Stránka 2 z 18
Re: Enigma 2 RTi core RC4
Napsal: 29 led 2011, 14:51
od karlos66
andrejtom píše:bambule píše:a komunikuje oskam s mgcamd
ano, ale to musis zvlast nastavit.
ja to mam oscam+cccamd a ide to super, mam bielu Skylink (0D03)
mohl by jsi prosím popsat jak to nastavit? díky
Napsal: 29 led 2011, 14:53
od andrejtom
aku mas kartu?
Napsal: 29 led 2011, 14:57
od karlos66
andrejtom píše:aku mas kartu?
bílou, už se s tím trápím dvě hodiny...:-(
Napsal: 29 led 2011, 15:15
od andrejtom
karlos66 píše:andrejtom píše:aku mas kartu?
takto to mam ja
najdes to vo /etc/tuxbox/config/
oscam.conf
[global]
logfile = /var/log/oscam.log
maxlogsize = 50000
saveinithistory = 1
Nice = -10
ClientTimeout = 5
ClientMaxIdle = 30
CacheDelay = 600
BindWait = 20
ResolveDelay = 15
Sleep = 0
waitforcards = 1
[dvbapi]
enabled = 0
au = 1
boxtype = none
[webif]
httpport = 8082
httpuser = oscam
httppwd = oscam
httprefresh = 5
httpallowed = 127.0.0.1,10.1.1.1-10.1.1.200
httphideidleclients = 0
httpreadonly = 0
httpsavefullcfg = 0
[cccam]
port = 10000
reshare = 2
version = 2.2.1
[MONITOR]
Port = 0
MonLevel = 3
NoCrypt = 127.0.0.1
NoCrypt = 10.160.70.200-10.160.170.255
NoCrypt = 10.160.70.201
#[newcamd]
#Key = 0102030405060708091011121314
#Port = 34001@1843:003411
[camd35]
Port = 35000@0D03:000004,000008
oscam.server
[reader]
label = skylink
enable = 1
protocol = internal
device = /dev/sc0
services =
caid = 0D03
detect = cd
mhz = 500
cardmhz = 357
ident =
group = 1
emmcache = 1,3,2
ecmcache = 1
lb_weight = 100
deprecated = 1
oscam.user
account]
user = user
pwd = pass
#expdate =
group = 1
#hostname =
#uniq = 0
#sleep = 0
monlevel = 0
au = 1
#services =
caid = 0D03
ident = 0D03:000004,000008
a este v
cccam.conf
L: 127.0.0.1 35000 user pass 0D03 000004,000008
Napsal: 29 led 2011, 15:16
od asp28
Po kratkych testoch moje postrehy a pripomienky
klady:
- RC4 + Glassys Utility 1.42 + oscam 1.0 svn 4640 = spokojnost.
Tato verzia sa naozaj vydarila (hovorim za Premium HD+) Je rychla a da sa povedat ze zatial aj stabilna.
Kedze funguje nahravanie aj internal card reader pod oscam nemam naozaj dovod sa uz vracat na OFW.
zapory:
- po prepnuti na radia a po spusteni nejakej radiostanice - totalne zatuhnutie u Premium HD+ (nutny hardreset)
- mate tiez problem, ze ako vypnut ventilator? V menu ziadna polozka. Viete iny sposob okrem jeho odpojenia?
- na VFD mi asi posledne tri verzie u Premium HD+ pretrvava problem pri zobrazovani textu - za textom zarovnanym
vlavo sa nachadza preskrtnute = a zvysne neidentifikovatelne znaky do konca displeya. Mate niekto na to recept
ako to odstranit, pripadne patch?
- malickost ale predsa... kde sa da zobrazit celkovy zoznam nacasovanych nahravani? Existuje taka moznost?
Napsal: 29 led 2011, 15:19
od bambule
a instalace přes jazup1.3 ju
Napsal: 29 led 2011, 16:05
od dzambo2302
pls aké je predvolené rodičovské heslo ? omylom som si to hodil na HBO HD a neviem sa toho zbaviť
Napsal: 29 led 2011, 16:16
od johank
asp28 píše:Po kratkych testoch moje postrehy a pripomienky
klady:
zapory:
-s rádiem stejný problém, box při zatuhnutí funguje pouze přes web rozhraní
- ventilátor mám řešen přídavným modulem, který řídí otáčky ventilátoru dle vnitřní teploty. Sice nějaká koruna navíc, ale už na ventilátor nemyslím. Jinak je tu návod v diskusi ke klasickému firmware AZBOXu s vložením odporu a snížením otáček=snížení hlučnosti.
- seznam nastavení nahrfávání s mi zobrazuje v Menu - časovač. V EPG si vyberu program na nahrávání - přidat časování a celkový seznam je jak píši Menu - Časovač
Napsal: 29 led 2011, 17:25
od ericek74
tak standby asi ok-vypnuto v 12:30 a zapnuto v 17:10 a nabehlo to v pohode
Napsal: 29 led 2011, 19:03
od bambule
pošle nekdo tuto verzi enigma na email díky nejde stahnout na žadnem odkaz díky......nitram.kepis@seznam.cz
Napsal: 29 led 2011, 19:06
od schmegea
ani odsud to nejde?
http://www.ulozto.cz/7613141/rti-core-1-1-4-rc4-rar
Napsal: 29 led 2011, 19:17
od frcko73
ako je to s prehravanim mkv a avi?Vdaka za odpoved.
EDIT:z ulozto to ide
Napsal: 29 led 2011, 19:49
od Beam
Jde vam zvuk na Nove SD @ Astra 3B (23.5E) - 12070.00 H ?
Napsal: 29 led 2011, 19:57
od schmegea
zvuk jde na všech programech, ale stává se že vypadne. Je třeba přepnout na jiný program a pak návrat zpět. Ještě bych nenastavoval zvuk na AC3 jsou ještě problémy.
Já mám problém když přepnu na CSfilm (leoTV) tak ztratím signál na hdmi, pomůže až restart. - nastavení 1080i i 1080p další rozlišení jsem nezkoušel
Jinak zatím stabilní.
Napsal: 29 led 2011, 20:01
od Beam
Vim ze obcas pri prepnuti zvuk vypadne, ale na Novu a Prima Cool prepinam a nejde, na Nove HD a Prime jde.
edit: Aha.. tak koukam ze na vetsine programu ni nejde zvuk, vlastne jde jenom na Prima a CT, budu laborovat
edit 2: uz to jde, ale nevim co se zmenilo ;( mel jsme pustenej media player a ladoval jsem setting, ale jeste pred rebootem to slo, po rebootu uz se zda ze to jde, tak ze by to bylo settingem, puvodne jsem programy ladil primo na SAT.
