MCAS
Re: MCAS
- Update : Mcas, Mclient and Keditor
--> DreCrypt Card fix.
--> Viaccess Card fix.
Re: MCAS
- mcas nd* card home sh** problem fix... (freezing problem)
Re: MCAS
MCAS k fw 1.08.44
- ShaMan
Re: MCAS
mcas_100928 pravděpodobně pro novější verze , stejně jako předchozí ..
28-09-2010 ird*to patch(emu) fix
- ShaMan
Re: MCAS 28-09-2010 2
MCAS 28-09-2010 2
tak dnes druhý Mcas
absat bis fix.
keydata.tmp = absat bis, canalsat + NL, seca rai tvglboo etc keys updated.
tak dnes druhý Mcas
absat bis fix.
Re: MCAS
- update : Mcas & Keditor
--> TvGlobo bug fix.
--> TvGlobo AU fix.
- Debug Mode on/off function add.
--> Start Mcas - Press OK Button - Press RED Button ON
--> Again press of RED Button debug Mode OFF
--> Debug Mode only for Bug analyze
--> Pls use with SW V10844 !
--> TvGlobo AU fix.
Re: MCAS
- update : Mcas
- new Functions add. :
--> Plugin Menu - Start Mcas (green Button) and press OK Button
--> Configuration : OK Button
--> EMM Loading on/off
--> Smartcard Message on/off
--> Card Slot 1 : use/not use (ein/aus)
--> Card Slot 2 : use/not use (ein/aus)
--> betacrypt use : irdeto protocol / nagravision protocol
Re: MCAS
Mcas - plugin pre fw 1.08.52
podpora BISS key
subor s BISS klucmi je vo /var/etc/coconut.dat
aktualizovana databaza klucov.
podpora BISS key
Re: MCAS
update : Mcas
--> SkyLink Irdeto SmartCard fix.
update : Keditor
--> Database update
- update keydata.tmp + coconut.dat
--> Database update
update : Mcas
update : Keditor
--> Database update
--> Database update
Re: MCAS
- Mcas & Keditor
--> SRG SF swiss Karte update fix. (Via - Hotbird13E)
--> Demux fehler fix. (25Nov)
--> Plugin connect problem auf via & seca fix. (NT1 etc.) - (25Nov)
--> TNTSAT EMU eingebaut Via3 (24Nov)
- ShaMan
Re: MCAS
- update Mcas
--> Skylink SmartCard EMM bug fix.
- update coconut
--> New function add.
--> SID TSID ONID Auto add.
--> Live Tv Mode : 2 x Info Button and press RED Button
- update coconut
Re: MCAS
- update : Mcas, Keditor und Mclient
--> EMM bug fix.
--> Crypto. bug fix.
- update : keydata.tmp + coconut.da
--> keys update
--> EMM bug fix.
--> keys update
Re: MCAS
HD+ Black SC fix.
RSA + Boxkey & New ProvID + CAID add.
HD+ Black SC fix.
Re: MCAS
- update : Mcas
-ORF EMU OK (Astra 19,2E)
http://www.lyngsat.com/packages/orf.html
-Austriasat AT EMU OK (Astra 19,2E)
http://www.austriasat.at/senderliste/
