r 2 horna 0 0 127.0.0.1 0 internal 14.12.10 09:50:24 00:04:40 0000:0000 no data 00:04:40 OFF
Proxies 0/1
Hide Restart p 1 reader-4 0 0 0.0.0.0 10001 newcamd 14.12.10 09:50:24 00:04:40 0D03:13A7 Skylink: JOJ PLUS no data 00:04:40 OFF
Clients 1/1
Hide Kill c 1 0 0 0.0.0.0 0 stapi 14.12.10 09:50:28 00:04:36 0D03:13A7 Skylink: JOJ PLUS timeout 00:04:36 OK
2010/12/14 9:54:46 2B9484E8 p connecting to adresa.bla.net
2010/12/14 9:54:46 2B9484E8 p can't resolve adresa.bla.net, error: Name or service not known
2010/12/14 9:54:47 2C1484E8 c stapi: Start another ECM 0105
2010/12/14 9:54:47 2C1484E8 c anonymous (0D03&000004/13A7/9C:C60D): timeout (12177 ms) (of 0 avail 0)
2010/12/14 9:54:49 2C1484E8 c stapi: Start another ECM 00AB
2010/12/14 9:54:49 2C1484E8 c anonymous (0D03&000004/13A7/9C:8860): timeout (12472 ms) (of 3 avail 3)
2010/12/14 9:54:49 2B9484E8 p proxy adresa.bla.net:10001 newcamd525 (fd=53)
2010/12/14 9:54:49 2B9484E8 p connecting to adresa.bla.net
2010/12/14 9:54:49 2B9484E8 p can't resolve adresa.bla.net, error: Name or service not known
2010/12/14 9:54:54 2C1484E8 c stapi: Start another ECM 0105
2010/12/14 9:54:54 2C1484E8 c anonymous (0D03&000004/13A7/9C:8860): timeout (12274 ms) (of 0 avail 0)
2010/12/14 9:54:56 2C1484E8 c stapi: Start another ECM 00AB
2010/12/14 9:54:56 2C1484E8 c anonymous (0D96&000004/13A7/80:E2CF): not found (1 ms) (of 1 avail 1)
2010/12/14 9:54:56 2C1484E8 c stapi: Start another ECM 0105
2010/12/14 9:54:56 2C1484E8 c anonymous (0D96&000004/13A7/80:9C76): timeout (12501 ms) (of 0 avail 0)
2010/12/14 9:54:59 2C1484E8 c stapi: Start another ECM 00AB
2010/12/14 9:54:59 2C1484E8 c anonymous (0D03&000004/13A7/9C:3E95): timeout (12381 ms) (of 3 avail 3)
2010/12/14 9:54:59 2B9484E8 p proxy adresa.bla.net:10001 newcamd525 (fd=53)
2010/12/14 9:54:59 2B9484E8 p connecting to adresa.bla.net
2010/12/14 9:54:59 2B9484E8 p can't resolve adresa.bla.net, error: Name or service not known
2010/12/14 9:54:59 2C1484E8 c stapi: Start another ECM 0105
2010/12/14 9:54:59 2C1484E8 c anonymous (0D96&000004/13A7/80:0348): timeout (12512 ms) (of 0 avail 0)
2010/12/14 9:55:01 2C1484E8 c stapi: Start another ECM 00AB
2010/12/14 9:55:01 2C1484E8 c anonymous (0D03&000004/13A7/9C:3E95): timeout (12519 ms) (of 0 avail 0)
2010/12/14 9:55:01 2B9484E8 p proxy adresa.bla.net:10001 newcamd525 (fd=53)
2010/12/14 9:55:01 2B9484E8 p connecting to adresa.bla.net
2010/12/14 9:55:01 2B9484E8 p can't resolve adresa.bla.net, error: Name or service not known
To mi vypisuje.
jirbar
Re: fw 1.08.65 FAC
Příspěvek od jirbar »
bery2 píše: 1:Smažu veškerá data z položky VAR přes program RCC190 a PC po lanu (ne přes usb a plugin a dálkové ovládání ,jednou už některý moderátor to zde popisoval)
2:Dám tovární nastavení a po startu ještě jednou vypnu přijímač dálkovým ovládáním a vzadu vypínačem.
