Stránka 3 z 4
Re: FirmWare 0.9.3177
Napsal: 20 srp 2009, 23:01
od monkus
no, uz ide aj mne (1.33), restart bol moj kamarat
Napsal: 21 srp 2009, 00:18
od monkus
ked uz sa dostal tento fw von, tu su moje postrehy:
bugs:
- switch program / channel via EPG will freeze azbox hd
- image viewer still has problems with image size and optimalization
- loading boot logo only after restart (for 1 sec), not after wake up
- some problems with TP 11797 (f.e. Discovery SD) - audio, video (see attached video)
- movie player (iso image with dvd menu not supported, language setting is forgotten)
- not using audio language settings in tv mode
changes:
- movie player changes (mkv support fixed from 0.9.3111, some high quality movies play fluent, dts via hdmi, subtitles from file, iso file support without dvd menu)
- fixed rewind of movie files
- can move channels within all channels list
- web browsers (looks like little speed improvement?, keypad removed from 0.9.3111)
- always start in tv mode (settings)
- new default root password (azbox)
- no problems with scrambled channels (EMU, skylink and T&T cryptoworks cards), not neccessary to switch between channels after wake up or restart like fw before
- fixed problem with radio (occurs stop playing after 10 seconds)
no changes:
- twin dvb-s
- multitasking
- web browser (speed, flash/java plugin)
- email client
je to sice testovaci firmware, kazdopadne moje sympatie ma, a jedine, co mi naozaj vadi je, ze box zamrzne po prepnuti kanalu cez epg. ostatne veci co nejdu ma mrzia, ale prezijem :-)
Napsal: 21 srp 2009, 01:07
Podpora pre druhý tuner / aj DVB-T / je už v 0.9.2880
Tá chyba - áno nahlásime / ak to teda dobre chápem tak ide o to čo sa stane keby som potvrdil voľbu - viď obrázok /
Napsal: 21 srp 2009, 07:58
od rada
Mé dojmy z tohohle FW jsou víceméně kladné, chyby které má, se mě vesměs netýkají nebo mi nevadí.
opravené chyby - zrychleno načítání divx ze sítě, přetáčení filmů oběma směry, při wake up je již aktivován emu plugin, funkční FTP i po wake up, rychlejší start přístroje po zapnutí, rychlejší přepínání programů ?, pamatuje si nastavení jazyků a video nastavení
nové chyby - nemožnost přepínání přes EPG - viz monkus, nevyužívá nastavení pro jazyk v TV - vždy používá auto
+- - hned po nainstalování se mi při wakeup odmítla zapnout TV při připojení přes scart, bylo nutné přepnout TV manuálně, teď již startuje OK. I při wake up se zobrazuje logo, nemohu tedy potvrdit monkusovo tvrzení
Napsal: 21 srp 2009, 08:09
od monkus
dempsey: presne tak, k tomu obrazku. robilo to aj v 3111 a tusim aj v 2880
vseobecne sa mi vsak zda, ze stabilita tv modu je OK, uz nemusim prepinat medzi kanalmi, kym sa mi chytia karty.
Napsal: 21 srp 2009, 08:11
od monkus
rada: ako si pripojeny stb - tv? ja hdmi ... a uz par fw dozadu mi ro robi (dokonca ani pri starte mi to neukazovalo moje nadherne boot logo :-(
Napsal: 21 srp 2009, 08:20
Ostala aj chyba pri TP11797 , akurat treba mat dlhsie zapnuty prijimac, aby sa to prejavilo. Prijimac v rezime copmosit 576i nedokaze synchronne skladat , co sa na obrazovke prejavuje ako dvojity obraz. Viditelne pri pouziti analogoveho vystupu. V rezime komponent 576p tento ja zmizne.
Napsal: 21 srp 2009, 08:46
od rada
2monkus : jeste jsem se nerozhoupal ke koupi plasmy, mam starou 72cm CRT TV, propojeni scart.
Napsal: 21 srp 2009, 09:34
od vikino
mozno to pre niekoho nieje podstatne, ale pre mna zatial ano: vratil som sa z 3177 na 2880 a dvd rec s hdd mi cez scart vypise pri zapnuti nahravania error a nenahrava. Pritom ked som predtym presiel z nizsieho fw na 2880, tak nahraval.
Napsal: 21 srp 2009, 09:38
od monkus
dempsey: este jeden bug:
- shaking picture in pan&scan mode
Napsal: 21 srp 2009, 09:39
vikino
A akým spôsobom si "prešiel" na ten starší fw ?
Urobil si Format application area ?
Napsal: 21 srp 2009, 09:41
monkus píše:dempsey: este jeden bug:
Ok. Je to to isté o čom písal grantec, ale to sa prejavuje aj v Pillar box móde
Napsal: 21 srp 2009, 09:46
od monkus
mozem sa spytat, ludi co maju lcd/led od samsungu, ktory su pripojeni cez hdmi, ci vam funguje to boot logo (aj po restarte, aj po wake-upe)?
teoreticky kym telka zisti, ze je signal, mozno uz obrazok zmizne ...
Napsal: 21 srp 2009, 09:47
od Benny
dempsey píše:Podpora pre druhý tuner / aj DVB-T / je už v 0.9.2880
Tohle mi delal i 2880. Prijde mi ze si kazdy prijimac zije svym zivotem :)
Napsal: 21 srp 2009, 09:50
od vikino
dempsey nie, nahral som ho cez USB bez formatu.
je zaujimave, ked som presiel z 2371 na 2880 bez formatu area, tak dvd rec nahraval. Potom som z USB dal 3177 tiez bez formatu a nahraval, no tu ma stvalo ze sa nedal pozerat obraz pri nastaveni na pan and scan. Tak som to vratil z USB na 2880 bez formatu a dvd rec hdd zase nenahrava. :sad:
