Stránka 3 z 3
Re: Backupsuite
Napsal: 10 lis 2013, 05:23
od vikino
backupsuite_13.7
Changed in version 13.7
- Removed some obsolete code which could generate an error in some cases
- made some parts more modular
Changed in version 13.6
- Improved the detection of the used image for reporting in the log file and in the file imageversion in the back-up folder.
Not sure if it is perfect now because of lack of information on how the various images identifies itself in the file /etc/issue
thx Pedro_Newbie
Re: Backupsuite
Napsal: 28 lis 2013, 20:13
od clasicrock
Backupsuite 14.0
Changed in version 14.0
- Revised Russian language again
- Now also support the Octagon SF8 XP1000
enigma2-plugin-extensions-backupsuite_14.0_mips32el.zip
Re: Backupsuite
Napsal: 30 led 2014, 06:28
od vikino
backupsuite_14.5
Again for Openpli 3.0 or later
Please don't try to use this version in the "older" images 2.1, the used programs/versions are not compatible
Changelog
Changed in version 14.5
- Added for all the Xtrends models 2 warnings because the Xtrends seems to have problems to flash images back which are greater than about 128MB (no hard boundary detected yet):
if the image size is between 111 MB and 128 MB the warning (in yellow) is:
Bei der Wiederherstellung dieses Backup könnte es zu einem Problem kommen da dieses nahe an der zulässigen Grösse liegt. Dies ist eine Beschränkung des Bootloaders, nicht des Backups oder der BackupSuite.
if the image is greater than 128MB the warning (in red) is:
Dieses Backup kann höchstwahrscheinlich nicht wieder eingespielt werden, es ist schlicht zu gross um es wieder herzustellen. Dies ist eine Beschränkung des Bootloaders, nicht des Backups oder der BackupSuite.
- Changed the aligning of the numbers in the size to back-up, now it detects whether the numbers are above or below the 100.000 KB (just for cosmetics)
Big thanks to the translators of the last 2 messages
DE Biki3
FR Demosat
IT Matrix64
TR SSD
for the other languages (ES, PL, RU and SK) I'm looking for translators who can translate the messages:
#message28
msgid "Most likely this back-up can't be restored because of it's size, it's simply too big to restore. This is a limitation of the bootloader not of the back-up or the BackupSuite."
#message29
msgid "There COULD be a problem with restoring this back-up because the size of the back-up comes close to the maximum size. This is a limitation of the bootloader not of the back-up or the BackupSuite."
thx Pedro_Newbie
Re: Backupsuite
Napsal: 15 bře 2014, 06:47
od vikino
backupsuite_15.0
Changed in version 15.0:
Changed the time measuring a bit because the newer kernels handles this a bit different (on the ET10000)
Added some translated German lines (free space check in USB version)
thx Pedro_Newbie
Re: Backupsuite
Napsal: 20 bře 2014, 06:47
od vikino
backupsuite_16.1
Changed in version 16.1
2 little bugfixes
Changed in version 16.0
Made the application more universal and easier to maintain for future models.
Now all supported brands/models are placed in a matrix (lookuptable.txt) with their parameters needed to make a back-up.
Now all what has to be done to support a new brand/model is enter the specifics into the lookuptable.txt, an example is show hereunder.
I moved the version (after some internal betaversions) to 16.0 because of the big changes in the code.
All is tested and should work fine
thx Pedro_Newbie
