funguje jeste satangelskeyupdater
- bambule
- Profík
Re: funguje jeste satangelskeyupdater
mam to velkejma a nic?tak nevím?
to je des. Este ti cosi ukazem:
Zapis klucov pre 0604 - bulsat v SoftCam.Key
do softcamu sa zapisuju ecm key - platne, pouzivane providerom.
Ich zapis ale moze byt pre jeden a ten isty emulator rozny. Je to sposobene tym,ze upravu emulatora mgcamd robia vsetci len cez hexeditor....
To je obsah suboru SoftCam.Key - to sa do binarky nedava, ale ako vidis, jeden a ten isty provider - podla sposobu upravy mgcamdu su rozne kluce... Tie tri hore nad farebnymi su urcene pre Vplug- do PC.#*#*#*#*#*#*#*#*#*#*# IRDETO KEYS #*#*#*#*#*#*#*#*#*#*#
I 060300 M2 87A3DBFC22B199E762C649E08F2A5E65 ; Al Jazeera Sport ricky 2011-07-22 02:54:57
I 060300 M1 903C3379A8698CE1D829CE82010C2F31 ; Al Jazeera Sport ricky 2011-07-22 02:54:02
I 00 0A 4BFEAC1A47633733 ; Aurora(156.0E) tonytr 2008-05-10 15:58:49
I 00 0C 151C4F82ACE5C5C1 ; Aurora(156.0E) tonytr 2008-05-10 17:42:15
I 00 08 82931AB0EC8594C1 ; Aurora(156.0E) tonytr 2008-05-10 15:58:22
I 060400 06 DB88B668A980CDBBCD8B06CE49A0BA6B ; Bulsat 39e vPlug tonytr 2011-08-05 17:58:32
I 060400 02 DFDD0C4B92B4ABD26514B9AF9F0C79C4 ; Bulsat 39e vPlug tailor 2011-06-03 12:37:46
I 060400 04 E31A2DE00121386236D3641FD152D4B4 ; Bulsat 39e vPlug coscos1222 2011-08-04 10:51:50
I 0604 06 DB88B668A980CDBBCD8B06CE49A0BA6B ; bulsat mgcamd patched version tonytr 2011-08-05 17:59:00
I 0604 04 E31A2DE00121386236D3641FD152D4B4 ; bulsat mgcamd patched version coscos1222 2011-08-04 10:51:37
I 062200 04 798BB61368D0A0551C68F065A076695C ; C+Nederland (19°E) tonytr 2011-05-13 14:42:30
I 062200 02 154A1A865DF48DED7115CDFF51977785 ; C+Nederland (19°E) lelmi 2011-08-12 08:59:12
I 062200 06 CB8C5E7BC42F4B0E3E3D6CD8B0DFAD50 ; CANAL+ NL ASTRA 19.2E vPlug coscos1222 2011-05-19 20:03:40
I 060410 06 77F559DB38FF1EE1295EF099D44CC5BE ; Nov@ Cy vPlug coscos 2010-04-19 18:51:04
I 060410 08 175630E44C05FC1DB97912D1112AA3A0 ; Nov@ Cy vPlug coscos 2010-04-19 18:51:23
- bambule
- Profík
tak novej softcam updater stahuje v pořadku keys konečne ale mgcamd stale nechce rozjed bulsat kanaly .....diema ,diema 2 atd.
toto ti stiahol ?
to je totiz aktivny key
- bambule
- Profík
ne ne 0604 06 005B53 takhle začína takže špatnej najmsatu je tenhle ale 060400 04 E31A2DE00121386236D3641FD152D4B4 ;Bulsat (39°E)tak jak to je.
hore mas oba a so spravnym zapisom .
- bambule
- Profík
tak už jsem tam updatoval sparavne keys dnes aktualní hore napsane a stale nic nejde.tak nevím co ten mgcam dela jako.
Pri takychto veciach sa vzdy bojim,ze ked dokoncim upravu, na druhy den to zdochne, lebo provideri asi len cakaju,kedy co spravim, aby to mohli zrusit. Idem sa kuknut na bulsat konecne ja , lebo ty budes furt otravovat .
Inak - uz si horsi ako iron(69) a maiden dokopy
- bambule
- Profík
a nemužou byt špatne atributy na softcam.key.....644 tam mam je to dobře .pač v nem jsou dobre keys ale třeba se nedostanou do mgcamdu je to možne?
SlavoF
max3 CAID .
LA7 , na ktorom sa da prepisat, tam nieje. takze bulsat smola.
- bambule
- Profík
a jakto že na jinejch boxech to jde ?
lebo ine maju aj providera LA7 - teda mali. Z toho jasne vyplyva,ze na coolstreame to v patchu 1.35a neslo ani kedysi - ale to asi nik nezbadal - taky bol o to zaujem .
- bambule
- Profík
a co 1.35c mgcamd koukal jsi aj na nej.
- bambule
- Profík
jinak to řeší teda nova verze mgcamd teda.