3:Po restartu přístroje teprve nahraji nový fw.
4:Po dalším restartu naladím z jednoho TP programy .
5:Zkontroluji vypnutí čteček v položce CAS nastavím lan a vypnu znovu přístroj.
6:Po restartu nahraji plugin a dle výběru co potřebuji zapnu a restartuji Hdbox
7:Dle použitého fw si až naposledy nahraji své uložené programy.
Chlapci HDBOX 9200 byl úplně nový neposkvrněný.
1/ Nebylo co mazat nic tam nebylo
2/ Ano
3/ Ano nahrálo se FW 65
3a/ Znova tovární nastavení doporučované po nahrátí každého nového FW + vypnutí vzadu vypínačem
4/ Ano a nenačítám Systémové nastavení jak píše "grantec"
5/ Ano přestože tady někdo tvrdil že u FW52 skryté menu není. U FW65 je a nikdo neodpověděl k čemu, když nemá být funkční.
6/ Ano
7/ Nebylo potřeba
8/ Nepamatuji si default položky Napájení, ale při jakémkoliv nahrávání ji uvedu do stavu "VYP"
Přesto se objevovalo "Není signál Tuner 1", slevilo to Vypnout/Zapnout přes DO
Nový pokus s rozdílem
1/ Mažu z Total Comandru přes FTP včetně složky VAR
7/ Nahraji před tím z FW65 naladěné a uložené programy
Výsledek byl ještě horší. Často nepomohl ani tvrdý restart. HDBOX snad musel vystydnout.
jerry
Re: fw 1.08.65 FAC
Příspěvek od jerry »
@dodkomajka: Nevie prelozit dns meno na ip-cku. Bud mas zle nastavene DNS, alebo vobec pripojenie do internetu.
bery2
Re: fw 1.08.65 FAC
Příspěvek od bery2 »
Už dvakrát u známých z ničeho nic odešel diseq přepínač a u jednoho monoblok.Naladit programy šlo ale po přidání další družice začal psát po restartu Není signál.Někdy naskočil a šel jindy né.Dal se jinej a mají klid .
dodkomajka Slovakia
Re: fw 1.08.65 FAC
Chlapci ako sa vypínaju interné čítačky , vrátil som to na 1.08.44 + univerzál oscam,a už som to zabudol ako sa to robí.
Už som na to prišiel keď som to prerábal na 44.
Naposledy upravil(a) dodkomajka dne 14 pro 2010, 18:04, celkem upraveno 1 x.
jirbar
Re: fw 1.08.65 FAC
bery2 píše: Už dvakrát u známých z ničeho nic odešel diseq přepínač a u jednoho monoblok.Naladit programy šlo ale po přidání další družice začal psát po restartu Není signál.Někdy naskočil a šel jindy né.Dal se jinej a mají klid .
To je sice možné, ale není to můj případ. Mám DisEqc 2 kusy 2x4. Astra23 je Twin LNB a na jednom DisEQc je HDBOX a na druhém Ariva. Parabola má 7 LNB z toho ten jeden Twin.
No a když HDBOX hlásil "Není signál" tak taky nejel klient Ariva. Stačilo Vypnout/Zapnout přes DO a oba naskočily. Takže spíš bych hádal Oscam. Teď již zase jedu pod Dreamem a HDBOX šel do kouta.
Pro klid duše udělám vše znova včetně naladění.
dodkomajka Slovakia
Re: fw 1.08.65 FAC
dodkomajka píše:Chlapci ako sa vypínaju interné čítačky , vrátil som to na 1.08.44 + univerzál oscam,a už som to zabudol ako sa to robí.
Tak už to viem, už všetko beží aj klienti.
baranček Slovakia
Dal poděkování: 15 poděkování
Re: fw 1.08.65 FAC
Příspěvek od baranček »
bery2 píše:Takže chlapci,vždy dodržujte postup jak nahrávat fw a budete mít klid. A raději dvakrát čtěte než něco provedete.Nikdy před nahraním nového fw nenechávejte plugin ve Varu to je první co musíte smazat než budete nahrávat fw.A to platí dvojnásob u fw 52 a novějších,jelikož jak čtete tak ve fw nastaly dost podstatné změny,tak nepoužívám i uložené programy ze starších fw1.07.31-1.08.44.Od fw 52 jsem si veškeré programy znovu naladil a uložil.To co píšete se mi stalo jen jednou když jsem bastlil a nedodržel postup.Za další tento stroj umí přes oscam dělat server pro další přístroje (sdílet vlastní kartu) a zároveň připojit se na další server newcamd nebo cccam .To vše mi funguje na 98%.Nepíši 100 moc bych ho chválil.Nejde bezhlavě jen tak nahrávat nový Fw a pluginy pokud tomuto přístroji moc nerozumíte a neovládáte ho alespoň v základních věcech .Hlavně si každý musí umět v hdboxu a oscamu upravit caid a ignore pro vaše karty co vlastníte .Tento postup nahrání fw a pluginů co Vám napíši dodržte a budete mít klid.
Zkoušel jsem na HD box 9200 , oscam 3152 a FW 52 připojit 4 sat na sdílení na dvě vlastní karty .nahrávat na pevný disk 2 programy a dále se souběžně připojit na 3 newcamd servery a z nich se dívat na programy v hlavním Hd boxu.
Takto jsem to testoval týden a bez jediného záseku či problémů co uvádíte.Někdy jsem nechal dva dny běžet box bez přestávky a jen vypnul nahrávání a někdy jsem ho nechal probudit z pohotovostního režimu.Vše proběhlo korektně. Doma mi běží Hdbox 9200 a dvě arivy skoro pořád a bez problémů Již dva dny si hraji s novým grantecovým oscamem 4085 na fw 65 a zatím vše zase jede až moc dobře.Až ho budu mít pořádně odzkoušen dám ho zase sem na testy hdboxařům.
Problém jsem párkrát měl s kartou Skylink ale ne s Hdboxem.Mají toho moc a tak jim blbnou zápisy na karty a někdy zazlobí transpordéry.
Postup nahrávání nového fw a pluginů
Ja Používam jedine MCAS a úplne mi stačí mazanie starého pluginu pomocou diaľkového ovládača v menu plugin modrým tlačítkom,nevyužívam ani továrenské nastavenie,seting mám pôvodný od fw 44,prešiel som s ním aj cez 52a65 a všetko ide v pohode.Ale ešte raz zdôrazňujem používam iba MCAS.
jirbar
Re: fw 1.08.65 FAC
jirbar píše:
2/ Ano
6/ Ano
7/ Nebylo potřeba
Tak u mně celá instalace znova včetně FW a zatím to běží bez výpadku. Jediný rozdíl oproti minule je, že jsem zatím nepřidal do "srvid" Penthouse a do "service" Travel"
bery2
Re: fw 1.08.65 FAC
No sláva a klidně si tam ty dva programy přidej nic tomu neuděláš.
Errors
Re: fw 1.08.65 FAC
Příspěvek od Errors »
Tak od rána jedu na tento FW. Přechod z 1.08.44. Instalace jako taková proběhla na poprvé. Jen se mi tam občas nacpalo uložené nastavení z přístroje. I když jsem ho před tím smazal.
Jako plugin používám oscamhd_update od Granteca. Zatím OK.
Plugin: MCAS z 22.5.2012,
Skylink ICE (0D96), Apacer AC601 320GB via eSATA, Sharing OFF
FUBA 85cm 19.2+23.5E
, LNB Inverto Pro Quad Monoblock
Re: fw 1.08.65 FAC
vypni si to logovanie v oscamhd.conf .
Errors
Re: fw 1.08.65 FAC
stačí smazat cestu, nebo je potřeba ještě něco změnit?
