HD Glass16
Skiny a picony pro přijímač Clarke-Tech , Xtrend
Re: HD Glass16
Skin- HD Glass16 ver. 6.08
- added new dyn. icon: Network status - can be enabled/disabled via setup
options: yes, no and with internet check
icons: net error - internet unavailable (with internet check)
wifi - communication through wifi adapter
eth - communication through lan adapter
3g - communication through modem
? net - broken communication detection
- updated pl, sk, cz, en, ru, de, it, uk translations
- help updated in download
- icons sets updated in download
- updated OLED type: default (thx aso)
Update is available online via setup
after update icons type will be set to default type 1, you must download/update icons sets via setup-download menu, then select your prefered icons type
Re: HD Glass16
HD Glass16 ver. 6.20
- updated pt translation (thx 0_o)
- updated encoding.conf
- fix Ignore timeout for infobar activated ...
- fix OLED type default: StandbySummary (thx aso)
- added screen 31 and style 8
- previews and extrascreens graphics updated in download
- fix option: cpu/mem, temp/rpm and provider
thx shamann
Re: HD Glass16
HD Glass16 ver. 6.35
- fixed tr translations (thx kikirim)
- added es - Spanish translation (thx elgeneral)
- added support-autodetect for BH 1.7.1 - 1.7.6(1.6.6 - removed)
- added screen 34, style 9
thx shamann
Re: HD Glass16
HD Glass16 ver. 6.47
- fix ipk installer
thx shamann
Re: HD Glass16
HD Glass16 ver. 6.59
- added protocol, version (oscam only) in enhanced bar
- added protocol, version (oscam only), cw0 and cw1 in Ecm and TP status
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al translations
- fix the setup of skin
- added support for DE 4.0 001r002 (older removed)
Menu Icons updated in download (DE 4.0 Menu Icons) - setup HD Glass16 - download menu
thx shamann
Re: HD Glass16
HD Glass16 ver. 6.80
- fix piconCam detection in download menu (OScam)
- added support icons set up to 30
- fix screens 36, 37, 9
- added new Menu type: Icons Bar
- added new option: Enable Animation in Menu type - Icons/Icons Bar, this mean:
press OK to start selected item: enable - with, disable - without anim
thx shamann
Re: HD Glass16
HD Glass16 ver. 6.97
- joined mips and sh4 version to one universal ipk
- added autodetection of the architecture (mips/sh4) to set supported binary
files
- added screen 77, 78
Note: this is first universal ipk for all architecture (sh4, mipsel), before installing in SH4 uninstall old version first then install this one
thx shamann
Re: HD Glass16
HD Glass16 ver. 7.37
- fix channel number in all Chammel Selection screens used default (by image)
services list
- removed screen for displaying Help - will be use default definition by image
- changed activating of the Special info from global action to infobarplugins
- added new Channelsel. type: Classical
- added autodetect images based on dmm image from 24.4.2013 and autodisable
option: Enable ChannelSel. percent
- fix main code for images based on dmm from 24.4.13 with full compatibility to older images
Recomendation: before update your image to image based on dmm image from 24.4.13, update skin to version 7.37
thx shamann
Re: HD Glass16
HD Glass16 ver. 7.52
- weather:
- small correction of text objects: date, state
- added the day in date
- added low, higt temp. in forecast with autocolor change of temp.
- added more cities in city_Code.txt
thx shamann
romanmesko Slovakia
Re: HD Glass16
Příspěvek od romanmesko »
HD Glass 16 ver. 7.68
VU+UNO 4k SE,OpenATV 6.3 aktívny,250GB Hdd,Portugal 85cm AL click clack,LNB Smart Twin Titanium 0.1db, Motor SG 2100,HDD WD My passport 500GB,LED Samsung UE46D5520,AV Receiver ONKYO HT-R548
Re: HD Glass16
HD Glass16 ver. 7.70
- added new OLED type: Default 2 (optimalized for dm7020hd, dm8k)
- added autodetect and autoconnect to backup server if primary failed
(download menu, update)
thx shamann
Re: HD Glass16
HD Glass16 ver. 7.83
- fix Channelsel. type: PIG(+several event) - show next 3 events
- added new Channelsel. type: New style(+several event)
- 2nd fix all renderers to display picon (IPTV channels only)
thx shamann
Re: HD Glass16
HD Glass 16 ver. 7.96
- weather: updated translations dictionary
- added new set of weather icons (setup of the skin - download menu - weather icons)
update is available online
thx shamann
Re: HD Glass16
HD Glass 16 ver. 7.99
- weather: fix/enhanced parser for translation
- added new option: ECM refresh time (2-10s)
- changed method to refresh ECM info and HDD state
- fix AGC(S) for dm7020hd
thx shamann
Re: HD Glass16
HD Glass 16 ver. 8.54
- main code update
- added info in setup about skin website
Thx Shamann
Zpět na „Clarke-Tech , Xtrend Skiny a picony“
